keypad ile 2 veya daha fazla basamakli sayi yazdirma
Başlatan fuzulidark, 18 Temmuz 2012, 22:23:28
fuzulidark
Arkadaslar bu programla lcd de 1 basamakli sayi yazabiliyorum ama benim istegim 2 veya daha fazla basamakli sayi girip bunu * veya # kare tusuna basarak secim yapmasini saglamak. Oncelikli sorunum 2 veya daha basamakli sayi giremiyorum bunu nasil yapabilirim yardimci olurmusunuz?
#include<16f877.h>
#fuses XT, NOWDT, NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT, NODEBUG,NOCPD
#use delay (clock=4000000)
#use fast_io(b)
#use fast_io(d)
#define use_portb_lcd TRUE
#include <lcd.c>
#define sut1 pin_d0
#define sut2 pin_d1
#define sut3 pin_d2
#define sat1 pin_d4
#define sat2 pin_d5
#define sat3 pin_d6
#define sat4 pin_d7
char tus=0;
char keypad_oku()
output_d(0x00);
output_high(sat1);
if(input(sut1))
   { delay_ms(20); tus=1;}
if(input(sut2))
   {delay_ms(20); tus=2;}
if(input(sut3))
   {delay_ms(20); tus=3;}
output_low(sat1);
output_high(sat2);
if(input(sut1))
   {delay_ms(20); tus=4;}
if(input(sut2))
   {delay_ms(20); tus=5;}
if(input(sut3))
   {delay_ms(20); tus=6;}
output_low(sat2);
output_high(sat3);
if(input(sut1))
   {delay_ms(20); tus=7;}
if(input(sut2))
   {delay_ms(20); tus=8;}
if(input(sut3))
   {delay_ms(20); tus=9;}
output_low(sat3);
output_high(sat4);
if(input(sut1))
   {delay_ms(20); tus=0xE;}
if(input(sut2))
   {delay_ms(20); tus=0;}
if(input(sut3))
   {delay_ms(20); tus=0xF;}
output_low(sat4);
return tus;
void main ()
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_timer_1(T1_DISABLED);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_CCP1(CCP_OFF);
setup_CCP2(CCP_OFF);
set_tris_b(0x01);
set_tris_d(0x0f);
lcd_init();
printf(lcd_putc,"\fBasilan Tus=");
while(1)
lcd_gotoxy(13,1);
if(keypad_oku()!='\0')
if (keypad_oku()>9)
printf(lcd_putc,"%d",keypad_oku());
printf(lcd_putc, "%d", keypad_oku());
