16 bit çarpım C51 - ASM
Başlatan power20, 11 Ağustos 2022, 10:12:57
16 bit çarpım ve 32 bit sonuç için şöyle bir ASM örnek verilmiş.
https://developer.arm.com/documentation/ka002453/latest
Temel bilgi eksikliğim var ASM kod   ?PR? kısmı sanki yazım hatası gibi. aynen yazdım olmadı
NAME    MULT
?PR?_uint_mult?MULT  SEGMENT CODE
        PUBLIC  _uint_mult
        RSEG  ?PR?_uint_mult?MULT
_uint_mult:
; x stored in R6+R7
; y stored in R4+R5
          mov     a,r7
          mov     b,r5
          mul     ab      ; ab = R7*R5
          mov     r3,b
          xch     a,r7    ; a = R7
          mov     b,r4
          mul     ab      ; ab = R4*R7
          add     a,r3
          mov     r3,a
          mov     a,#0
          addc    a,b
          xch     a,r5    ; a = R5
          mov     b,r6
          mul     ab      ; ab = R5*R6
          add     a,r3
          xch     a,r6
          xch     a,b     ; b = R6
          addc    a,r5
          mov     r5,a
          mov     a,#0
          addc    a,#0
          xch     a,r4
          mul     ab      ; ab = R4*R6
          add     a,r5
          mov     r5,a
          mov     a,b
          addc    a,r4
          mov     r4,a
; Result returned in R4+R5+R6+R7
        RET
        END
Bu örneği C kod içine dahil ederek  kullanmak istiyorum. Nasıl yazacağımı kestiremedim
Şunun içerisine nasıl ekleyebilirim?
C:\Keil_v5\C51\Examples\HELLO
HELLO.C
Copyright 1995-2005 Keil Software, Inc.
#include <REG52.H>                /* special function register declarations   */
                                  /* for the intended 8051 derivative         */
#include <stdio.h>                /* prototype declarations for I/O functions */
#ifdef MONITOR51                         /* Debugging with Monitor-51 needs   */
char code reserve [3] _at_ 0x23;         /* space for serial interrupt if     */
#endif                                   /* Stop Exection with Serial Intr.   */
                                         /* is enabled                        */
The main C function.  Program execution starts
here after stack initialization.
void main (void) {
Setup the serial port for 1200 baud at 16MHz.
#ifndef MONITOR51
    SCON  = 0x50;		        /* SCON: mode 1, 8-bit UART, enable rcvr      */
    TMOD |= 0x20;               /* TMOD: timer 1, mode 2, 8-bit reload        */
    TH1   = 221;                /* TH1:  reload value for 1200 baud @ 16MHz   */
    TR1   = 1;                  /* TR1:  timer 1 run                          */
    TI    = 1;                  /* TI:   set TI to send first char of UART    */
#endif
Note that an embedded program never exits (because
there is no operating system to return to).  It
must loop and execute forever.
  while (1) {
    P1 ^= 0x01;     		    /* Toggle P1.0 each time we print */
    printf ("Hello World\n");   /* Print "Hello World" */
You must prototype this routine in your C code as follows:
unsigned long uint_mult (
  unsigned int x,
  unsigned int y);
main?
unsigned long z;
unsigned int x, y;
unsigned long z1;
for (x = 0; x < 0xFF00; x += 13)
  for (y = 0; y < 0xFF00; y += 17)
    z1 = (unsigned long) x * y;
    z = uint_mult (x, y);
    if (z != z1)
      printf ("0x%4.4X x 0x%4.4X = ", x, y);
      printf ("0x%8.8LX (0x%8.8LX)\n", z, z1);
16 bit iki sayıyı çarparak sonucu gösteren program hazır fakat çalıştıramadım
