stm32f4 timer9 ayarı
Başlatan fryrmnd, 16 Mart 2014, 12:40:21
fryrmnd
Arkadaşlar st nin STM32 Cube kütüphanesi ile timer9 kurmak istedim. Timer çalışıyor yalnız aşağıdaki parametrelerle Bülent hocamın örneğindeki gibi 0.5 sn de led flash etmesi lazım. 2 sn de bir yapıyor.  sadece  prescaler= 84000 period= 1000 değerinde doğru bir şekilde 1 sn de yapıyor.
Parametrelerim mi yanlış. Nasıl kontrol edebilirim acaba.
Teşekkürler.
/* Includes ------------------------------------------------------------------*/
#include "stm32f4xx_hal.h"
#include "stm32f4_discovery.h"
TIM_HandleTypeDef htim9;
static void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_TIM9_Init(void);
static void Error_Handler(void);
int main(void)
  HAL_Init();
  BSP_LED_Init(LED4);
  BSP_LED_Init(LED5);
  SystemClock_Config();
  MX_GPIO_Init();
  MX_TIM9_Init();
  while (1)
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 8;
  RCC_OscInitStruct.PLL.PLLN = 336;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = 4;
  if(HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_SYSCLK|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
    Error_Handler();
  TIM_ClockConfigTypeDef sClockSourceConfig;
  TIM_MasterConfigTypeDef sMasterConfig;
  htim9.Instance = TIM9;
  htim9.Init.Prescaler = 42000-1;
  htim9.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim9.Init.Period = 1000;
  htim9.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  HAL_TIM_Base_Init(&htim9);
  sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
  HAL_TIM_ConfigClockSource(&htim9, &sClockSourceConfig);
  sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
  HAL_TIMEx_MasterConfigSynchronization(&htim9, &sMasterConfig);
  HAL_TIM_Base_Start_IT(&htim9);
void MX_GPIO_Init(void) {
  GPIO_InitTypeDef GPIO_InitStruct;
  __GPIOD_CLK_ENABLE();
  /*Configure GPIO pin : PD12 */
  GPIO_InitStruct.Pin = GPIO_PIN_12;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_HIGH;
  HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
	 	BSP_LED_Toggle(LED4);
  /* Turn LED5 (RED) on */
  BSP_LED_On(LED5);
  while(1)
#ifdef USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
    ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
#endif
 RCC_OscInitStruct.PLL.PLLQ = 7;
yapıp denermisiniz
fryrmnd
Maalesef hocam aynı parametrelerle Q=7  için denendim durum aynı. :(  Neyi kontrol etmeliyim bilmiyorum.
timer normal gibi ama SystemInıt de benim ayarlarım 168mhz de dediğim gibi.
benim konfig dosyam
  * @file    system_stm32f4xx.c
  * @author  MCD Application Team
  * @version V1.0.1
  * @date    30-July-2013
  * @brief   CMSIS Cortex-M4 Device Peripheral Access Layer System Source File.
  *          This file contains the system clock configuration for STM32F4xx devices,
  *          and is generated by the clock configuration tool
  *          stm32f4xx_Clock_Configuration_V1.0.1.xls
  * 1.  This file provides two functions and one global variable to be called from
  *     user application:
  *      - SystemInit(): Setups the system clock (System clock source, PLL Multiplier
  *                      and Divider factors, AHB/APBx prescalers and Flash settings),
  *                      depending on the configuration made in the clock xls tool.
  *                      This function is called at startup just after reset and
  *                      before branch to main program. This call is made inside
  *                      the "startup_stm32f4xx.s" file.
  *      - SystemCoreClock variable: Contains the core clock (HCLK), it can be used
  *                                  by the user application to setup the SysTick
  *                                  timer or configure other parameters.
  *      - SystemCoreClockUpdate(): Updates the variable SystemCoreClock and must
  *                                 be called whenever the core clock is changed
  *                                 during program execution.
