I2C Master Mode DMA Kullanımı
Başlatan robikod, 02 Temmuz 2021, 18:26:27
robikod
Eeproma yazmak için normal moddan DMA moduna geçtim, normal modda gayet başarılı çalışırken, DMA modunda bir yerde takılıyor. Stm32f4 kullanıyorum ve kodlarım şu şekilde:
 if(hi2c->Instance==I2C1)
/* USER CODE BEGIN I2C1_MspInit 0 */
  /* USER CODE END I2C1_MspInit 0 */
__HAL_RCC_GPIOB_CLK_ENABLE();
/**I2C1 GPIO Configuration
    PB6     ------> I2C1_SCL
    PB7     ------> I2C1_SDA
GPIO_InitStruct.Pin GPIO_PIN_6|GPIO_PIN_7;
GPIO_InitStruct.Mode GPIO_MODE_AF_OD;
GPIO_InitStruct.Pull GPIO_PULLUP;
GPIO_InitStruct.Speed GPIO_SPEED_FREQ_VERY_HIGH;
GPIO_InitStruct.Alternate GPIO_AF4_I2C1;
HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
/* Peripheral clock enable */
__HAL_RCC_I2C1_CLK_ENABLE();
/* I2C1 DMA Init */
    /* I2C1_RX Init */
hdma_i2c1_rx.Instance DMA1_Stream0;
hdma_i2c1_rx.Init.Channel DMA_CHANNEL_1;
hdma_i2c1_rx.Init.Direction DMA_PERIPH_TO_MEMORY;
hdma_i2c1_rx.Init.PeriphInc DMA_PINC_DISABLE;
hdma_i2c1_rx.Init.MemInc DMA_MINC_ENABLE;
hdma_i2c1_rx.Init.PeriphDataAlignment DMA_PDATAALIGN_BYTE;
hdma_i2c1_rx.Init.MemDataAlignment DMA_MDATAALIGN_BYTE;
hdma_i2c1_rx.Init.Mode DMA_NORMAL;
hdma_i2c1_rx.Init.Priority DMA_PRIORITY_LOW;
hdma_i2c1_rx.Init.FIFOMode DMA_FIFOMODE_DISABLE;
    if (
HAL_DMA_Init(&hdma_i2c1_rx) != HAL_OK)
Error_Handler();
__HAL_LINKDMA(hi2c,hdmarx,hdma_i2c1_rx);
/* I2C1_TX Init */
hdma_i2c1_tx.Instance DMA1_Stream7;
hdma_i2c1_tx.Init.Channel DMA_CHANNEL_1;
hdma_i2c1_tx.Init.Direction DMA_MEMORY_TO_PERIPH;
hdma_i2c1_tx.Init.PeriphInc DMA_PINC_DISABLE;
hdma_i2c1_tx.Init.MemInc DMA_MINC_ENABLE;
hdma_i2c1_tx.Init.PeriphDataAlignment DMA_PDATAALIGN_BYTE;
hdma_i2c1_tx.Init.MemDataAlignment DMA_MDATAALIGN_BYTE;
hdma_i2c1_tx.Init.Mode DMA_NORMAL;
hdma_i2c1_tx.Init.Priority DMA_PRIORITY_LOW;
hdma_i2c1_tx.Init.FIFOMode DMA_FIFOMODE_DISABLE;
    if (
HAL_DMA_Init(&hdma_i2c1_tx) != HAL_OK)
Error_Handler();
__HAL_LINKDMA(hi2c,hdmatx,hdma_i2c1_tx);
/* I2C1 interrupt Init */
HAL_NVIC_SetPriority(I2C1_EV_IRQn00);
HAL_NVIC_EnableIRQ(I2C1_EV_IRQn);
HAL_NVIC_SetPriority(I2C1_ER_IRQn00);
HAL_NVIC_EnableIRQ(I2C1_ER_IRQn);
/* USER CODE BEGIN I2C1_MspInit 1 */
  /* USER CODE END I2C1_MspInit 1 */
Aşağıdaki kodda, HAL_I2C_Master_Transmit_DMA çağırdıktan sonra fonksiyonun içerisinden HAL_OK olarak çıkıyor ancak hemen I2C1_EV_IRQHandler içerisinde loopta kalıyor bu interruptan çıkamıyor. Bu neden olabilir ? Nasıl çözebilirim?
     while (HAL_I2C_GetState(hi2c) != HAL_I2C_STATE_READY)
errorCode HAL_I2C_Master_Transmit_DMA(hi2c, (uint16_t)deviceAddress, (uint8_t*)dataArray2);
      if(
errorCode != HAL_OK)
// print("%d",errorCode);
robikod
Bu konuda yardımcı olabilecek yok mu ?
Cemre.
Bu konu ST community forumunda da konuşulmuş. Hatta bug fix geçilmiş gözüküyor.
Tavsiye olarak CubeMX kütüphane paketlerini güncellemek ve proje ayarlarından en güncel kütüphaneyi kullanacak şekilde ayarlamak önerilebilir. Denemekte fayda var.
https://community.st.com/s/question/0D50X0000BTcGDf/bug-report-fix-hal-i2c-interrupt-handler-not-working
mr.engineer
ST'lerin bazı I2C modüllerinde problem olduğu söyleniyordu. Hala devam ediyor galiba sorun
Yasal Uyarı: Picproje.org sitemizde 5651 sayılı kanunun 8. maddesine ve T.C.Knın 125. maddesine göre tüm üyelerimiz yaptıkları paylaşımlardan kendileri sorumludur. Picproje.org hakkında yapılacak tüm hukuksal şikayetleri İletişim sayfamızdan bize bildirdikten en geç 3 (üç) iş günü içerisinde ilgili kanunlar ve yönetmelikler çerçevesinde tarafımızca incelenerek gereken işlemler yapılacak ve site yöneticilerimiz tarafından bilgi verilecektir.
