asm hex çevirme
Başlatan hunterxt41, 12 Haziran 2008, 21:53:50
hunterxt41
arkadaşlar aşağıdaki asm dosyasını nasıl hex e çeviririm.
; PIC16C84 ILE YAPILAN 5*16=80 LED LI KAYAN YAZI DEVRESI ICIN PROGRAMDIR
; 32 KARAKTER KULLANILABILIR
   LIST    P = 16C84,  F = INHX8M, n = 66
       PIC84   equ     H'03FF'
;       Register Definitions
W                            EQU     H'0000'
F                            EQU     H'0001'
;----- Register Files------------------------------------------------------
INDF                         EQU     H'0000'
TMR0                         EQU     H'0001'
PCL                          EQU     H'0002'
STATUS                       EQU     H'0003'
FSR                          EQU     H'0004'
PORTA                        EQU     H'0005'
PORTB                        EQU     H'0006'
EEDATA                       EQU     H'0008'
EEADR                        EQU     H'0009'
PCLATH                       EQU     H'000A'
INTCON                       EQU     H'000B'
OPTION_REG                   EQU     H'0081'
TRISA                        EQU     H'0085'
TRISB                        EQU     H'0086'
EECON1                       EQU     H'0088'
EECON2                       EQU     H'0089'
;----- STATUS Bits --------------------------------------------------------
IRP                          EQU     H'0007'
RP1                          EQU     H'0006'
RP0                          EQU     H'0005'
NOT_TO                       EQU     H'0004'
NOT_PD                       EQU     H'0003'
Z                            EQU     H'0002'
DC                           EQU     H'0001'
C                            EQU     H'0000'
;----- INTCON Bits --------------------------------------------------------
GIE                          EQU     H'0007'
EEIE                         EQU     H'0006'
T0IE                         EQU     H'0005'
INTE                         EQU     H'0004'
RBIE                         EQU     H'0003'
T0IF                         EQU     H'0002'
INTF                         EQU     H'0001'
RBIF                         EQU     H'0000'
;----- OPTION Bits --------------------------------------------------------
NOT_RBPU                     EQU     H'0007'
INTEDG                       EQU     H'0006'
T0CS                         EQU     H'0005'
T0SE                         EQU     H'0004'
PSA                          EQU     H'0003'
PS2                          EQU     H'0002'
PS1                          EQU     H'0001'
PS0                          EQU     H'0000'
;----- EECON1 Bits --------------------------------------------------------
EEIF                         EQU     H'0004'
WRERR                        EQU     H'0003'
WREN                         EQU     H'0002'
WR                           EQU     H'0001'
RD                           EQU     H'0000'
;       RAM Definition
       __MAXRAM H'AF'
       __BADRAM H'07', H'30'-H'7F', H'87'
;       Configuration Bits
_CP_ON                       EQU     H'3FEF'
_CP_OFF                      EQU     H'3FFF'
_PWRTE_ON                    EQU     H'3FFF'
_PWRTE_OFF                   EQU     H'3FF7'
_WDT_ON                      EQU     H'3FFF'
_WDT_OFF                     EQU     H'3FFB'
_LP_OSC                      EQU     H'3FFC'
_XT_OSC                      EQU     H'3FFD'
_HS_OSC                      EQU     H'3FFE'
_RC_OSC                      EQU     H'3FFF'
;----------- USER REGISTERS ----------------------------------------------
POINTER                      EQU     H'000C'
HCOUNT                       equ     H'000D'
LCOUNT              equ     H'000E'
