LCD ile PIC fantezisi
Başlatan ziyaretci, 10 Ağustos 2012, 14:45:06
ziyaretci
  aşağıdaki kodda lcd b portuna bağlı komutu verdiğim halde d portunda veri alışverişi oldu. İsis ten kaynaklanır mı acaba ? Allah Allah dedim ya
#include <16f877.h>
#USE DELAY(CLOCK=4000000)
#define use_portb_lcd True
#include <lcd.c>
 Void main()
 set_tris_b(0x00);
 while(1)
  lcd_init();
  printf(lcd_putc,"\f ELEKTROCAVUS.com");
cemilkendir
lcd.c dosyasını buraya koyman lazım sorun onda büyük ihtimal
ziyaretci
Portlarda B yide seçsem D yide seçsem hep D den çıkış veriyor. Port b nin de durumu sürekli 0b10000111 bu şekilde
LCD dosyası aşağıda
////                             LCD.C                                     ////
////                 Driver for common LCD modules                         ////
////  lcd_init()   Must be called before any other function.               ////
////  lcd_putc(c)  Will display c on the next position of the LCD.         ////
////                     The following have special meaning:               ////
////                      \f  Clear display                                ////
////                      \n  Go to start of second line                   ////
////                      \b  Move back one position                       ////
////  lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1)        ////
////  lcd_getc(x,y)   Returns character at position x,y on LCD             ////
////  CONFIGURATION                                                        ////
////  The LCD can be configured in one of two ways: a.) port access or     ////
////  b.) pin access.  Port access requires the entire 7 bit interface     ////
////  connected to one GPIO port, and the data bits (D4:D7 of the LCD)     ////
////  connected to sequential pins on the GPIO.  Pin access                ////
////  has no requirements, all 7 bits of the control interface can         ////
////  can be connected to any GPIO using several ports.                    ////
////  To use port access, #define LCD_DATA_PORT to the SFR location of     ////
////  of the GPIO port that holds the interface, -AND- edit LCD_PIN_MAP    ////
////  of this file to configure the pin order.  If you are using a         ////
////  baseline PIC (PCB), then LCD_OUTPUT_MAP and LCD_INPUT_MAP also must  ////
////  be defined.                                                          ////
////  Example of port access:                                              ////
////     #define LCD_DATA_PORT getenv("SFR:PORTD")                         ////
////  To use pin access, the following pins must be defined:               ////
////     LCD_ENABLE_PIN                                                    ////
////     LCD_RS_PIN                                                        ////
////     LCD_RW_PIN                                                        ////
////     LCD_DATA4                                                         ////
////     LCD_DATA5                                                         ////
////     LCD_DATA6                                                         ////
////     LCD_DATA7                                                         ////
////  Example of pin access:                                               ////
////     #define LCD_ENABLE_PIN  PIN_E0                                    ////
////     #define LCD_RS_PIN      PIN_E1                                    ////
////     #define LCD_RW_PIN      PIN_E2                                    ////
////     #define LCD_DATA4       PIN_D4                                    ////
////     #define LCD_DATA5       PIN_D5                                    ////
////     #define LCD_DATA6       PIN_D6                                    ////
////     #define LCD_DATA7       PIN_D7                                    ////
////        (C) Copyright 1996,2009 Custom Computer Services           ////
//// This source code may only be used by licensed users of the CCS C  ////
//// compiler.  This source code may only be distributed to other      ////
//// licensed users of the CCS C compiler.  No other use, reproduction ////
//// or distribution is permitted without written permission.          ////
//// Derivative programs created using this software in object code    ////
//// form are not restricted in any way.                               ////
typedef struct
{                            // This structure is overlayed
   BOOLEAN enable;           // on to an I/O port to gain
   BOOLEAN rs;               // access to the LCD pins.
   BOOLEAN rw;               // The bits are allocated from
   BOOLEAN unused;           // low order up.  ENABLE will
   int     data : 4;         // be LSB pin of that port.
  #if defined(__PCD__)       // The port used will be LCD_DATA_PORT.
   int    reserved: 8;
  #endif
} LCD_PIN_MAP;
#if defined(__PCB__)
   // these definitions only need to be modified for baseline PICs.
   // all other PICs use LCD_PIN_MAP or individual LCD_xxx pin definitions.
