HATA MESAJLARI NASIL GİDERİLİR
Başlatan Nisre, 11 Nisan 2008, 17:00:55
Nisre
MERHABA ARKADAŞLAR ;
PROGRAMI MPLAB 8 DE DERLEDİKTEN SONRA AŞAĞIDAKİ HATA MESAJLARINI ALDIM,DERLEDİĞİM KODUDA YOLLUYORUM,BU HATALAR NASIL GİDERİLİR,YARDIMINIZ İÇİN CİDDEN ÇOK TEŞEKKÜRLER,KOLAY GELSİN.
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPAsmWin.exe" /q /p16F628A "enes.asm" /l"enes.lst" /e"enes.err"
Error[113]   C:\PROJE.C\ENES.ASM 4 : Symbol not previously defined (_INTRC_OSC_NOCLOCKOUT)
Error[113]   C:\PROJE.C\ENES.ASM 4 : Symbol not previously defined (_)
Error[112]   C:\PROJE.C\ENES.ASM 4 : Missing operator
Message[302] C:\PROJE.C\ENES.ASM 11 : Register in operand not in bank 0.  Ensure that bank bits are correct.
Message[302] C:\PROJE.C\ENES.ASM 13 : Register in operand not in bank 0.  Ensure that bank bits are correct.
Warning[207] C:\PROJE.C\ENES.ASM 17 : Found label after column 1. (BUTON_TEST)
Error[113]   C:\PROJE.C\ENES.ASM 19 : Symbol not previously defined (BUTONTEST)
Warning[207] C:\PROJE.C\ENES.ASM 21 : Found label after column 1. (DONGU)
Error[122]   C:\PROJE.C\ENES.ASM 23 : Illegal opcode (Deleting)
Error[129]   C:\PROJE.C\ENES.ASM 24 : Expected (END)
Halting build on first failure as requested.
BUILD FAILED: Fri Apr 11 16:18:47 2008
LIST P=16F628A
     INCLUDE "P16F628A.INC"
    __CONFIG  _CP_OFF & _PWRTE_ON & _INTRC_OSC_NOCLOCKOUT & _MCLRE_ON & _BODEN_OFF & _LVP_OFF _ & _DATA_CP_OFF & _WDT_OFF;
      LRF PORTB
      BSF  STATUS,5
      CLRF TRISB
      MOVLW H'FF'
      MOVWF TRISA
      BCF STATUS,5
      MOVLW H'07'
      MOVWF CMCON
BUTON_TEST
      BTFSC PORTA,0
      GOTO BUTONTEST
      BSF      PORTB,0
DONGU
      GOTO DONGU
      END
SpeedyX
LIST P=16F628a
INCLUDE "p16f628a.inc"
__CONFIG _CP_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT & _MCLRE_ON & _BODEN_OFF & _LVP_OFF & _DATA_CP_OFF & _WDT_OFF;
CLRF PORTB
banksel TRISB
CLRF TRISB
MOVLW H'FF'
MOVWF TRISA
banksel CMCON
MOVLW H'07'
MOVWF CMCON
BUTON_TEST
BTFSC PORTA,0
GOTO BUTON_TEST
BSF PORTB,0
GOTO $
END
Dene bakalım
