STM32F10x USB Library Problemi
Başlatan Mucit23, 07 Temmuz 2015, 15:47:03
Hocam init ayarı için main programında sırayla aşağıdaki fonksiyonları çağırıyorum.
  Set_System();
  USB_Interrupts_Config();
  Set_USBClock();
  USB_Init();
Bu fonksiyonların hepsi hw_config.c içerisinde.
  * @file    hw_config.c
  * @author  MCD Application Team
  * @version V4.0.0
  * @date    21-January-2013
  * @brief   Hardware Configuration & Setup
  * @attention
  * <h2><center>&copy; COPYRIGHT 2013 STMicroelectronics</center></h2>
  * Licensed under MCD-ST Liberty SW License Agreement V2, (the "License");
  * You may not use this file except in compliance with the License.
  * You may obtain a copy of the License at:
  *        http://www.st.com/software_license_agreement_liberty_v2
  * Unless required by applicable law or agreed to in writing, software
  * distributed under the License is distributed on an "AS IS" BASIS,
  * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  * See the License for the specific language governing permissions and
  * limitations under the License.
/* Includes ------------------------------------------------------------------*/
#include "hw_config.h"
#include "usb_lib.h"
#include "usb_desc.h"
#include "usb_pwr.h"
#include "platform_config.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
  ErrorStatus HSEStartUpStatus;
/* Extern variables ----------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
  static void IntToUnicode (uint32_t value , uint8_t *pbuf , uint8_t len);
/* Private functions ---------------------------------------------------------*/
* Function Name  : Set_System
* Description    : Configures Main system clocks & power.
* Input          : None.
* Return         : None.
void Set_System(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
  /* Enable the PWR clock */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE);
  /* Enable USB_DISCONNECT GPIO clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIO_DISCONNECT, ENABLE);
  /* USB_DISCONNECT_PIN used as USB pull-up */
  GPIO_InitStructure.GPIO_Pin = USB_DISCONNECT_PIN;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
  GPIO_Init(USB_DISCONNECT, &GPIO_InitStructure);
* Function Name  : Set_USBClock
* Description    : Configures USB Clock input (48MHz).
* Input          : None.
* Output         : None.
* Return         : None.
void Set_USBClock(void)
  /* USBCLK = PLLCLK */
  RCC_USBCLKConfig(RCC_USBCLKSource_PLLCLK_1Div5);
  /* Enable USB clock */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_USB, ENABLE);
* Function Name  : Enter_LowPowerMode.
* Description    : Power-off system clocks and power while entering suspend mode.
* Input          : None.
* Output         : None.
* Return         : None.
void Enter_LowPowerMode(void)
  /* Set the device state to suspend */
  bDeviceState = SUSPENDED;
  /* Request to enter STOP mode with regulator in low power mode */
  PWR_EnterSTOPMode(PWR_Regulator_LowPower, PWR_STOPEntry_WFI);
* Function Name  : Leave_LowPowerMode.
* Description    : Restores system clocks and power while exiting suspend mode.
* Input          : None.
* Output         : None.
* Return         : None.
void Leave_LowPowerMode(void)
  DEVICE_INFO *pInfo = &Device_Info;
  /* Set the device state to the correct state */
  if (pInfo->Current_Configuration != 0)
    /* Device configured */
    bDeviceState = CONFIGURED;
    bDeviceState = ATTACHED;
  /*Enable SystemCoreClock*/
  SystemInit();
* Function Name  : USB_Interrupts_Config.
* Description    : Configures the USB interrupts.
* Input          : None.
* Output         : None.
* Return         : None.
void USB_Interrupts_Config(void)
  NVIC_InitTypeDef NVIC_InitStructure;
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  NVIC_InitStructure.NVIC_IRQChannel = USB_HP_CAN1_TX_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
* Function Name  : USB_Cable_Config.
* Description    : Software Connection/Disconnection of USB Cable.
* Input          : NewState: new state.
* Output         : None.
* Return         : None
void USB_Cable_Config (FunctionalState NewState)
  if (NewState != DISABLE)
    GPIO_ResetBits(USB_DISCONNECT, USB_DISCONNECT_PIN);
    GPIO_SetBits(USB_DISCONNECT, USB_DISCONNECT_PIN);
* Function Name  : Get_SerialNum.
* Description    : Create the serial number string descriptor.
* Input          : None.
* Output         : None.
