VHDL ile Digital Saat Uygulaması
Başlatan alicavuslu, 17 Haziran 2016, 20:35:48
alicavuslu
https://www.youtube.com/watch?v=kt8IWj-xNEI
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
entity digital_clock is
	generic(
		SYS_FREQ : integer := 100_000_000
    Port(
		in_clk : in std_logic;
		in_rst : in std_logic;
		in_set : in std_logic;
		in_chng_seg : in std_logic;
		in_inc : in std_logic;
		out_seg : out std_logic_vector(7 downto 0);
		out_seg_leds : out std_logic_vector(7 downto 0)
end digital_clock;
architecture Behavioral of digital_clock is
	component hour_digit_cntrl
	Port (
		in_pulse : in std_logic;
		in_inc_right : in std_logic;
		in_inc_left : in std_logic;
		out_right_digit : out std_logic_vector(3 downto 0);
		out_left_digit : out std_logic_vector(3 downto 0)
	end component;
	component min_sec_digit_cntrl
	Generic(
		DIGIT_SIZE : integer := 10
	Port (
		out_digit : out std_logic_vector(3 downto 0);
		out_pulse : out std_logic
	end component;
	component bcd2seven_segment
	Port (
		in_bcd : in std_logic_vector(3 downto 0);
		out_seven_segment : out std_logic_vector(7 downto 0)
	end component;
	component pulse_generator
	generic(
	Port (
		out_sec_pulse : out std_logic
	end component;
	type t_Time_Digits is array (0 to 5) of std_logic_vector(3 downto 0);
	signal r_Time_Digits : t_Time_Digits := (others=>(others => '0'));
	signal r_bcd : std_logic_vector(3 downto 0) := (others => '0');
	signal r_seg_leds : std_logic_vector(7 downto 0) := (others => '0');
	signal r_seg : std_logic_vector(5 downto 0) := "011111";
	signal r_seg_cnt : std_logic_vector(2 downto 0) := (others => '0');
	signal r_seg_pulse : std_logic := '0';
	signal r_sec_pulse : std_logic := '0';
	signal r_sec_right_pulse : std_logic := '0';
	signal r_sec_left_pulse : std_logic := '0';
	signal r_min_right_pulse : std_logic := '0';
	signal r_min_left_pulse : std_logic := '0';
	signal r_set : std_logic := '0';
	signal r_set_chk : std_logic_vector(5 downto 0) := "011111";
	signal r_set_cntrl : std_logic_vector(2 downto 0) := (others=> '0');
	signal r_set_cnt : integer := 0;
	signal r_set_stts : std_logic := '0';
	signal r_chng_cntrl : std_logic_vector(2 downto 0) := (others=> '0');
	signal r_set_seg : std_logic_vector(2 downto 0) := (others=> '0');
	signal r_inc_cntrl : std_logic_vector(2 downto 0) := (others=> '0');
	signal r_inc_seg : std_logic_vector(5 downto 0) := (others=> '0');
	function f_set_shift(r_seg : std_logic_vector(5 downto 0) ; r_set_stts : std_logic; r_set_seg : std_logic_vector(2 downto 0) ) return std_logic_vector is
		variable v_seg : std_logic_vector(5 downto 0);
	begin
		v_seg := r_seg;
		if v_seg(conv_integer(r_set_seg)) = '0' then
			v_seg(conv_integer(r_set_seg)) := r_set_stts;
		end if;
		return ("11" & v_seg);
	end f_set_shift;
begin
	out_seg_leds <= r_seg_leds;
	out_seg <= f_set_shift(r_seg, r_set_stts, r_set_seg);
	process(in_clk, in_rst)
	begin
		if in_rst = '1' then
			r_set_cnt <= 0;
			r_set_stts <= '0';
		elsif rising_edge(in_clk) then
