Uydu bulma cihazı-Uydu sinyal metre
Başlatan byka, 07 Ocak 2004, 23:59:14
byka
http://www.uydutvhaber.net/olcsec.htm
http://www.qrx.narod.ru/arhn2/ind.htm
http://roxsat.biz/product_info.php?products_id=32
oradaki metnin
ingilizcesi
Tuning meter of the antennas of satellite television
This indicator is intended for the finer tuning of the antenna of satellite television to the satellite, which in the final
analysis ensures the more qualitative reception TV of signal.
Ris.y.
In fig.1 is depicted indicator circuit for tuning of the antennas of satellite television, developed.
It
measures the power first PCH (950-2500 MHz), i.e., it is connected to the output of converter, which makes it possible with one instrument to produce tuning antennas in any range from L (1-2
GHz) to k (20-30 GHz).
Device consists of two amplifier stages on VT1, VT2 with microstrip 1/4 - by wave chokes with a wave drag of 110 Ohm (W1-w4) and 50 Ohm (W5), detector on
VD1, UPT on OU da2 and needle indicator PARADISE. Nourishment is achieved through FNCH LЗЗ2 and integral stabilizer DA1 from constant stress, injected BY STV - tuner
into the cable of a decrease. DA3 - the inverter of stress, it forms - 5v from + 5 v for the nourishment OU.
V. Fedorov
Radio-Mir of №8/2001, s.2shch, 26
material prepared Yu. pogreban (UA9XEX)
DWIN LCD Satış Türkiye email:info@kamantek.com  web:http://www.kamantek.com/shop/index.php
Discovery
Sn.Byka
Burada göstermiş olduğunuz devre aceba uydu bulucu cihazın devresimi ?
Uydu bulucuların
devresi konusunda bana yardımcı olabilirmisiniz ? Birçok sitede araştırma yaptım ama bu cihazın devre şemasını bulamadım. Lütfen bu konuda bilginiz varsa banada yardımcı
olun.
Teşekkürler
XNHCX
Discovery
Sn.XNHCX
Aceba basit bir devra şemasını bulamayızmı ? Görüntülü olmasada olur.
Teşekkürler