* Return         : None.
void Get_SerialNum(void)
  uint32_t Device_Serial0, Device_Serial1, Device_Serial2;
  Device_Serial0 = *(uint32_t*)ID1;
  Device_Serial1 = *(uint32_t*)ID2;
  Device_Serial2 = *(uint32_t*)ID3;
  Device_Serial0 += Device_Serial2;
  if (Device_Serial0 != 0)
    IntToUnicode (Device_Serial0, &CustomHID_StringSerial[2] , 8);
    IntToUnicode (Device_Serial1, &CustomHID_StringSerial[18], 4);
* Function Name  : HexToChar.
* Description    : Convert Hex 32Bits value into char.
* Input          : None.
* Output         : None.
* Return         : None.
  uint8_t idx = 0;
  for( idx = 0 ; idx < len ; idx ++)
    if( ((value >> 28)) < 0xA )
      pbuf[ 2* idx] = (value >> 28) + '0';
      pbuf[2* idx] = (value >> 28) + 'A' - 10;
    value = value << 4;
    pbuf[ 2* idx + 1] = 0;
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
USB clock ayarlarım aşağıdaki gibi yapılmış durumda.
Yalnız dikkatimi çeken birşey daha var. DM ve DP pinleri için extra bir tanımlama yapmadık. Biz USB modülünü aktif edince bu pinler otomatikmen USB donanımına bağlanmış mı oluyor?
USB donanım frekansı yanlışım yoksa 48MHZ olması gerekiyor. Benim İşlemcim 72Mhz de çalışıyor. Bölücü ayarları felan doğru olması lazım.
justice_for_all
TFT duruyorsa program biyerde kilitleniyordur orasını bulmak lazım .Hangi kart ile deniyosun? USB pinleri Registerlerinde aktif ediliyor yalnış bilmiyorsam. Clock ayarın doğru 72 Mhz / 1.5 =48 Mhz.
Hocam işlemci interruptları aktif edince donuyor.
Mainde aşağıdaki interruptları aktif etmek için   USB_Interrupts_Config(); fonksiyonunu çağırıyorum. (fonksiyon bir önceki mesajımda hw_configçc içerisinde)
İnterruptlar aktif olunca işlemci  USB_Init(); fonksiyonunda takılıp kalıyor.
justice_for_all
Kart hangisiydi hocam yada sizmi yaptınız kartı?
Yok hocam ya hazır bir kart
http://propix.com.pl/pl/p/Modul-STM32-Firebull/54
Ne yapacam bilmiyorum. Herşey iyi güzel görünüyor. Başka ne hata yapıyor olabilir
justice_for_all
#20
JP9 jumper i bağlımı hocam?
mesaj birleştirme:: 09 Temmuz 2015, 13:50:55
  * @file    platform_config.h
  * @version V4.0.0
  * @brief   Evaluation board specific configuration file.
  * @attention
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef __PLATFORM_CONFIG_H
#define __PLATFORM_CONFIG_H
#if defined(STM32L1XX_MD) || defined(STM32L1XX_HD)|| defined(STM32L1XX_MD_PLUS)
 #include "stm32l1xx.h"
 #if defined (USE_STM32L152_EVAL)
  #include "stm32l152_eval.h"
 #elif defined (USE_STM32L152D_EVAL)
  #include "stm32l152d_eval.h"
 #else
  #error "Missing define: USE_STM32L152_EVAL or USE_STM32L152D_EVAL"
 #endif /* USE_STM32L152_EVAL */
#elif defined (STM32F10X_MD) || defined (STM32F10X_HD) || defined (STM32F10X_XL)
 #include "stm32f10x.h"
 #if defined (USE_STM3210B_EVAL)
  #include "stm3210b_eval.h"
 #elif defined (USE_STM3210E_EVAL)
  #include "stm3210e_eval.h"
 #else
  #error "Missing define: USE_STM3210B_EVAL or USE_STM3210E_EVAL"
 #endif /* USE_STM3210B_EVAL */
#elif defined (USE_STM32373C_EVAL)
 #include "stm32f37x.h"
 #include "stm32373c_eval.h"
#elif defined (USE_STM32303C_EVAL)
 #include "stm32f30x.h"
 #include "stm32303c_eval.h"
#endif
/* Exported types ------------------------------------------------------------*/
/* Exported constants --------------------------------------------------------*/
/* Uncomment the line corresponding to the STMicroelectronics evaluation board
   used to run the example */
#if !defined (USE_STM3210B_EVAL) &&  !defined (USE_STM3210E_EVAL) &&  !defined (USE_STM32L152_EVAL) &&  !defined (USE_STM32L152D_EVAL)&&  !defined (USE_STM32373C_EVAL) &&  !defined (USE_STM32303C_EVAL)
 //#define USE_STM3210B_EVAL
 //#define USE_STM3210E_EVAL
 //#define USE_STM32L152_EVAL
//#define USE_STM32L152D_EVAL
//#define USE_STM32373C_EVAL