TEMP1                        EQU     H'002B'
TEMP2                        EQU     H'002C'
TEMP3                        EQU     H'002D'
ZAMAN                        equ     H'002E'
DISP                         EQU     H'002F'
msb             equ     0x29            ;general delay register
lsb             equ     0x2A            ;general delay register
FLCOUNT         equ     H'0027'         ;flas counter
WAITC           equ     H'0026'         ;wait and run
SPECIAL         equ     H'0025'          ;special function register
COUNT1          equ     H'0022'         ;system timer counter
COUNT2          equ     H'0021'         ;system flas timer counter
SYSFUNC         equ     H'0020'         ;system control register
LINE1           EQU     H'0010'
LINE2           EQU     H'0011'
LINE3           EQU     H'0012'
LINE4           EQU     H'0013'
LINE5           EQU     H'0014'
LINE6           EQU     H'0015'
LINE7           EQU     H'0016'
LINE8           EQU     H'0017'
LINE9           EQU     H'0018'
LINE10          EQU     H'0019'
LINE11          EQU     H'001A'
LINE12          EQU     H'001B'
LINE13          EQU     H'001C'
LINE14          EQU     H'001D'
LINE15          EQU     H'001E'
LINE16          EQU     H'001F'
SATIRLAR        EQU     H'0023'
; Display organization
ZERO    EQU     B'00111111'
ONE     EQU     B'00000110'
TWO     EQU     B'01011011'
THREE   EQU     B'01001111'
FOUR    EQU     B'01100110'
FIVE    EQU     B'01101101'
SIX     EQU     B'01111101'
SEVEN   EQU     B'00000111'
EIGHT   EQU     B'01111111'
NINE    EQU     B'01101111'
BLANK   EQU     B'00000000'
DISP1   equ   B'11111110'
DISP2   equ   B'11111101'   ; Mapping of Active Display Selection (PORT_A)
;DISP3   equ     B'11111011'
;DISP4   equ     B'11110111'
DISPOFF   equ   H'FF'
SWITCH   equ   B'00001110'   ; Activate RB1-3 for switch inputs
START
       call    SETCPUPORTSTATUS
       call    STEP_CLEAR
KAYANYAZI_1
        MOVLW  H'0000'
        MOVWF  SATIRLAR
KAYANYAZI_2
       INCFSZ  SATIRLAR
       GOTO    KAYANYAZI_3
       GOTO    KAYANYAZI_4
KAYANYAZI_3
       goto    KAYANYAZI_5
KAYANYAZI_4
       goto    KAYANYAZI_1
KAYANYAZI_5
       MOVLW   H'00'
       ADDWF   SATIRLAR,0
       CALL    FINDSHOW
       movwf   LINE1
       MOVLW   H'01'
       ADDWF   SATIRLAR,0
       CALL    FINDSHOW
       movwf   LINE2
       MOVLW   H'02'
       ADDWF   SATIRLAR,0
       CALL    FINDSHOW
       movwf   LINE3
       MOVLW   H'03'
       ADDWF   SATIRLAR,0
       CALL    FINDSHOW
       movwf   LINE4
       MOVLW   H'04'
       ADDWF   SATIRLAR,0
       CALL    FINDSHOW
       movwf   LINE5
       MOVLW   H'05'
       ADDWF   SATIRLAR,0
       CALL    FINDSHOW
       movwf   LINE6
       MOVLW   H'06'
       ADDWF   SATIRLAR,0
       CALL    FINDSHOW
       movwf   LINE7
       MOVLW   H'07'
       ADDWF   SATIRLAR,0
       CALL    FINDSHOW
       movwf   LINE8
       MOVLW   H'08'
       ADDWF   SATIRLAR,0
       CALL    FINDSHOW
       movwf   LINE9
       MOVLW   H'09'
       ADDWF   SATIRLAR,0
       CALL    FINDSHOW
       movwf   LINE10
       MOVLW   H'0A'
       ADDWF   SATIRLAR,0
       CALL    FINDSHOW
       movwf   LINE11
       MOVLW   H'0B'
       ADDWF   SATIRLAR,0
       CALL    FINDSHOW
       movwf   LINE12
       MOVLW   H'0C'
       ADDWF   SATIRLAR,0
       CALL    FINDSHOW
       movwf   LINE13
       MOVLW   H'0D'
       ADDWF   SATIRLAR,0
       CALL    FINDSHOW
       movwf   LINE14
       MOVLW   H'0E'
       ADDWF   SATIRLAR,0
       CALL    FINDSHOW
       movwf   LINE15
       MOVLW   H'0F'
       ADDWF   SATIRLAR,0
       CALL    FINDSHOW
       movwf   LINE16
