1.5A Low-Voltage µCAP LDO
Başlatan M.Salim GÜLLÜCE, 04 Şubat 2021, 17:30:26
1.5 Volttan 3.3 Volta kadar sabit çıkışlı..
1.24 Volttan 5.5 Volta kadar Ayarlı çıkışlı..
Çok küçük Seramik kapasitörlerle çalışan regülatörler..
Features:
•  1.5A Minimum Guaranteed Output Current
•  500 mV Maximum Dropout Voltage over Temperature
   -Ideal for 3.0V to 2.5V Conversion
   -Ideal for 2.5V to 1.8V, 1.65V, or 1.5V Conversion
•  Stable with Ceramic or Tantalum Capacitor
•  Wide Input Voltage Range
   -VIN: 2.25V to 6.0V
•  ±1.0% Initial Output Tolerance
•  Fixed and Adjustable Output Voltages
   -MIC37150: 3-Lead S-Pak Fixed Voltages
   -MIC37151: 5-Lead S-Pak Fixed Voltages with Flag
   -MIC37152: 5-Lead S-Pak or 8-Lead SOIC Adjustable Voltage
   -MIC37153: 8-Lead ePad SOIC Adjustable Voltage with Flag
•  Excellent Line and Load Regulation Specifications
•  Logic Controlled Shutdown
•  Thermal Shutdown and Current-Limit Protection
•  Reverse-Leakage Protection
•  Low Profile 3- or 5-Lead S-Pak Packages or 8-Lead ePad SOIC
Applications:
•  LDO Linear Regulator for Low-Voltage Digital IC
•  PC Add-In Cards
•  High Efficiency Linear Power Supplies
•  SMPS Post Regulator
•  Battery Charger
https://ww1.microchip.com/downloads/en/DeviceDoc/MIC37150-1-2-3-1.5A-Low-Voltage-Microcap-LDO-Regulators-DS20006491A.pdf