 #define USE_STM32303C_EVAL
#endif
/*Unique Devices IDs register set*/
#if defined(STM32L1XX_MD) || defined(STM32L1XX_HD) || defined(STM32L1XX_MD_PLUS)
#define         ID1          (0x1FF80050)
#define         ID2          (0x1FF80054)
#define         ID3          (0x1FF80064)
#elif defined (STM32F37X) || defined(STM32F30X)
#define         ID1          (0x1FFFF7AC)
#define         ID2          (0x1FFFF7B0)
#define         ID3          (0x1FFFF7B4)
#else /*STM32F1x*/
#define         ID1          (0x1FFFF7E8)
#define         ID2          (0x1FFFF7EC)
#define         ID3          (0x1FFFF7F0)
#endif
/* Define the STM32F10x hardware depending on the used evaluation board */
#ifdef USE_STM3210B_EVAL
  #define USB_DISCONNECT                      GPIOD
  #define USB_DISCONNECT_PIN                  GPIO_Pin_9
  #define RCC_APB2Periph_GPIO_DISCONNECT      RCC_APB2Periph_GPIOD
  #define ADC1_DR_Address                     ((uint32_t)0x4001244C)
  #define USB_DISCONNECT                      GPIOB
  #define USB_DISCONNECT_PIN                  GPIO_Pin_14
  #define RCC_APB2Periph_GPIO_DISCONNECT      RCC_APB2Periph_GPIOB
#elif defined (USE_STM32L152_EVAL) || defined (USE_STM32L152D_EVAL)
   For STM32L15xx devices it is possible to use the internal USB pullup
   controlled by register SYSCFG_PMC (refer to RM0038 reference manual for
   more details).
   It is also possible to use external pullup (and disable the internal pullup)
   by setting the define USB_USE_EXTERNAL_PULLUP in file platform_config.h
   and configuring the right pin to be used for the external pull up configuration.
   To have more details on how to use an external pull up, please refer to
   STM3210E-EVAL evaluation board manuals.
 /* Uncomment the following define to use an external pull up instead of the
    integrated STM32L15xx internal pull up. In this case make sure to set up
    correctly the external required hardware and the GPIO defines below.*/
/* #define USB_USE_EXTERNAL_PULLUP */
 #if !defined(USB_USE_EXTERNAL_PULLUP)
  #define STM32L15_USB_CONNECT                SYSCFG_USBPuCmd(ENABLE)
  #define STM32L15_USB_DISCONNECT             SYSCFG_USBPuCmd(DISABLE)
  #define RCC_AHBPeriph_GPIO_DISCONNECT       0
 #elif defined(USB_USE_EXTERNAL_PULLUP)
  /* PA0 is chosen just as illustrating example, you should modify the defines
    below according to your hardware configuration. */
  #define USB_DISCONNECT                      GPIOA
  #define USB_DISCONNECT_PIN                  GPIO_Pin_0
  #define RCC_AHBPeriph_GPIO_DISCONNECT       RCC_AHBPeriph_GPIOA
  #define STM32L15_USB_CONNECT                GPIO_ResetBits(USB_DISCONNECT, USB_DISCONNECT_PIN)
  #define STM32L15_USB_DISCONNECT             GPIO_SetBits(USB_DISCONNECT, USB_DISCONNECT_PIN)
 #endif /* USB_USE_EXTERNAL_PULLUP */
  #define ADC1_DR_Address                     ((uint32_t)0x40012458)
#if defined (USE_STM32373C_EVAL)
  #define USB_DISCONNECT                      GPIOC
  #define USB_DISCONNECT_PIN                  GPIO_Pin_5
  #define RCC_AHBPeriph_GPIO_DISCONNECT       RCC_AHBPeriph_GPIOC
#endif
#if defined (USE_STM32303C_EVAL)
  #define USB_DISCONNECT_PIN                  GPIO_Pin_8
  #define RCC_AHBPeriph_GPIO_DISCONNECT       RCC_AHBPeriph_GPIOB
#define RCC_AHBPeriph_ALLGPIO                 (RCC_AHBPeriph_GPIOA \
                                              | RCC_AHBPeriph_GPIOB \
                                              | RCC_AHBPeriph_GPIOC \
                                              | RCC_AHBPeriph_GPIOD \
                                              | RCC_AHBPeriph_GPIOE \
                                              | RCC_AHBPeriph_GPIOF )
#endif
  #define RCC_AHBPeriph_GPIO_IOAIN            RCC_AHBPeriph_GPIOB
