MCP6V76 Serisi Yeni bir opamp daha
Başlatan M.Salim GÜLLÜCE, 24 Nisan 2020, 01:09:54
Microchip tarafından imal edilen..
170 μA, 2 MHz Zero-Drift Op Amps
Başlığıyla lanse ettiği Çip.
Features
•  High DC Precision:
-VOS Drift: ±150 nV/°C (maximum)
-VOS: ±25 μV (maximum)
-AOL: 111 dB (minimum, VDD = 5.5V)
-PSRR: 110 dB (minimum, VDD = 5.5V)
-CMRR: 112 dB (minimum, VDD = 5.5V)
-Eni: 0.45 μVP-P (typical), f = 0.1 Hz to 10 Hz
-Eni: 0.15 μVP-P (typical), f = 0.01 Hz to 1 Hz
•  Enhanced EMI Protection:
-  Electromagnetic Interference Rejection Ratio (EMIRR) at 1.8 GHz: 96 dB
•  Low Power and Supply Voltages:
-IQ: 170 μA/amplifier (typical)
-  Wide Supply Voltage Range: 2V to 5.5V
•  Small Packages:
-  Singles in SC70, SOT-23
-  Duals in MSOP-8, 2x3 TDFN
-  Quads in TSSOP-14
•Easy to Use:
-  Rail-to-Rail Input/Output
-  Gain Bandwidth Product: 2 MHz (typical)
-  Unity Gain Stable
•  Extended Temperature Range:
 -40°C to +125°C
Typical Applications
•  Portable Instrumentation
•  Sensor Conditioning
•  Temperature Measurement
•  DC Offset Correction
•  Medical Instrumentation
MCP6V76-Family-Data-Sheet-DS20006323B.pdf
tekosis
beş-on seneye ideal opampı satmaya başlayacaklar :)