       MOVLW   D'15'
       MOVWF   ZAMAN
       CALL    STEP_DELAY
       goto    KAYANYAZI_2
;        org     h'0100'
FINDSHOW
;KIRIKKALE ENDUSTRI MESLEK LISESI ELEKTRONIK BOLUMU
showdata
       addwf   PCL,1
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00011111'     ;
       retlw   B'00010101'     ;
       retlw   B'00010101'     ;
       retlw   B'00010001'     ;
       retlw   B'00000000'     ;       E
       retlw   B'00011111'     ;
       retlw   B'00000010'     ;
       retlw   B'00000100'     ;
       retlw   B'00011111'     ;
       retlw   B'00000000'     ;       N
       retlw   B'00011111'     ;
       retlw   B'00010001'     ;
       retlw   B'00010001'     ;
       retlw   B'00001110'     ;
       retlw   B'00000000'     ;       D
       retlw   B'00001101'     ;
       retlw   B'00010000'     ;
       retlw   B'00010000'     ;
       retlw   B'00001101'     ;
       retlw   B'00000000'     ;       ü
       retlw   B'00010010'     ;
       retlw   B'00010101'     ;
       retlw   B'00001001'     ;
       retlw   B'00000000'     ;       S
       retlw   B'00000001'     ;
       retlw   B'00000001'     ;
       retlw   B'00011111'     ;
       retlw   B'00000001'     ;
       retlw   B'00000001'     ;
       retlw   B'00000000'     ;       T
       retlw   B'00011111'     ;
       retlw   B'00000101'     ;
       retlw   B'00001101'     ;
       retlw   B'00010010'     ;
       retlw   B'00000000'     ;       R
       retlw   B'00011101'     ;
       retlw   B'00000000'     ;       i
       retlw   B'00000001'     ;
       retlw   B'00000010'     ;
       retlw   B'00011100'     ;
       retlw   B'00000010'     ;
       retlw   B'00000001'     ;
       retlw   B'00000000'     ;       Y
       retlw   B'00011111'     ;
       retlw   B'00010101'     ;
       retlw   B'00010101'     ;
       retlw   B'00010001'     ;
       retlw   B'00011111'     ;
       retlw   B'00010000'     ;
       retlw   B'00010000'     ;
       retlw   B'00010000'     ;
       retlw   B'00000000'     ;       L
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00011111'     ;
       retlw   B'00010101'     ;
       retlw   B'00010101'     ;
       retlw   B'00010001'     ;
       retlw   B'00011111'     ;
       retlw   B'00010000'     ;
       retlw   B'00010000'     ;
       retlw   B'00010000'     ;
       retlw   B'00011111'     ;
       retlw   B'00010101'     ;
       retlw   B'00010101'     ;
       retlw   B'00010001'     ;       E
       retlw   B'00000000'     ;
       retlw   B'00011111'     ;
       retlw   B'00000100'     ;
       retlw   B'00001010'     ;
       retlw   B'00010001'     ;
       retlw   B'00000000'     ;       K
       retlw   B'00000001'     ;
       retlw   B'00000001'     ;
       retlw   B'00011111'     ;
       retlw   B'00000001'     ;
       retlw   B'00000001'     ;
       retlw   B'00011111'     ;
       retlw   B'00000101'     ;
       retlw   B'00001101'     ;
       retlw   B'00010010'     ;
       retlw   B'00001110'     ;
       retlw   B'00010001'     ;
       retlw   B'00010001'     ;
       retlw   B'00001110'     ;
       retlw   B'00000000'     ;       O
       retlw   B'00011111'     ;
       retlw   B'00000010'     ;
       retlw   B'00000100'     ;
       retlw   B'00011111'     ;
       retlw   B'00011101'     ;
       retlw   B'00011111'     ;
       retlw   B'00000100'     ;
       retlw   B'00001010'     ;
       retlw   B'00010001'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00011111'     ;
       retlw   B'00010101'     ;
       retlw   B'00010101'     ;
       retlw   B'00001010'     ;       B