  * 2. After each device reset the HSI (16 MHz) is used as system clock source.
  *    Then SystemInit() function is called, in "startup_stm32f4xx.s" file, to
  *    configure the system clock before to branch to main program.
  * 3. If the system clock source selected by user fails to startup, the SystemInit()
  *    function will do nothing and HSI still used as system clock source. User can
  *    add some code to deal with this issue inside the SetSysClock() function.
  * 4. The default value of HSE crystal is set to 25MHz, refer to "HSE_VALUE" define
  *    in "stm32f4xx.h" file. When HSE is used as system clock source, directly or
  *    through PLL, and you are using different crystal you have to adapt the HSE
  *    value to your own configuration.
  * 5. This file configures the system clock as follows:
  *        Supported STM32F4xx device revision    | Rev A
  *        System Clock source                    | PLL (HSE)
  *        SYSCLK(Hz)                             | 168000000
  *        HCLK(Hz)                               | 168000000
  *        AHB Prescaler                          | 1
  *        APB1 Prescaler                         | 4
  *        APB2 Prescaler                         | 2
  *        HSE Frequency(Hz)                      | 8000000
  *        PLL_M                                  | 8
  *        PLL_N                                  | 336
  *        PLL_P                                  | 2
  *        PLL_Q                                  | 7
  *        PLLI2S_N                               | NA
  *        PLLI2S_R                               | NA
  *        I2S input clock                        | NA
  *        VDD(V)                                 | 3,3
  *        Main regulator output voltage          | Scale1 mode
  *        Flash Latency(WS)                      | 5
  *        Prefetch Buffer                        | OFF
  *        Instruction cache                      | ON
  *        Data cache                             | ON
  *        Require 48MHz for USB OTG FS,          | Disabled
  *        SDIO and RNG clock                     |
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2011 STMicroelectronics</center></h2>
/** @addtogroup CMSIS
/** @addtogroup stm32f4xx_system
/** @addtogroup STM32F4xx_System_Private_Includes
#include "stm32f4xx.h"
/** @addtogroup STM32F4xx_System_Private_TypesDefinitions
/** @addtogroup STM32F4xx_System_Private_Defines
/************************* Miscellaneous Configuration ************************/
/*!< Uncomment the following line if you need to use external SRAM mounted
     on STM324xG_EVAL board as data memory  */
/* #define DATA_IN_ExtSRAM */
/*!< Uncomment the following line if you need to relocate your vector Table in
     Internal SRAM. */
/* #define VECT_TAB_SRAM */
#define VECT_TAB_OFFSET  0x00 /*!< Vector Table base offset field.
                                   This value must be a multiple of 0x200. */
/************************* PLL Parameters *************************************/
/* PLL_VCO = (HSE_VALUE or HSI_VALUE / PLL_M) * PLL_N */
#define PLL_M      8
#define PLL_N      336
/* SYSCLK = PLL_VCO / PLL_P */
#define PLL_P      2
/* USB OTG FS, SDIO and RNG Clock =  PLL_VCO / PLLQ */
#define PLL_Q      7
/** @addtogroup STM32F4xx_System_Private_Macros
/** @addtogroup STM32F4xx_System_Private_Variables
  uint32_t SystemCoreClock = 168000000;
  __I uint8_t AHBPrescTable[16] = {0, 0, 0, 0, 0, 0, 0, 0, 1, 2, 3, 4, 6, 7, 8, 9};
/** @addtogroup STM32F4xx_System_Private_FunctionPrototypes
static void SetSysClock(void);
#ifdef DATA_IN_ExtSRAM
  static void SystemInit_ExtMemCtl(void);
#endif /* DATA_IN_ExtSRAM */
/** @addtogroup STM32F4xx_System_Private_Functions
  * @brief  Setup the microcontroller system
  *         Initialize the Embedded Flash Interface, the PLL and update the
  *         SystemFrequency variable.
