MAX7219 DP AKTİF ETME
Başlatan alfurkan1064, 09 Mart 2021, 23:05:01
alfurkan1064
Merhabalar max7219 ile sürülen digitlerin dp lerini nasıl aktif edebilirim ?
Not:Normal olarak çalıştırabiliyoırum sadece dp(.) pinlerini aktif edemiyorum.
Max7219 Kütüphanesi:
* Chip        : MAX7219
* Author      : Burak HANÇERLİ
* Mail        : bhancerli@gmail.com
* Description : MAX7219 LED Display Driver Routines - v1.1
*  The Maxim MAX7219 is a led display driver. It can control up to 64 individual leds or eight
*  7-segment-display.
*  Max7912 uses 3-wire to communicate with microcontroller.
*    - DATA   : Used to transmit data.
*    - CLOCK  : Used to generate clock signal which is required for transmitting each bite of data.
*    - LOAD   : Used to load data to the Max7913's Dual-Port SRam.
*  DESCRIPTION OF USER FUNCTIONS
*  init7219()                      : Required for initialize MAX7219. This function have has to be called before calling any function.
*  write7219(digit, data)          : Writes data to the specified digit number. If Decimal Point needed on any digit, just add
                                     128 to the data.
                                     For example : write7219(1,3)   = writes "3"  to first digit.
                                                   write7219(1,131) = writes "3." to first digit.
*  shutdown7219(operatingMode)     : Set operatingMode = 0 to Shutdown mode
*                                    Set operatingMode = 1 to Normal mode
*  decode7219(decodeMode)          : Sets digit-decode mode. code-B or no-decode mode. Look up datasheet for detailed instructions.
*                                    For example, if user sets decodeMode = 4, (4=0b00000100), then 3. digit will be
*                                    decoded as code-B algorithm, but other pins don't have any decode mode.
*  brightness7219(brightnessLevel) : Sets brightness level of digits.
*                                    brightnessLevel = 0  ; minimum brightness level
*                                    brightnessLevel = 15 ; maximum brigthness level
*  scanLimit7219(totalDigitNumber) : Sets number of connected digits to the MAX7219. When init7912() function is called,
                                     number of digit will be setted to 4 as default.
*  test7219(testMode)              : Sets 7-segment-display test-mode on or off.
                                     testMode = 0 ; normal operation mode
                                     testMode = 1 ; display test mode
** THIS LIBRARY CAN BE USED, DEVELOPED OR SHARED WITH REFERRING THE AUTHOR.
// CONSTANTS //
// - Connection Pins (CHANGE THESE PINS AS YOU WISH)
#define CLK       pin_D7
#define LOAD      pin_D6
#define SEND_DATA pin_D5
// - Mode Selection
#define decode 0x09
#define brightness 0x0A
#define scanLimit 0x0B
#define shutDown 0x0C
#define dispTest 0x0F
// Firt 4 bites (not used generally)
#define firstBites 0x0
// Wait function
#define wait delay_ms(1)
long serialData=0;
void clock7219() // clock (CLK) pulse
   output_low(CLK);
   wait;
   output_high(CLK);
void load7219()  // load (LOAD) pulse
   output_low(LOAD);
   wait;
   output_high(LOAD);
void send7219(long data) // send 16 bit data word to the 7219
   int count;
   for (count=0; count<16; ++count)
      output_bit(SEND_DATA, shift_left(&data,2,0)); // set data (DIN) level
      clock7219(); // clock data in
   load7219(); // latch the last 16 bits clocked
void dataMaker(byte mode, int dataIncoming) // Standart data package function
   serialData=firstBites;
   serialData<<=4;
   serialData|=mode;
   serialData<<=8;
   serialData|=dataIncoming;
   send7219(serialData);
void write7219(byte digit, int data) // Send data to digits
   dataMaker(digit, data);
void shutdown7219(int operatingMode)
   dataMaker(shutDown,operatingMode);
void decode7219(int decodeMode)
   dataMaker(decode, decodeMode);
void brightness7219(int brightnessLevel)
   dataMaker(brightness, brightnessLevel);
void scanLimit7219(int totalDigitNumber)
   dataMaker(scanLimit, totalDigitNumber);
void test7219(int testMode)
   dataMaker(dispTest, testMode);
void init7219()
   dataMaker(shutDown, 1);     // No-Shutdown mode. Normal Operation mode.
   dataMaker(decode, 0xFF);      // All digits are programmed as code-B decode mode.
   dataMaker(scanLimit, 7);    // Total digit number set to 4.
   dataMaker(brightness, 15);  // Full brightness.
CCS C Kodu
write7219(1, (hedef_1%100)/10);
write7219(2, hedef_1%10);
write7219(2, (hedef_1%10) + 0x80);
alfurkan1064
Alıntı yapılan: mehmet - 11 Mart 2021, 13:40:12
Mehmet hocam ilginize teşekkür ederim,
Kütüphane içerisindede açıklaması mevcutmuş
                                     128 to the data.
Lakin şuanda Max7219 ile bu kütüphane üzerinden Harf yazmakta problem yaşıyorum örneğin E harfini yazmak istiyorum Ortak Katot Ekranda :0x79 olması gerekiyor lakin bu hexi ekrana gönderdiğimde saçma bir karakter gösteriyor E'nin karşılıgı :0X7B olarak çıkıyor,bu konuda yardımınızı bekliyorum hocam.
Saygılarımla.
MAX7219 datasheet in 8 . sayfasında 0X0B gönderilmesi gerektiğini söylüyor, yani %xxxx1011 (0X0B) ile %01111011 (0x7B) arasında bir fark olmamış oluyor bu durumda çünkü 4,5,6 ıncı bitler sonucu değiştirmiyor. Muhtemelen decode modunu Code-B olarak kullanıyorsunuz.
alfurkan1064
Alıntı yapılan: yas - 11 Mart 2021, 21:59:55MAX7219 datasheet in 8 . sayfasında 0X0B gönderilmesi gerektiğini söylüyor, yani %xxxx1011 (0X0B) ile %01111011 (0x7B) arasında bir fark olmamış oluyor bu durumda çünkü 4,5,6 ıncı bitler sonucu değiştirmiyor. Muhtemelen decode modunu Code-B olarak kullanıyorsunuz.
Alıntı yapılan: mehmet - 12 Mart 2021, 01:23:33"E" -> 11
İlginize teşekkür ederim decode modlu ve modsuz olarak kullanıyorum,decode modsuz istediğim değerleri veriyor lakin decode modunda istediğim harfi nasıl yazabilirim ? H-E-L-P- - Dışında örneğin "r"  örnek olarak dediğime bakmayın direk mantığını öğrenmek benim için daha yararlı olur.
Saygılarmla.
Decode 0 için karakter tablosunu
kendiniz oluşturacaksınız.
decode7219(0x00);
write7219(0, 0xFF); // ilk haneye 8. yazması gerekir