       retlw   B'00000000'     ;
       retlw   B'00001101'     ;
       retlw   B'00010010'     ;
       retlw   B'00010010'     ;
       retlw   B'00001101'     ;
       retlw   B'00000000'     ;       ö
       retlw   B'00011111'     ;
       retlw   B'00010000'     ;
       retlw   B'00010000'     ;
       retlw   B'00010000'     ;
       retlw   B'00001101'     ;
       retlw   B'00010000'     ;
       retlw   B'00010000'     ;
       retlw   B'00001101'     ;
       retlw   B'00011111'     ;
       retlw   B'00000010'     ;
       retlw   B'00000100'     ;
       retlw   B'00000010'     ;
       retlw   B'00011111'     ;
       retlw   B'00000000'     ;       M
       retlw   B'00001101'     ;
       retlw   B'00010000'     ;
       retlw   B'00010000'     ;
       retlw   B'00001101'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
       retlw   B'00000000'     ;
return
STEP_CLEAR
       movlw   B'00000000'
       movwf   LINE1
       movwf   LINE2
       movwf   LINE3
       movwf   LINE4
       movwf   LINE5
       movwf   LINE6
       movwf   LINE7
       movwf   LINE8
       movwf   LINE9
       movwf   LINE10
       movwf   LINE11
       movwf   LINE12
       movwf   LINE13
       movwf   LINE14
       movwf   LINE15
       movwf   LINE16
       MOVLW   D'50'
       MOVWF   ZAMAN
       CALL    STEP_DELAY
RETURN
STEP_DELAY
       clrwdt
      ; call    DELAYSYS                        ;20 msec delay
       CALL    RUNTIME
       decfsz  ZAMAN
       goto    STEP_DELAY
return
RUNTIME
WRITEDISP
       ;test
       ;call    delay20
       ;test
       clrwdt
       movlw   D'0'
       movwf   PORTA
       movf    LINE1,0
       movwf   PORTB
       call    delay1
       clrwdt
       movlw   D'1'
       movwf   PORTA
       movf    LINE2,0
       movwf   PORTB
       call    delay1
       clrwdt
       movlw   D'2'
       movwf   PORTA
       movf    LINE3,0
       movwf   PORTB
       call    delay1
       clrwdt
       movlw   D'3'
       movwf   PORTA
       movf    LINE4,0
       movwf   PORTB
       call    delay1
       clrwdt
       movlw   D'4'
       movwf   PORTA
       movf    LINE5,0
       movwf   PORTB
       call    delay1
       clrwdt
       movlw   D'5'
       movwf   PORTA
       movf    LINE6,0
       movwf   PORTB
       call    delay1
       clrwdt
       movlw   D'6'
       movwf   PORTA
       movf    LINE7,0
       movwf   PORTB
       call    delay1
       clrwdt
       movlw   D'7'
       movwf   PORTA
       movf    LINE8,0
       movwf   PORTB
       call    delay1
       clrwdt
       movlw   D'8'
       movwf   PORTA
       movf    LINE9,0
       movwf   PORTB
       call    delay1
       clrwdt
       movlw   D'9'
       movwf   PORTA
       movf    LINE10,0
       movwf   PORTB
       call    delay1
       clrwdt
       movlw   D'10'
       movwf   PORTA
       movf    LINE11,0
       movwf   PORTB
       call    delay1
       clrwdt
       movlw   D'11'
       movwf   PORTA
       movf    LINE12,0
       movwf   PORTB
       call    delay1
       clrwdt
       movlw   D'12'
       movwf   PORTA
       movf    LINE13,0
       movwf   PORTB
       call    delay1
       clrwdt
       movlw   D'13'
       movwf   PORTA
       movf    LINE14,0
       movwf   PORTB
       call    delay1
       clrwdt
       movlw   D'14'
       movwf   PORTA
       movf    LINE15,0
       movwf   PORTB
       call    delay1
       clrwdt
       movlw   D'15'
       movwf   PORTA
       movf    LINE16,0
       movwf   PORTB
       call    delay1
       movlw   H'00'
       movwf   PORTB
       RETURN
SETCPUPORTSTATUS