  * @param  None
  * @retval None
void SystemInit(void)
  /* FPU settings ------------------------------------------------------------*/
  #if (__FPU_PRESENT == 1) && (__FPU_USED == 1)
    SCB->CPACR |= ((3UL << 10*2)|(3UL << 11*2));  /* set CP10 and CP11 Full Access */
  #endif
  /* Reset the RCC clock configuration to the default reset state ------------*/
  /* Set HSION bit */
  RCC->CR |= (uint32_t)0x00000001;
  /* Reset CFGR register */
  RCC->CFGR = 0x00000000;
  /* Reset HSEON, CSSON and PLLON bits */
  RCC->CR &= (uint32_t)0xFEF6FFFF;
  /* Reset PLLCFGR register */
  RCC->PLLCFGR = 0x24003010;
  /* Reset HSEBYP bit */
  RCC->CR &= (uint32_t)0xFFFBFFFF;
  /* Disable all interrupts */
  RCC->CIR = 0x00000000;
  SystemInit_ExtMemCtl();
  /* Configure the System clock source, PLL Multiplier and Divider factors,
     AHB/APBx prescalers and Flash settings ----------------------------------*/
  SetSysClock();
  /* Configure the Vector Table location add offset address ------------------*/
#ifdef VECT_TAB_SRAM
  SCB->VTOR = SRAM_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal SRAM */
#else
  SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH */
#endif
   * @brief  Update SystemCoreClock variable according to Clock Register Values.
  *         The SystemCoreClock variable contains the core clock (HCLK), it can
  *         be used by the user application to setup the SysTick timer or configure
  *         other parameters.
  * @note   Each time the core clock (HCLK) changes, this function must be called
  *         to update SystemCoreClock variable value. Otherwise, any configuration
  *         based on this variable will be incorrect.
  * @note   - The system frequency computed by this function is not the real
  *           frequency in the chip. It is calculated based on the predefined
  *           constant and the selected clock source:
  *           - If SYSCLK source is HSI, SystemCoreClock will contain the HSI_VALUE(*)
  *           - If SYSCLK source is HSE, SystemCoreClock will contain the HSE_VALUE(**)
  *           - If SYSCLK source is PLL, SystemCoreClock will contain the HSE_VALUE(**)
  *             or HSI_VALUE(*) multiplied/divided by the PLL factors.
  *         (*) HSI_VALUE is a constant defined in stm32f4xx.h file (default value
  *             16 MHz) but the real value may vary depending on the variations
  *             in voltage and temperature.
  *         (**) HSE_VALUE is a constant defined in stm32f4xx.h file (default value
  *              25 MHz), user has to ensure that HSE_VALUE is same as the real
  *              frequency of the crystal used. Otherwise, this function may
  *              have wrong result.
  *         - The result of this function could be not correct when using fractional
  *           value for HSE crystal.
  * @param  None
  * @retval None
void SystemCoreClockUpdate(void)
  uint32_t tmp = 0, pllvco = 0, pllp = 2, pllsource = 0, pllm = 2;
  /* Get SYSCLK source -------------------------------------------------------*/
  tmp = RCC->CFGR & RCC_CFGR_SWS;
  switch (tmp)
    case 0x00:  /* HSI used as system clock source */
      SystemCoreClock = HSI_VALUE;
      break;
    case 0x04:  /* HSE used as system clock source */
      SystemCoreClock = HSE_VALUE;
      break;
    case 0x08:  /* PLL used as system clock source */
      pllsource = (RCC->PLLCFGR & RCC_PLLCFGR_PLLSRC) >> 22;
      pllm = RCC->PLLCFGR & RCC_PLLCFGR_PLLM;
      if (pllsource != 0)
        /* HSE used as PLL clock source */
        pllvco = (HSE_VALUE / pllm) * ((RCC->PLLCFGR & RCC_PLLCFGR_PLLN) >> 6);
        /* HSI used as PLL clock source */
        pllvco = (HSI_VALUE / pllm) * ((RCC->PLLCFGR & RCC_PLLCFGR_PLLN) >> 6);
      pllp = (((RCC->PLLCFGR & RCC_PLLCFGR_PLLP) >>16) + 1 ) *2;
      SystemCoreClock = pllvco/pllp;
      break;
    default:
      break;
  /* Compute HCLK frequency --------------------------------------------------*/
  /* Get HCLK prescaler */
  tmp = AHBPrescTable[((RCC->CFGR & RCC_CFGR_HPRE) >> 4)];
  /* HCLK frequency */
  SystemCoreClock >>= tmp;
  * @brief  Configures the System clock source, PLL Multiplier and Divider factors,
  *         AHB/APBx prescalers and Flash settings
  * @Note   This function should be called only once the RCC clock configuration
  *         is reset to the default reset state (done in SystemInit() function).
