Satılık SMD Komponentler
Başlatan yusuffyk, 06 Ekim 2021, 19:59:36
yusuffyk
Merhabalar,
Proje fazlası olarak aşağıdaki ürünleri satmaktayım.
İlgilenenler yusuffyk@gmail.com mail adresi ile iletişime geçebilirler.
Ücret belirtmiyorum, tekliflere açığım.
Ürünler sıfırdır.
Ürün Kodu   Açıklama   Adet
STM32F103VCT6    IC MCU 32BIT 256KB FLASH 100LQFP   32
STM32F103VBT6   IC MCU 32BIT 128KB FLASH 100LQFP   6
STM32F103VFT6    IC MCU 32BIT 768KB FLASH 100LQFP   16
STM32F030K6T6    IC MCU 32BIT 32KB FLASH 32LQFP   19
ENC28J60T-I/SS   IC ETHERNET CTLR SPI 28SSOP   30
ACS722llCTR-10AU-T   SENSOR CURRENT HALL 10A DC   70
08B0-1X1T-06-F   CONN JACK 1PORT 100 BASE-T PCB   4,47
G2R-1-SNDI DC12(S)   RELAY GEN PURPOSE SPDT 10A 12V   145
HLSR 10-SM/SP33   SENSOR CURRENT HALL 10A AC/DC   48
UWT1H221MNL1GS    CAP ALUM 220UF 20% 50V SMD   300
H11L1SR2M   OPTOISO 4.17KV OPN COLL 6SMD   160
TAJT106M016RNJ   CAP TANT 10UF 20% 16V 1411   50
114-00841-68   CONN MICRO SD CARD PUSH-PULL R/A   40
UWT1C471MNL1GS   CAP ALUM 470UF 20% 16V SMD   70
BC817-40Q-13-F   TRANS NPN 45V 500MA SOT23   500
CBC3225T100MR   FIXED IND 10UH 900MA 172.9 MOHM   280
PDS1-S3-S3-M-TR   DC DC CONVERTER 3.3V 1W   40
NDS356AP   MOSFET P-CH 30V 1.1A SUPERSOT3   100
ES1B   DIODE GEN PURP 100V 1A SMA   250
EEE-1EA330WR   CAP ALUM 33UF 20% 25V SMD   160
S2M(S2MFSTR-ND)   DIODE GEN PURP 1KV 2A DO214AA   100
S1B(S1BFSTR-ND)   DIODE GEN PURP 100V 1A SMA   100
B32021A3103M289   CAP FILM 10000PF 20% 1.5KVDC RAD   80
B88069X6771T902   GDT 75V 10KA 3 POLE SMD   35
S8401-46   BATTERY HOLDER COIN 20MM PC PIN   18
865060457009   CAP ALUM 470UF 20% 25V SMD   20
ABLS-25.000MHZ-B2F-T   CRYSTAL 25.0000MHZ 18PF SMD   40
EDK227M035A9MAA   CAP ALUM 220UF 20% 35V SMD   20
RN112-0.4-02-39M   CMC 39MH 400MA 2LN TH   30
BS-7(BS-7-ND)   BATTERY HOLDER COIN 20MM PC PIN   20
UWX1C101MCL1GB   CAP ALUM 100UF 20% 16V SMD   85
LM22676MR-ADJ/NOPB   LM22676 SIMPLE SWITCHER 4.5V TO   20
MOC3021S   OPTOISOLATOR 5KV TRIAC 6SMD   80
AOZ1282CI   IC REG BUCK ADJ 1.2A SOT23-6   20
FDLL4148   DIODE GEN PURP 100V 200MA SOD80   500
TSM680P06CP ROG   MOSFET P-CHANNEL 60V 18A TO252   30
NCS20072DR2G   IC OPAMP GP 2 CIRCUIT 8SOIC   250
NCP1117DT33G   IC REG LINEAR 3.3V 1A DPAK   50
610010243021   Socket Header   96
610016243021   Socket Header   120
610004243021   Socket Header   116
http://yusuffyk.com  ||  http://www.youtube.com/yusuffyk