       bsf     STATUS,RP0
       movlw   H'00'
       movwf   TRISB           ;PORTB pins : O-O-O-O-O-O-O-O
       movlw   B'00000000'
       movwf   TRISA           ;PORTA pins : X-X-X-O-O-O-O-O
       bcf     STATUS,RP0
       movlw   H'00'
       movwf   PORTA
       movwf   PORTB
RETURN
;*-     Delay Routines                                                     -*
vlong
   movlw   0xff            ;very long delay, approx 200msec
       movwf   msb
       goto    d1
       movlw   .26
       movwf   msb
       CLRWDT
       CALL    RUNTIME
       goto    d1
delay20                         ;20 msec delay
       movlw   .26
       movwf   msb
       goto    d1
delay16                         ;16 msec delay
       movlw   .21
       movwf   msb
       goto    d1
delay1                          ;approx 750nsec delay
       movlw   .1
       movwf   msb
d1      movlw   0xff
       movwf   lsb
d2      decfsz  lsb,F
       goto    d2
       decfsz  msb,F
       goto    d1
       return
FINISH
       goto    START
end
kaplan_65
MPLAB ya da MPASM kullanarak çevirebilirsiniz
:100000009C211F210030A300A30F072808280928DE
:100010000228003023074D209000013023074D2097
:100020009100023023074D209200033023074D201A
:100030009300043023074D209400053023074D2002
:100040009500063023074D209600073023074D20EA
:100050009700083023074D209800093023074D20D2
:1000600099000A3023074D209A000B3023074D20BA
:100070009B000C3023074D209C000D3023074D20A2
:100080009D000E3023074D209E000F3023074D208A
:100090009F000F30AE003421042882070034003462
:1000A00000340034003400340034003400340034B0
:1000B000003400340034003400341F341534153457
:1000C000113400341F34023404341F3400341F341C
:1000D000113411340E3400340D34103410340D3416
:1000E00000341234153409340034013401341F341F
:1000F0000134013400341F3405340D34123400341B
:100100001D340034013402341C3402340134003410
:100110001F3415341534113400341F3410341034A6
:1001200010340034003400340034003400341F3400
:1001300015341534113400341F3410341034103495
:1001400000341F3415341534113400341F34043492
:100150000A3411340034013401341F3401340134C1
:1001600000341F3405340D34123400340E3411348D
:1001700011340E3400341F34023404341F3400347C
:100180001D3400341F3404340A3411340034003474
:1001900000340034003400341F34153415340A346C
:1001A00000340D34123412340D3400341F34103442
:1001B0001034103400340D34103410340D34003445
:1001C0001F340234043402341F3400340D3410342C
:1001D00010340D3400340034003400340034003462
:1001E000003400340034003400340034003400346F
:1001F000003400340034003400340034003400345F
:10020000003400340034003400340034003400344E
:10021000003400340034003400340034003400343E
:10022000003400340034003400340034003400342E
:10023000003400340034003400340034080000304E
:100240009000910092009300940095009600970012
:10025000980099009A009B009C009D009E009F00C2
:100260003230AE003421080064003921AE0B34294D
:10027000080064000030850010088600B421640086
:100280000130850011088600B42164000230850029
:1002900012088600B421640003308500130886002C
:1002A000B42164000430850014088600B421640081
:1002B0000530850015088600B421640006308500ED
:1002C00016088600B42164000730850017088600F0
:1002D000B42164000830850018088600B421640049
:1002E0000930850019088600B42164000A308500B1
:1002F0001A088600B42164000B3085001B088600B4
:10030000B42164000C3085001C088600B421640010
:100310000D3085001D088600B42164000E30850074
:100320001E088600B42164000F3085001F08860077
:10033000B4210030860008008316003086000030AB
:10034000850083120030850086000800FF30A90078
:10035000B6291A30A90064003921B6291A30A9003B
:10036000B6291530A900B6290130A900FF30AA002E
:0C037000AA0BB829A90BB6290800002828
:00000001FF
KAZIM ASLAN Gazi Üniversitesi Elektrik Elektronik  Mühendisliği...