  * @param  None
  * @retval None
/*            PLL (clocked by HSE) used as System clock source                */
  __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  /* Enable HSE */
  RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  /* Wait till HSE is ready and if Time out is reached exit */
  do
    HSEStatus = RCC->CR & RCC_CR_HSERDY;
    StartUpCounter++;
  } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  if ((RCC->CR & RCC_CR_HSERDY) != RESET)
    HSEStatus = (uint32_t)0x01;
    HSEStatus = (uint32_t)0x00;
  if (HSEStatus == (uint32_t)0x01)
    /* Select regulator voltage output Scale 1 mode, System frequency up to 168 MHz */
    RCC->APB1ENR |= RCC_APB1ENR_PWREN;
    PWR->CR |= PWR_CR_VOS;
    /* HCLK = SYSCLK / 1*/
    RCC->CFGR |= RCC_CFGR_HPRE_DIV1;
    /* PCLK2 = HCLK / 2*/
    RCC->CFGR |= RCC_CFGR_PPRE2_DIV2;
    /* PCLK1 = HCLK / 4*/
    RCC->CFGR |= RCC_CFGR_PPRE1_DIV4;
    /* Configure the main PLL */
    RCC->PLLCFGR = PLL_M | (PLL_N << 6) | (((PLL_P >> 1) -1) << 16) |
                   (RCC_PLLCFGR_PLLSRC_HSE) | (PLL_Q << 24);
    /* Enable the main PLL */
    RCC->CR |= RCC_CR_PLLON;
    /* Wait till the main PLL is ready */
    while((RCC->CR & RCC_CR_PLLRDY) == 0)
    /* Configure Flash prefetch, Instruction cache, Data cache and wait state */
    FLASH->ACR = FLASH_ACR_ICEN |FLASH_ACR_DCEN |FLASH_ACR_LATENCY_5WS;
    /* Select the main PLL as system clock source */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
    RCC->CFGR |= RCC_CFGR_SW_PLL;
    /* Wait till the main PLL is used as system clock source */
    while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS ) != RCC_CFGR_SWS_PLL);
  { /* If HSE fails to start-up, the application will have wrong clock
         configuration. User can add here some code to deal with this error */
  * @brief  Setup the external memory controller. Called in startup_stm32f4xx.s
  *          before jump to __main
  * @param  None
  * @retval None
  *         Called in startup_stm32f4xx.s before jump to main.
  *         This function configures the external SRAM mounted on STM324xG_EVAL board
  *         This SRAM will be used as program data memory (including heap and stack).
