Ağ lazer yazıcı Ricoh Sp1210N reset nasıl yapılır.
Başlatan rree, 22 Şubat 2022, 10:30:31
rree
Rex-Rotary  Ricoh Sp1210N veya(Type 1210N) Yazıcının şifresi bilinmiyor. Fabrika ayarlarına nasıl döndürülür? Yazıcı üzerinde resetleme butonu gözükmüyor.
ByTEK
vereceğim linkteki adımları uygulayın.
https://www.manualslib.com/manual/408278/Ricoh-Aficio-Sp-1210n.html?page=59
-Turn off the printer.
-Make sure that the front cover is closed and the power cord is plugged in.
-Hold down the Go button as you turn on the power switch. Keep the Go button pressed down until theToner, Drum and Error LEDs light up. Release the Go button. Make sure that the Toner, Drum and Error LEDs are off.
- Press the Go button seven times. Make sure that all the LEDs light up to indicate the print server hasbeen reset to its default settings
