SMD HIGH VOLTAGE FAST-SWITCHING NPN POWER TRANSISTOR
Başlatan erkan614, 23 Haziran 2009, 14:57:22
erkan614
VCES Collector-Emitter Voltage (VBE = 0)      800 V
VCEO Collector-Emitter Voltage (IB = 0)       450 V
VEBO Emitter-Base Voltage (IC = 0)            9 V
IC Collector Current                          5 A
ICM Collector Peak Current (tp <5 ms)         10 A
IB Base Current                               2 A
IBM Base Peak Current (tp <5 ms)              4 A
Ptot Total Dissipation at Tc =                25 oC 80 W
Tstg Storage Temperature                      -65 to 150 oC
Tj Max. Operating Junction Temperature        150 oC
bu özelliklere yakın smd npn power transistor varmıdır?
