SIEMENS S5 KAYNAKLARI
Başlatan XNHCX, 07 Aralık 2003, 19:06:59
XNHCX
SIEMENS 'in S5 serisi PLClerine ait KAYNAKLARI bu başlık altına yazalım
XNHCX
Alıntı YapThe following S5 PLC Program files have been tested on a
Siemens S5 135 928b Processor.
They all use the so-called "scratch pad" flags (F200.0 to F255.7),
Therefore you must ensure compatibility with your
program before using the files.
Each program is stored as a Zip file together with a .TXT file giving a brief description.
The S5D file also includes a sample "call" of the associated FB in
PB1.
FB1       (CLOCK PULSE GENERATOR).
FB2       (BINARY SCALLER)
FB9       (RESET DB)
FB22
(COMP ><)
FB40     (BITHIGH (DW))
FB50     (BITHIGH (FW))
FB51     (BITHIGH ((FY))
FB52     (MB-RESET)
FB55     (STOERFL)
FB68
(AVERAGES)
FB104   (KF->BCD)
FB105   (COUNTER (DW))
FB106   (COUNTER (DD))
FB120   (STOER0)
FB121   (STOER1)
FB130
(SHIFTREG)
FB133   (DW_FILL)
FB135   (BLOCKTRANSFER (DW TO DW))
FB136   (BLOCKTRANSFER ((FY TO DW))
FB140   (BLOCK LIST)
FB141
(BLOCK EXISTS?)
FB142   (BLOCK LENGTH)
FB145   (BLOCK P/U)
FB173   (SAVE-ZYK (FY/SY TO DR/DL))
FB174   (SAVE-ZYK (IB/QB TO DR/DL))
FB199
 (GENERATE DB/DX (928B))
FB200   (GENERATE DB ((928B))
FB216   (READ IN FROM ANALOG CARD ((STORE IN DD))
FB231   (COMPARE DD AGAINST 8
VALUES (IN DW) FOR >)
FB233   (COMPARE DD AGAINST 8 VALUES (IN DW) FOR <)
FB253   (READ IN FROM ANALOG CARD)
FB254   (OUTPUT
VALUE TO ANALOG
CARD)
http://www.plcman.co.uk/plcfiles/s5/fb1.zip
http://www.plcman.co.uk/plcfiles/s5/fb2.zip
http://www.plcman.co.uk/plcfiles/s5/fb9.zip
http://www.
plcman.co.uk/plcfiles/s5/fb22.zip
http://www.plcman.co.uk/plcfiles/s5/fb40.zip
http://www.plcman.co.uk/plcfiles/s5/fb50.zip
http://www.plcman.co.uk/plcfiles/s5/fb51.zip
http://
www.plcman.co.uk/plcfiles/s5/fb52.zip
http://www.plcman.co.uk/plcfiles/s5/fb55.zip
http://www.plcman.co.uk/plcfiles/s5/fb68.zip
http://www.plcman.co.uk/plcfiles/s5/fb104.zip
nhttp://www.plcman.co.uk/plcfiles/s5/fb105.zip
http://www.plcman.co.uk/plcfiles/s5/fb106.zip
http://www.plcman.co.uk/plcfiles/s5/fb120.zip
121.zip
http://www.plcman.co.uk/plcfiles/s5/fb130.zip
http://www.plcman.co.uk/plcfiles/s5/fb133.zip
http://www.plcman.co.uk/plcfiles/s5/fb135.zip
lcfiles/s5/fb136.zip
http://www.plcman.co.uk/plcfiles/s5/fb140.zip
http://www.plcman.co.uk/plcfiles/s5/fb141.zip
http://www.plcman.co.uk/plcfiles/s5/fb142.zip
http://www.plc
man.co.uk/plcfiles/s5/fb145.zip
http://www.plcman.co.uk/plcfiles/s5/fb173.zip
http://www.plcman.co.uk/plcfiles/s5/fb174.zip
http://www.plcman.co.uk/plcfiles/s5/fb199.zip
http:
//www.plcman.co.uk/plcfiles/s5/fb200.zip
http://www.plcman.co.uk/plcfiles/s5/fb216.zip
http://www.plcman.co.uk/plcfiles/s5/fb231.zip
http://www.plcman.co.uk/plcfiles/s5/fb233.zi
p
http://www.plcman.co.uk/plcfiles/s5/fb253.zip
http://www.plcman.co.uk/plcfiles/s5/fb254.zip
XNHCX
RS232 to 20mA
Converter
Alıntı YapThe Siemens SIMATIC S5 PLCs are programmed via a TTY serial interface
(called also 20mA
Current Loop).  To connect a PC, which is normally
equiped with RS232 ports, a converter is therefore required.
In the AutoCAD R12 file there is a complete drawing of a RS232 to
20mA Current Loop converter, suitable for data access or programming
functions.
Bu yazı aşağıdaki zip dosyasını
içinde.
http://www.plcman.co.uk/232_20ma.zip
XNHCX
fuzzy_dizayn
S5 AS511 kablosu ile kullanılabilecek bir free OPC server veya dll veya dde sahibi olan var mı?
