BS83B08 ile çalışan var mı?
Başlatan merve damar, 20 Ağustos 2019, 16:58:06
merve damar
#15
Alıntı yapılan: RaMu - 22 Ağustos 2019, 13:51:22
//#include "BS83B08-3.h"
yorumu kaldır, muhtemelen "_wctl" o dosyada tanımlıdır,
program derlenirken "_wctl" tanımlı değil diye hata veriyordur şuan.
Öyle bir dosya paylaşılmamış, _wctl'nin Bulunduğu dosya ;
void INCLUDE_ASM(void)
#asm
INCLUDE BS83B08.INC
INCLUDE TKS_HEAD.INC
#endasm
void LOAD_HXT_REFERENCE(void);
void CLEAR_RAM(void);
//;;*SUB. NAME:                                              *
//;;*INPUT    :                                              *
//;;*OUTPUT  :                                              *
//;;*USED REG.:                                              *
//;;*FUNCTION :                                              *
void SYSTEM_INITIAL(void)
#asm
                ;-SYSTEM CLOCK INITIAL
                MOV    A,SystemClock  ;0=8MHz;1=12MHz;2=16MHz;Other=8MHz
                CALL    _SET_SYS_CLK
                ;-WDT INITIAL  -
                MOV    A,11110000B    ;one SEC. time out
                MOV    WCTL,A
                CLR    WDT
                CLR    WDT1
                CLR    WDT2
                ;-RAM INITIAL ---
                ;-CLEAR RAM BANK1
                CLR    BP
                SET    BP.0
                MOV    A,80H
                #endasm
              CLEAR_RAM();
              #asm
                ;-CLEAR RAM BANK0
                CLR    BP
                MOV    A,60H
                #endasm
                CLEAR_RAM();
                #asm
                ;-IO INITIAL  ---
                ;-PA INITIAL
                CLR    PAPU
                CLR    PAC
                CLR    PA
                ;-PB INITIAL
                CLR    PBPU
                CLR    PBC
                CLR    PB
                ;-PC INITIAL
                //CLR    PCPU
                //CLR    PCC
                //CLR    PC
                ;-LIBRARY INITIAL
                ;-LOAD LIBRARY OPTION/THRESHOLD
                #endasm
                LOAD_HXT_REFERENCE();
                #asm
                ;-TKS VARIES INITIAL
                CALL    _TKS_INITIAL
                ;-SET as KEY or IO : 0=KEY 1=IO
                MOV    A,KEY8_KEY1_ATTR
                MOV    _DATA_BUF
[li],A[/li]
                MOV    A,KEY16_KEY9_ATTR
                MOV    _DATA_BUF[1],A
                CALL    _SET_KEY_ATTR
                ;-HXT EDITOR INTERFACE INITIAL
                IFDEF  HXT_IIC_MODE
                CALL    HXT_IIC_INITIAL
                ENDIF
                ;-ENABLE GLOBE INT.
                SET    EMI
                RET
#endasm
//;;*SUB. NAME:                                              *
//;;*INPUT    :                                              *
//;;*OUTPUT  :                                              *
//;;*USED REG.:                                              *
//;;*FUNCTION :                                              *
#define        GlobeOptionA    (CalibrateTime<<4)|KeyDebounce
#define        GlobeOptionB    (MaximumOnTime<<4)|SamplingTime
#define        GlobeOptionC    (PowerOnBalance<<7)|(ReBalance<<6)|(OneKeyActive<<5)|(AutoRSelect<<3)
#asm
                ;-TKS LIBRARY OPTION
                MOV    A,GlobeOptionA
                MOV    _GLOBE_VARIES
[list]
[li],A         [/li]
[/list]
                MOV    A,GlobeOptionB
                MOV    _GLOBE_VARIES[1],A
                MOV    A,GlobeOptionC
                MOV    _GLOBE_VARIES[2],A
                ;-KEY1 THRESHOLD
                MOV    A,Key1Threshold
                MOV    _GLOBE_VARIES[3],A
                ;-KEY2 THRESHOLD
                MOV    A,Key2Threshold
                MOV    _GLOBE_VARIES[4],A
                ;-KEY3 THRESHOLD
                MOV    A,Key3Threshold
                MOV    _GLOBE_VARIES[5],A
                ;-KEY4 THRESHOLD
                MOV    A,Key4Threshold
                MOV    _GLOBE_VARIES[6],A
                ;-KEY5 THRESHOLD
                MOV    A,Key5Threshold
                MOV    _GLOBE_VARIES[7],A
                ;-KEY6 THRESHOLD
                MOV    A,Key6Threshold
                MOV    _GLOBE_VARIES[8],A
                ;-KEY7 THRESHOLD
                MOV    A,Key7Threshold
                MOV    _GLOBE_VARIES[9],A
                ;-KEY8 THRESHOLD
                MOV    A,Key8Threshold
                MOV    _GLOBE_VARIES[10],A
                ;-KEY9 THRESHOLD
                MOV    A,Key9Threshold
                MOV    _GLOBE_VARIES[11],A
                ;-KEY10 THRESHOLD
                MOV    A,Key10Threshold
                MOV    _GLOBE_VARIES[12],A
                ;-KEY11 THRESHOLD
                MOV    A,Key11Threshold
                MOV    _GLOBE_VARIES[13],A
                ;-KEY12 THRESHOLD
                MOV    A,Key12Threshold
                MOV    _GLOBE_VARIES[14],A
                ;-KEY13 THRESHOLD
                MOV    A,Key13Threshold
                MOV    _GLOBE_VARIES[15],A
                ;-KEY14 THRESHOLD
                MOV    A,Key14Threshold
                MOV    _GLOBE_VARIES[16],A
                ;-KEY15 THRESHOLD
                MOV    A,Key15Threshold
                MOV    _GLOBE_VARIES[17],A
                ;-KEY16 THRESHOLD
                MOV    A,Key16Threshold
                MOV    _GLOBE_VARIES[18],A
                RET
#endasm
//;;*SUB. NAME:                                              *
//;;*INPUT    :                                              *
//;;*OUTPUT  :                                              *
//;;*USED REG.:                                              *
//;;*FUNCTION :                                              *
#asm
                MOV    MP1,A
                CLR    IAR1
                INCA    MP1
                SNZ    Z
                JMP    $-4
                RET
  #endasm