  * @param  None
  * @retval None
/*-- GPIOs Configuration -----------------------------------------------------*/
 +                       SRAM pins assignment                                   +
 | PD0  <-> FSMC_D2  | PE0  <-> FSMC_NBL0 | PF0  <-> FSMC_A0 | PG0 <-> FSMC_A10 |
 | PD1  <-> FSMC_D3  | PE1  <-> FSMC_NBL1 | PF1  <-> FSMC_A1 | PG1 <-> FSMC_A11 |
 | PD4  <-> FSMC_NOE | PE3  <-> FSMC_A19  | PF2  <-> FSMC_A2 | PG2 <-> FSMC_A12 |
 | PD5  <-> FSMC_NWE | PE4  <-> FSMC_A20  | PF3  <-> FSMC_A3 | PG3 <-> FSMC_A13 |
 | PD8  <-> FSMC_D13 | PE7  <-> FSMC_D4   | PF4  <-> FSMC_A4 | PG4 <-> FSMC_A14 |
 | PD9  <-> FSMC_D14 | PE8  <-> FSMC_D5   | PF5  <-> FSMC_A5 | PG5 <-> FSMC_A15 |
 | PD10 <-> FSMC_D15 | PE9  <-> FSMC_D6   | PF12 <-> FSMC_A6 | PG9 <-> FSMC_NE2 |
 | PD11 <-> FSMC_A16 | PE10 <-> FSMC_D7   | PF13 <-> FSMC_A7 |------------------+
 | PD12 <-> FSMC_A17 | PE11 <-> FSMC_D8   | PF14 <-> FSMC_A8 |
 | PD13 <-> FSMC_A18 | PE12 <-> FSMC_D9   | PF15 <-> FSMC_A9 |
 | PD14 <-> FSMC_D0  | PE13 <-> FSMC_D10  |------------------+
 | PD15 <-> FSMC_D1  | PE14 <-> FSMC_D11  |
 |                   | PE15 <-> FSMC_D12  |
   /* Enable GPIOD, GPIOE, GPIOF and GPIOG interface clock */
  RCC->AHB1ENR   = 0x00000078;
  /* Connect PDx pins to FSMC Alternate function */
  GPIOD->AFR[0]  = 0x00cc00cc;
  GPIOD->AFR[1]  = 0xcc0ccccc;
  /* Configure PDx pins in Alternate function mode */
  GPIOD->MODER   = 0xaaaa0a0a;
  /* Configure PDx pins speed to 100 MHz */
  GPIOD->OSPEEDR = 0xffff0f0f;
  /* Configure PDx pins Output type to push-pull */
  GPIOD->OTYPER  = 0x00000000;
  /* No pull-up, pull-down for PDx pins */
  GPIOD->PUPDR   = 0x00000000;
  /* Connect PEx pins to FSMC Alternate function */
  GPIOE->AFR[0]  = 0xc00cc0cc;
  GPIOE->AFR[1]  = 0xcccccccc;
  /* Configure PEx pins in Alternate function mode */
  GPIOE->MODER   = 0xaaaa828a;
  /* Configure PEx pins speed to 100 MHz */
  GPIOE->OSPEEDR = 0xffffc3cf;
  /* Configure PEx pins Output type to push-pull */
  GPIOE->OTYPER  = 0x00000000;
  /* No pull-up, pull-down for PEx pins */
  GPIOE->PUPDR   = 0x00000000;
  /* Connect PFx pins to FSMC Alternate function */
  GPIOF->AFR[0]  = 0x00cccccc;
  GPIOF->AFR[1]  = 0xcccc0000;
  /* Configure PFx pins in Alternate function mode */
  GPIOF->MODER   = 0xaa000aaa;
  /* Configure PFx pins speed to 100 MHz */
  GPIOF->OSPEEDR = 0xff000fff;
  /* Configure PFx pins Output type to push-pull */
  GPIOF->OTYPER  = 0x00000000;
  /* No pull-up, pull-down for PFx pins */
  GPIOF->PUPDR   = 0x00000000;
  /* Connect PGx pins to FSMC Alternate function */
  GPIOG->AFR[0]  = 0x00cccccc;
  GPIOG->AFR[1]  = 0x000000c0;
  /* Configure PGx pins in Alternate function mode */
  GPIOG->MODER   = 0x00080aaa;
  /* Configure PGx pins speed to 100 MHz */
  GPIOG->OSPEEDR = 0x000c0fff;
  /* Configure PGx pins Output type to push-pull */
  GPIOG->OTYPER  = 0x00000000;
  /* No pull-up, pull-down for PGx pins */
  GPIOG->PUPDR   = 0x00000000;
/*-- FSMC Configuration ------------------------------------------------------*/
  /* Enable the FSMC interface clock */
  RCC->AHB3ENR         = 0x00000001;
  /* Configure and enable Bank1_SRAM2 */
  FSMC_Bank1->BTCR[2]  = 0x00001015;
  FSMC_Bank1->BTCR[3]  = 0x00010603;
