ICSP üzerinden brick olan 2560
Başlatan Eugene, 21 Nisan 2019, 03:49:56
Eugene
Arduino UNO'yu ArduinoISP olarak programlayıp 2560'a icsp üzerinden program atıyordum. Ne olduysa son program atarken write bitti read yaparken iletişim koptu dedi. Ardından ne yaptıysam program atamaz oldum. Hep şu hatayı veriyor :
Arduino: 1.8.8 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\c00pER\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/bin/avrdude -CC:\Users\c00pER\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf -v -patmega2560 -carduino -PCOM3 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xD8:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20171130
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\c00pER\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x000000 (retrying)
Reading | ################################################## | 100% 0.01s
Error while burning bootloader.
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
ICSP kablosunu taksam da takmasam da device signature 0x00000. Bağlantılardan şüphelenip başka bir kart denedim sorun yok. Çipi çıkarıp başka bir harici programlayıcıda programlama şansım yok. Yabancı forumlarda fuse ların hatalı olması sebebiyle kart brick olmuş olabilir demişler daha önceki sorulara. Kartı atmadan önce sorayım dedim :(
muhendisbey
Olur arada. Vadesi yetmiş olabilir.
Başka bilgisayarda dene, ISP olarak kullandığın uno'nun bağlantısını test et olmadı başka bir uno ile tekrar dene. Dönerse senindir dönmezse hurdalığın. :(
kaan0
Fuse ayarlarından seri programlama devre dışı bırakılmış olabilir. Bu durumda HVPP (High Voltage Parallel Programming) ile fuse ayarlarını tekrar yapmanız gerekir. HVPP devresi çok zor değil internetten bulabilirsiniz. Reset pinine +12V verilerek yapılıyor. Daha önce yanlış fuse ayarlarıyla seri programlamaya kapattığım bir Atmega328'i HVPP ile kurtarmıştım.
Eugene
Evet HVPP çözüm gibi görünüyor. Peki ICSP oluyor mu sökmek mi gerekiyor? Sökülmesi gerekiyorsa devre yerine 2560 ı da değiştirebilirim.
Alıntı yapılan: kaan0 - 21 Nisan 2019, 13:46:18Fuse ayarlarından seri programlama devre dışı bırakılmış olabilir.
Bildiğim kadarıyla, seri programlama cihazı kullanılarak seri programlama sigortası iptal edilemiyor. Bunu yanlışlıkla cihaz kilitlenmesin diye yapmışlar. Ama her model için geçerli midir bilmiyorum.
kaan0
Alıntı yapılan: Tagli - 21 Nisan 2019, 23:44:13Bildiğim kadarıyla, seri programlama cihazı kullanılarak seri programlama sigortası iptal edilemiyor. Bunu yanlışlıkla cihaz kilitlenmesin diye yapmışlar. Ama her model için geçerli midir bilmiyorum.
Evet hocam üzerinden 3-4 sene geçtiği için tam hatırlayamadım. Sanırım RSTDISBL sigortasını değiştirmiştim o zaman. Bu sigorta değişince seri programlama için reset pinine 12V vermek gerekiyordu diye hatırlıyorum. Seri ve paralel programlayıcı olarak Arduino kullanmıştım.