			if r_set = '1' then
				if r_set_cnt = (SYS_FREQ / 2) - 1 then
					r_set_cnt <= 0;
					r_set_stts <= not r_set_stts;
					r_set_cnt <= r_set_cnt + 1;
				end if;
				r_set_cnt <= 0;
				r_set_stts <= '0';
			end if;
		end if;
	end process;
	begin
			r_inc_seg <= (others => '0');
			if r_inc_cntrl(2 downto 1) = "01" then
				r_inc_seg(5 - conv_integer(r_set_seg)) <= '1';
			end if;
		end if;
	end process;
	begin
			r_inc_cntrl <= (others=> '0');
			r_inc_cntrl <= r_inc_cntrl(1 downto 0) &  in_inc;
		end if;
	end process;
	begin
			r_seg <= "011111";
			r_set_chk <= "111111";
			if r_seg_pulse = '1' then
				r_seg <= r_seg(4 downto 0) & r_seg(5);
			end if;
		end if;
	end process;
	begin
			r_set_seg <= (others => '0');
			if r_chng_cntrl(2 downto 1) = "01" then
				if r_set_seg = 5 then
					r_set_seg <= r_set_seg + 1;
				end if;
			end if;
		end if;
	end process;
	begin
			r_chng_cntrl <= (others=> '0');
			r_chng_cntrl <= r_chng_cntrl(1 downto 0) &  in_chng_seg;
		end if;
	end process;
	begin
			r_seg_cnt <= (others => '0');
			r_bcd <= (others => '0');
				r_bcd <= r_Time_Digits(5 - conv_integer(r_seg_cnt));
				if r_seg_cnt = 5 then
					r_seg_cnt <= r_seg_cnt + 1;
				end if;
			end if;
		end if;
	end process;
	begin
			r_set <= '0';
			if r_set_cntrl(2 downto 1) = "01" then
				r_set <= not r_set;
			end if;
		end if;
	end process;
	begin
			r_set_cntrl <= (others=> '0');
			r_set_cntrl <= r_set_cntrl(1 downto 0) &  in_set;
		end if;
	end process;
	bcd2seven_segment_map : bcd2seven_segment
	Port  map(
		in_bcd => r_bcd,
		out_seven_segment => r_seg_leds
	hour_digit_cntrl_map : hour_digit_cntrl
	Port map (
		in_clk => in_clk,
		in_rst => in_rst,
		in_pulse => r_min_left_pulse,
		in_inc_right => r_inc_seg(1),
		in_inc_left => r_inc_seg(0),
		out_right_digit => r_Time_Digits(1),
		out_left_digit => r_Time_Digits(0)
	min_left_digit : min_sec_digit_cntrl
	Generic map(
		DIGIT_SIZE => 6
	Port map(
		in_clk => in_clk,
		in_rst => in_rst,
		in_pulse => r_min_right_pulse,
		in_inc => r_inc_seg(2),
		out_digit => r_Time_Digits(2),
		out_pulse => r_min_left_pulse
	min_right_digit : min_sec_digit_cntrl
	Generic map(
		DIGIT_SIZE => 10
	Port map(
		in_clk => in_clk,
		in_rst => in_rst,
		in_pulse => r_sec_left_pulse,
		in_inc => r_inc_seg(3),
		out_digit => r_Time_Digits(3),
		out_pulse => r_min_right_pulse
	sec_left_digit : min_sec_digit_cntrl
	Generic map(
		DIGIT_SIZE => 6
	Port map(
		in_clk => in_clk,
		in_rst => in_rst,
		in_pulse => r_sec_right_pulse,
		in_inc => r_inc_seg(4),
		out_digit => r_Time_Digits(4),
		out_pulse => r_sec_left_pulse
	sec_right_digit : min_sec_digit_cntrl
	Generic map(
		DIGIT_SIZE => 10
	Port map(
		in_clk => in_clk,
		in_rst => in_rst,
		in_pulse => r_sec_pulse,
		in_inc => r_inc_seg(5),
		out_digit => r_Time_Digits(5),
		out_pulse => r_sec_right_pulse
	seg_pulse_map : pulse_generator
	generic map(
		FREQ => 10_000
	Port map (
		in_clk => in_clk,
		in_rst => in_rst,
		out_sec_pulse => r_seg_pulse