  FSMC_Bank1E->BWTR[2] = 0x0fffffff;
  Bank1_SRAM2 is configured as follow:
  p.FSMC_AddressSetupTime = 3;
  p.FSMC_AddressHoldTime = 0;
  p.FSMC_DataSetupTime = 6;
  p.FSMC_BusTurnAroundDuration = 1;
  p.FSMC_CLKDivision = 0;
  p.FSMC_DataLatency = 0;
  p.FSMC_AccessMode = FSMC_AccessMode_A;
  FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM2;
  FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
  FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_PSRAM;
  FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;
  FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
  FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
  FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
  FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
  FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;
  FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
fryrmnd
Hocam kusura bakmayın arada bir kopyala yapıştır yaparken hata yapmışım. onu düzelttim.
    Error_Handler();
    Error_Handler();
yerine
    Error_Handler();
  if(HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
    Error_Handler();
Ama bu sefer de 42000 değerinde 0.5sn kesme aldım. Fakfat 84000 de 1 sn alamadım.
Bende ki system dosyası şöyle
  * @version V2.0.0
  * @date    18-February-2014
  *   This file provides two functions and one global variable to be called from
  *   user application:
  *      - SystemInit(): This function is called at startup just after reset and
  * @attention
  * <h2><center>&copy; COPYRIGHT 2014 STMicroelectronics</center></h2>
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/*!< Uncomment the following line if you need to use external SRAM or SDRAM mounted
     on STM324xG_EVAL/STM324x9I_EVAL boards as data memory  */
#if defined(STM32F405xx) || defined(STM32F415xx) || defined(STM32F407xx) || defined(STM32F417xx) || defined(STM32F427xx) || defined(STM32F437xx) || defined(STM32F429xx) || defined(STM32F439xx)
#endif /* STM32F405xx || STM32F415xx || STM32F407xx || STM32F417xx || STM32F427xx || STM32F437xx || STM32F429xx || STM32F439xx */
#if defined(STM32F427xx) || defined(STM32F437xx) || defined(STM32F429xx) || defined(STM32F439xx)
/* #define DATA_IN_ExtSDRAM */
#endif /* STM32F427xx || STM32F437xx || STM32F429xx || STM32F439xx */
#if defined(DATA_IN_ExtSRAM) && defined(DATA_IN_ExtSDRAM)
 #error "Please select DATA_IN_ExtSRAM or DATA_IN_ExtSDRAM "
#endif /* DATA_IN_ExtSRAM && DATA_IN_ExtSDRAM */
     Internal SRAM. */
  /* This variable is updated in three ways:
      1) by calling CMSIS function SystemCoreClockUpdate()
      2) by calling HAL API function HAL_RCC_GetHCLKFreq()
      3) each time HAL_RCC_ClockConfig() is called to configure the system clock frequency
         Note: If you use this function to configure the system clock; then there
               is no need to call the 2 first functions listed above, since SystemCoreClock
               variable is updated automatically.
  uint32_t SystemCoreClock = 16000000;
#if defined (DATA_IN_ExtSRAM) || defined (DATA_IN_ExtSDRAM)
#endif /* DATA_IN_ExtSRAM || DATA_IN_ExtSDRAM */
  *         Initialize the FPU setting, vector table location and External memory
  *         configuration.