  #define GPIO_IOAIN                          GPIOB
  #define GPIO_IOAIN_PIN                      GPIO_Pin_12   /* PB.12 */
  #define ADC_AIN_CHANNEL                     ADC_Channel_18
  #define RCC_AHBPeriph_GPIO_IOAIN            RCC_AHBPeriph_GPIOF
  #define GPIO_IOAIN                          GPIOF
  #define GPIO_IOAIN_PIN                      GPIO_Pin_10   /* PF.10 */
  #define ADC_AIN_CHANNEL                     ADC_Channel_31
  #define ADC1_DR_Address                     0x4001244C
  #define GPIO_IOAIN_PIN                      GPIO_Pin_1   /* PB.1 */
  #define ADC_AIN_CHANNEL                     ADC_Channel_9
  #define GPIO_Mode_AIN                       GPIO_Mode_AN
  #define ADC1_DR_Address                      0x5000030C
  #define RCC_AHBPeriph_GPIO_IOAIN            RCC_AHBPeriph_GPIOC
  #define GPIO_IOAIN                          GPIOC
  #define GPIO_IOAIN_PIN                      GPIO_Pin_1   /* PC.1 */
  #define ADC_AIN_CHANNEL                     ADC_Channel_7
#else
  #define RCC_APB2Periph_GPIO_IOAIN           RCC_APB2Periph_GPIOC
  #define GPIO_IOAIN_PIN                      GPIO_Pin_4   /* PC.04 */
  #define ADC_AIN_CHANNEL                     ADC_Channel_14
/* Exported macro ------------------------------------------------------------*/
/* Exported functions ------------------------------------------------------- */
#endif /* __PLATFORM_CONFIG_H */
bu kodu kullanıyomusunuz hocam ?
mesaj birleştirme:: 09 Temmuz 2015, 13:55:04
hw_config.c içinde
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
diye değiştirip denermisinizhocam.
Kullanıyorum. Ama ben o dosyayı bayağı bi düzenledim. STM32F10x ile çalışacak şekilde diğer işlemciler için bulunan tanımlamaları kod kalabalığı olmaması için sildim.
/******************** (C) COPYRIGHT 2010 STMicroelectronics ********************
* File Name          : platform_config.h
* Author             : MCD Application Team
* Version            : V3.2.1
* Date               : 07/05/2010
* Description        : Evaluation board specific configuration file.
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  #define RCC_APB2Periph_GPIO_DISCONNECT      RCC_APB2Periph_GPIOC
  #define RCC_APB2Periph_ALLGPIO             (RCC_APB2Periph_GPIOA \
                                              | RCC_APB2Periph_GPIOB \
                                              | RCC_APB2Periph_GPIOC \
                                              | RCC_APB2Periph_GPIOD \
                                              | RCC_APB2Periph_GPIOE )
/*STM32F1x*/
/******************* (C) COPYRIGHT 2010 STMicroelectronics *****END OF FILE****/
Disconnect Pin ayarlarını vs hepsini kendi boardıma göre yaptım. USB aktif olduğunda LD6 ledi yanıyor.
Bendeki boardda USB_DISCONNECT pini Portc.9'a bağlı. Portc.9 GND de iken Aktif oluyor.
justice_for_all
Benim aklıma ordan geliyodu ama onuda yapmışsın baska bise kalmadı yapacak arastırayım bakim biraz.
Hocam çok iyi olur. Ciddi anlamda 2 gündür bu USB işine uğraşıyorum. Ben ST Forumda yazacam birde
justice_for_all
Hocam verdiğiniz likte PC için yazılmış USB hid Test programı gibi birşey var. Bana STM32F103 için yazılmış HID örnekleri lazım.
justice_for_all
Ben işyerinde olduğum için yükleyemedim içinden ne olduğunu bilmiyodum ben stm için yazılmış sandım hocam.
bunu deneyin bide isterseniz
https://github.com/RavWin/RHIDDemo/tree/master/tstHID-STM32F103
Hocam ilginiz için teşekkür ederim. Ben o kodlar dahil birçok projeyi indirdim. İnceliyorum ama göze çarpacak bir hata bulamıyorum.
Daha önce stm32f10x ile usb kullanan başka birisi varmı?
justice_for_all
http://www.st.com/web/en/catalog/tools/PF259446
burdaki usb ornegini denedim hocam stm32f072rb discoda calistirdim.usb lib kullanabilirsiniz sanirim nasil kullanmaniz gerektigide yaziyor zaten.