	one_second_pulse_map : pulse_generator
	generic map(
		FREQ => SYS_FREQ
	Port map (
		in_clk => in_clk,
		in_rst => in_rst,
		out_sec_pulse => r_sec_pulse
end Behavioral;
library IEEE;
entity pulse_generator is
	generic(
	Port (
end pulse_generator;
architecture Behavioral of pulse_generator is
	signal r_cnt : integer := 0;
begin
	out_sec_pulse <= r_sec_pulse;
	begin
			r_cnt<= 0;
			r_sec_pulse <= '0';
			if r_cnt = FREQ - 1 then
				r_sec_pulse <= '1';
				r_cnt<= 0;
				r_sec_pulse <= '0';
				r_cnt <= r_cnt + 1;
			end if;
		end if;
	end process;
end Behavioral;
library IEEE;
entity min_sec_digit_cntrl is
	Generic(
	Port (
end min_sec_digit_cntrl;
architecture Behavioral of min_sec_digit_cntrl is
	signal r_digit : std_logic_vector(3 downto 0) := (others => '0');
	signal r_pulse : std_logic := '0';
begin
	out_digit <= r_digit;
	out_pulse <= r_pulse;
	begin
			r_digit <= (others => '0');
			r_pulse <= '0';
			r_pulse <= '0';
			if in_pulse = '1' then
				if r_digit = DIGIT_SIZE - 1 then
					r_pulse <= '1';
					r_digit <= r_digit + 1;
				end if;
			end if;
			if in_inc = '1' then
				end if;
			end if;
		end if;
	end process;
end Behavioral;
library IEEE;
entity hour_digit_cntrl is
	Port (
end hour_digit_cntrl;
architecture Behavioral of hour_digit_cntrl is
	signal r_right_digit : std_logic_vector(3 downto 0);
	signal r_left_digit : std_logic_vector(3 downto 0);
begin
	out_right_digit <= r_right_digit;
	out_left_digit <= r_left_digit;
	begin
			r_right_digit <= (others => '0');
			r_left_digit <= (others => '0');
				if (r_left_digit /= 2 and r_right_digit = 9) or
				    (r_left_digit = 2 and r_right_digit = 3) then
					if r_left_digit = 2 then
						r_left_digit <= r_left_digit + 1;
					end if;
					r_right_digit <= r_right_digit + 1;
				end if;
			end if;
			if in_inc_right = '1' then
				end if;
			end if;
			if in_inc_left = '1' then
				end if;
			end if;
		end if;
	end process;
end Behavioral;
library IEEE;
entity bcd2seven_segment is
	Port (
end bcd2seven_segment;
architecture Behavioral of bcd2seven_segment is
	signal r_seven_segment : std_logic_vector(7 downto 0) := (others => '0');
begin
	out_seven_segment <= r_seven_segment;
	process(in_bcd)
	begin
		case in_bcd is
			when "0000" =>
				r_seven_segment <= "10000001";
			when "0001" =>
				r_seven_segment <= "11001111";
			when "0010" =>
				r_seven_segment <= "10010010";
			when "0011" =>
				r_seven_segment <= "10000110";
			when "0100" =>
				r_seven_segment <= "11001100";
			when "0101" =>
				r_seven_segment <= "10100100";
			when "0110" =>
				r_seven_segment <= "10100000";
			when "0111" =>
				r_seven_segment <= "10001111";
			when "1000" =>
				r_seven_segment <= "10000000";
			when "1001" =>
				r_seven_segment <= "10000100";
			when others =>
				r_seven_segment <= "00000000";
		end case;
	end process;
end Behavioral;
Firzen
Ellerinize sağlık hocam. Güzel olmuş.
Kararsız...
aydınD
Emeğiniz için tebrikler
Paylasiminiz için teşekkürler