  * @param  None
  * @retval None
  #endif
  /* Set HSION bit */
#else
#endif
  *         other parameters.
  *         (*) HSI_VALUE is a constant defined in stm32f4xx_hal_conf.h file (default value
  *         (**) HSE_VALUE is a constant defined in stm32f4xx_hal_conf.h file (its value
  *              depends on the application requirements), user has to ensure that HSE_VALUE
  *              is same as the real frequency of the crystal used. Otherwise, this function
  *              may have wrong result.
  * @param  None
  * @retval None
  switch (tmp)
      break;
      break;
      if (pllsource != 0)
      break;
    default:
      break;
  *         This function configures the external memories (SRAM/SDRAM)
  *         This SRAM/SDRAM will be used as program data memory (including heap and stack).
  * @param  None
  * @retval None
#if defined (DATA_IN_ExtSDRAM)
  register uint32_t tmpreg = 0, timeout = 0xFFFF;
  register uint32_t index;
  /* Enable GPIOC, GPIOD, GPIOE, GPIOF, GPIOG, GPIOH and GPIOI interface
      clock */
  RCC->AHB1ENR |= 0x000001F8;
  /* Connect PDx pins to FMC Alternate function */
  GPIOD->AFR[0]  = 0x000000CC;
  GPIOD->AFR[1]  = 0xCC000CCC;
  GPIOD->MODER   = 0xA02A000A;
  /* Configure PDx pins speed to 50 MHz */
  GPIOD->OSPEEDR = 0xA02A000A;
  /* Connect PEx pins to FMC Alternate function */
  GPIOE->AFR[0]  = 0xC00000CC;
  GPIOE->AFR[1]  = 0xCCCCCCCC;
  GPIOE->MODER   = 0xAAAA800A;
  /* Configure PEx pins speed to 50 MHz */
  GPIOE->OSPEEDR = 0xAAAA800A;
  /* Connect PFx pins to FMC Alternate function */
  GPIOF->AFR[0]  = 0xCCCCCCCC;
  GPIOF->AFR[1]  = 0xCCCCCCCC;
  GPIOF->MODER   = 0xAA800AAA;
  /* Configure PFx pins speed to 50 MHz */
  GPIOF->OSPEEDR = 0xAA800AAA;
  /* Connect PGx pins to FMC Alternate function */
  GPIOG->AFR[0]  = 0xCCCCCCCC;
  GPIOG->AFR[1]  = 0xCCCCCCCC;
  GPIOG->MODER   = 0xAAAAAAAA;
  /* Configure PGx pins speed to 50 MHz */
  GPIOG->OSPEEDR = 0xAAAAAAAA;
  /* Connect PHx pins to FMC Alternate function */
  GPIOH->AFR[0]  = 0x00C0CC00;
  GPIOH->AFR[1]  = 0xCCCCCCCC;
  /* Configure PHx pins in Alternate function mode */
  GPIOH->MODER   = 0xAAAA08A0;
  /* Configure PHx pins speed to 50 MHz */
  GPIOH->OSPEEDR = 0xAAAA08A0;
  /* Configure PHx pins Output type to push-pull */
  GPIOH->OTYPER  = 0x00000000;
  /* No pull-up, pull-down for PHx pins */
  GPIOH->PUPDR   = 0x00000000;
  /* Connect PIx pins to FMC Alternate function */
  GPIOI->AFR[0]  = 0xCCCCCCCC;
  GPIOI->AFR[1]  = 0x00000CC0;
  /* Configure PIx pins in Alternate function mode */
  GPIOI->MODER   = 0x0028AAAA;
  /* Configure PIx pins speed to 50 MHz */
