uart sorunu
Başlatan canbulut, 16 Mayıs 2015, 15:58:22
canbulut
Merhaba arkadaslar,
Bu kodlar ile transmit yapamadım. Problem ne olabilir?
 * File:   Uart_TX.c
 * Author: Bulut
 * Created on 16 May?s 2015 Cumartesi, 10:29
#include <xc.h>
#include "Config.h"
void main(void) {
// PIC16F628A Configuration Bit Settings
// 'C' source line config statements
//#include <xc.h>
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
// CONFIG
#pragma config FOSC = INTOSCCLK // Oscillator Selection bits (INTOSC oscillator: CLKOUT function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT disabled)
#pragma config MCLRE = ON      // RA5/MCLR/VPP Pin Function Select bit (RA5/MCLR/VPP pin function is digital input, MCLR internally tied to VDD)
#pragma config BOREN = ON       // Brown-out Detect Enable bit (BOD enabled)
#pragma config LVP = OFF        // Low-Voltage Programming Enable bit (RB4/PGM pin has digital I/O function, HV on MCLR must be used for programming)
#pragma config CPD = OFF        // Data EE Memory Code Protection bit (Data memory code protection off)
#pragma config CP = OFF         // Flash Program Memory Code Protection bit (Code protection off)
#define _XTAL_FREQ 4000000
    TRISA=0;
    PORTA=0;
    TRISB=0;
    PORTB=0;
    CMCON=7;
    TXSTAbits.BRGH=1;       // select low speed Baud Rate (see baud rate calcs below)
    TXSTAbits.TX9=0;        // select 8 data bits
    TXSTAbits.TXEN = 1;     // enable transmit
    TXSTAbits.SYNC=0;
    SPBRG=25;  // here is calculated value of SPBRGH and SPBRGL
void uart(void);
    while (1)
         uart();
void uart()
   while(!TXSTAbits.TRMT)    // make sure buffer full bit is high before transmitting
    TXREG ='M';
    return;
İlk bakışta göze iki hata çarpıyor:
1) RCSTA.SPEN biti 1 yapılmamış. Seri port modülünün ana açma kapama anahtarı bu.
2) Seri port ile ilgili bacakların TRIS bitleri 1 olmalı. TX için de böyle, çıkış diye 0 olmayacak yani. Kulağa yanlış gibi geliyor ama datasheet'te böyle yazmış.
Başka hata var mı bilmiyorum, çok ayrıntılı bakmadım.
canbulut
dedikleriniz yaptım gelişme yok hocam.
Şimdi bir tane daha gördüm: while(!TXSTAbits.TRMT) satırından sonra noktalı virgül olacak. Yani TXREG = 'm'; ifadesi döngünün bir parçası olmamalı. Döngünün amacı TRMT 0 olduğu sürece (ki bu gönderme işleminin devam ettiğini gösterir) boş boş dönüp beklemek.
canbulut
onuda düzelttim. bişeyler daha var kaçan ama.. ne :)
mesaj birleştirme:: 16 Mayıs 2015, 18:43:15
donanımı basic ile denedim sorun yok..xc8'de çalışmıyor. son hali asağıda
 * File:   Uart_TX.c
 * Author: Bulut
#include <xc.h>
//#include "Config.h"
void main(void) {
//#include <xc.h>
// CONFIG
    TRISA=0;
    PORTA=0;
    TRISB=6;
    PORTB=0;
    CMCON=7;
    RCSTAbits.CREN=1;
    //OPTION_REGbits.nRBPU=0;
    TXSTAbits.SYNC=0;
void uartt(void);
    while (1)
         uartt();
void uartt()
   while(!TXSTAbits.TRMT);    // make sure buffer full bit is high before transmitting
    TXREG ='M';
    //return;
İlk mesajımda bahsetmiş olduğum RCSTAbits.SPEN = 1; ifadesi vermiş olduğun son kodda bulunmuyor. Gözünden kaçmadığından emin misin?
Pyrodigy
Uart tx/rx pinlerini giriş yaptınmı ?
Deneyiniz...
 * File:   main.c
 * Author: mbmb
 * Created on 17 Mayıs 2015 Pazar, 00:38
#include <xc.h>
// CONFIG 16F628A
void uartt(void);
void main(void)
    TRISA = 0;
    PORTA = 0;
    TRISB = 6;
    PORTB = 0;
    CMCON = 7;
    TXSTAbits.BRGH = 1;       // select low speed Baud Rate (see baud rate calcs below)
    TXSTAbits.TX9 = 0;        // select 8 data bits
    RCSTAbits.CREN = 1;
    //OPTION_REGbits.nRBPU = 0;
    TXSTAbits.SYNC = 0;
    SPBRG = 25;  // here is calculated value of SPBRGH and SPBRGL
    while (1)
         uartt();
void uartt(void)
    TXREG = 'M';
canbulut
gerçektende spen bitini kaçırmışım şu anda çalışıyor. Teşekkürler arkadaşlar. teşekkürler Tagli hocam.
Çalışan kodu ekleyebilirsiniz...
canbulut
peki bu gönderme işinde text halinde nasıl gönderirim. kendi library'mi mi kurmam gerekiyor paylaşılan bir yer var mı_?
yazarken mesajıınızı aldım mehmet hocam.asağıdaki kodu ekledim.
    RCSTAbits.SPEN=1;
Text denen  şey arka arkaya sıralanmış ASCII karakterinden ibarettir. Sonlandığının anlaşılabilmesi için diznin sonunca \0 karakteri bulunur (ki bildiğin sıfırdır bu). Yani yapman gereken şey, yukarıda yaptığın işlemi bir döngü içinde dizinin tüm elemanları için tekrarlamak ve en son \0 karakterini gönderdikten sonra durmak.
@canbulut; C yapısına biraz dikkat edebilirsiniz.
canbulut
aşağıdaki kodlar ile text şeklinde gönderebiliyorum ama rakam,sayı gönderemiyorum.
void xmitt(char TxArray[])   // An array that can hold 25 characters
  int b=0;
 while (TxArray[b]!='\0')
   TXREG =TxArray[b];
   b++;
Gökhan BEKEN
  int b=0;
 while (TxArray[b]!='\0') // stringin sonuna gelene kadar döngü çalışır
   while(!TXSTAbits.TRMT);    // meşguliyet bitene kadar bekle
   TXREG =TxArray[b]; // stringin sıradaki karakterini gönder
   b++; //sırayı 1 artır
void xmittData(char TxArray[], unsigned int boyut)   // An array that can hold 25 characters
  int b=0;
 while (boyut--) // sayac 0 olana kadar döngüyü dönder
kullanım:
TxArray[0]=0xFF;
TxArray[1]=0x00;
TxArray[2]=0x15;
TxArray[3]=0x75;
xmittData(&TxArray[0], 4) // dizideki verilerden 4 tanesini gönder
stringler 0 ile bittiğinden sıfıra ulaşana kadar döngüyü döndeririz, fakat göndereceğiniz şey, sayısal data ise, adet belirtmeniz şart.