  GPIOI->OSPEEDR = 0x0028AAAA;
  /* Configure PIx pins Output type to push-pull */
  GPIOI->OTYPER  = 0x00000000;
  /* No pull-up, pull-down for PIx pins */
  GPIOI->PUPDR   = 0x00000000;
/*-- FMC Configuration ------------------------------------------------------*/
  /* Enable the FMC interface clock */
  RCC->AHB3ENR |= 0x00000001;
  /* Configure and enable SDRAM bank1 */
  FMC_Bank5_6->SDCR[0] = 0x000019E0;
  FMC_Bank5_6->SDTR[0] = 0x01115351;
  /* SDRAM initialization sequence */
  /* Clock enable command */
  FMC_Bank5_6->SDCMR = 0x00000011;
  tmpreg = FMC_Bank5_6->SDSR & 0x00000020;
  while((tmpreg != 0) && (timeout-- > 0))
  /* Delay */
  for (index = 0; index<1000; index++);
  /* PALL command */
  FMC_Bank5_6->SDCMR = 0x00000012;
  timeout = 0xFFFF;
  /* Auto refresh command */
  FMC_Bank5_6->SDCMR = 0x00000073;
  timeout = 0xFFFF;
  /* MRD register program */
  FMC_Bank5_6->SDCMR = 0x00046014;
  timeout = 0xFFFF;
  /* Set refresh count */
  tmpreg = FMC_Bank5_6->SDRTR;
  FMC_Bank5_6->SDRTR = (tmpreg | (0x0000027C<<1));
  /* Disable write protection */
  tmpreg = FMC_Bank5_6->SDCR[0];
  FMC_Bank5_6->SDCR[0] = (tmpreg & 0xFFFFFDFF);
#endif /* DATA_IN_ExtSDRAM */
  RCC->AHB1ENR   |= 0x00000078;
  GPIOD->AFR[0]  = 0x00CCC0CC;
  GPIOD->AFR[1]  = 0xCCCCCCCC;
  GPIOD->MODER   = 0xAAAA0A8A;
  GPIOD->OSPEEDR = 0xFFFF0FCF;
  GPIOE->AFR[0]  = 0xC00CC0CC;
  GPIOE->MODER   = 0xAAAA828A;
  GPIOE->OSPEEDR = 0xFFFFC3CF;
  GPIOF->AFR[0]  = 0x00CCCCCC;
  GPIOF->AFR[1]  = 0xCCCC0000;
  GPIOF->MODER   = 0xAA000AAA;
  GPIOF->OSPEEDR = 0xFF000FFF;
  GPIOG->AFR[0]  = 0x00CCCCCC;
  GPIOG->AFR[1]  = 0x000000C0;
  GPIOG->MODER   = 0x00085AAA;
  GPIOG->OSPEEDR = 0x000CAFFF;
/*-- FMC/FSMC Configuration --------------------------------------------------*/
  /* Enable the FMC/FSMC interface clock */
#if defined(STM32F427xx) || defined(STM32F437xx) || defined(STM32F429xx)|| defined(STM32F439xx)
  FMC_Bank1->BTCR[2]  = 0x00001011;
  FMC_Bank1->BTCR[3]  = 0x00000201;
  FMC_Bank1E->BWTR[2] = 0x0fffffff;
#if defined(STM32F405xx) || defined(STM32F415xx) || defined(STM32F407xx)|| defined(STM32F417xx)
  FSMC_Bank1->BTCR[2]  = 0x00001011;
  FSMC_Bank1->BTCR[3]  = 0x00000201;
  FSMC_Bank1E->BWTR[2] = 0x0FFFFFFF;
#endif /* STM32F405xx || STM32F415xx || STM32F407xx || STM32F417xx */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
Birde 168 Mhz için flash latency ne kullanıyorsunuz hocam.
neden böyle sizin dosyada
fryrmnd
Hocam otomatik üretilen kod o şekilde.
Tabii onu 168MHz olarak da denedim.
hocam proje ekte bir deneme imkanınız varmı?
http://s3.dosya.tc/server19/1IkQxV/deneme3.zip.html