/*                                    EN, RS,   RW,   UNUSED,  DATA  */
 const LCD_PIN_MAP LCD_OUTPUT_MAP =  {0,  0,    0,    0,       0};
 const LCD_PIN_MAP LCD_INPUT_MAP =   {0,  0,    0,    0,       0xF};
#endif
////////////////////// END CONFIGURATION ///////////////////////////////////
#ifndef LCD_ENABLE_PIN
   #define lcd_output_enable(x) lcdlat.enable=x
   #define lcd_enable_tris()   lcdtris.enable=0
#else
   #define lcd_output_enable(x) output_bit(LCD_ENABLE_PIN, x)
   #define lcd_enable_tris()  output_drive(LCD_ENABLE_PIN)
#endif
#ifndef LCD_RS_PIN
   #define lcd_output_rs(x) lcdlat.rs=x
   #define lcd_rs_tris()   lcdtris.rs=0
#else
   #define lcd_output_rs(x) output_bit(LCD_RS_PIN, x)
   #define lcd_rs_tris()  output_drive(LCD_RS_PIN)
#endif
#ifndef LCD_RW_PIN
   #define lcd_output_rw(x) lcdlat.rw=x
   #define lcd_rw_tris()   lcdtris.rw=0
#else
   #define lcd_output_rw(x) output_bit(LCD_RW_PIN, x)
   #define lcd_rw_tris()  output_drive(LCD_RW_PIN)
#endif
#ifndef LCD_DATA_PORT
      #define LCD_DATA_PORT      0x06     //portb
      #define set_tris_lcd(x)   set_tris_b(x)
   #elif defined(__PCM__)
      #define LCD_DATA_PORT      getenv("SFR:PORTD")     //portd
   #elif defined(__PCH__)
   #elif defined(__PCD__)
   #endif
#endif
   LCD_PIN_MAP lcd, lcdlat;
   #byte lcd = LCD_DATA_PORT
   #byte lcdlat = LCD_DATA_PORT
   LCD_PIN_MAP lcd, lcdlat, lcdtris;
   #byte lcdtris = LCD_DATA_PORT+0x80
   #byte lcdlat = LCD_DATA_PORT+9
   #byte lcdtris = LCD_DATA_PORT+0x12
   #word lcd = LCD_DATA_PORT
   #word lcdlat = LCD_DATA_PORT+2
   #word lcdtris = LCD_DATA_PORT-0x02
#endif
#ifndef LCD_TYPE
   #define LCD_TYPE 2           // 0=5x7, 1=5x10, 2=2 lines
#endif
#ifndef LCD_LINE_TWO
   #define LCD_LINE_TWO 0x40    // LCD RAM address for the second line
#endif
BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
                             // These bytes need to be sent to the LCD
                             // to start it up.
// original version of this library incorrectly labeled LCD_DATA0 as LCD_DATA4,
// LCD_DATA1 as LCD_DATA5, and so on.  this block of code makes the driver
// compatible with any code written for the original library
#if (defined(LCD_DATA0) && defined(LCD_DATA1) && defined(LCD_DATA2) && defined(LCD_DATA3) && !defined(LCD_DATA4) && !defined(LCD_DATA5) && !defined(LCD_DATA6) && !defined(LCD_DATA7))
   #define  LCD_DATA4    LCD_DATA0
   #define  LCD_DATA5    LCD_DATA1
   #define  LCD_DATA6    LCD_DATA2
   #define  LCD_DATA7    LCD_DATA3
#endif
BYTE lcd_read_nibble(void);
BYTE lcd_read_byte(void)
   BYTE low,high;
   set_tris_lcd(LCD_INPUT_MAP);
 #else
  #if (defined(LCD_DATA4) && defined(LCD_DATA5) && defined(LCD_DATA6) && defined(LCD_DATA7))
   output_float(LCD_DATA4);
   output_float(LCD_DATA5);
   output_float(LCD_DATA6);
   output_float(LCD_DATA7);
  #else
   lcdtris.data = 0xF;
  #endif
 #endif
   lcd_output_rw(1);
   delay_cycles(1);
   lcd_output_enable(1);
   delay_cycles(1);
   high = lcd_read_nibble();
   lcd_output_enable(0);
   delay_cycles(1);
   delay_us(1);
   low = lcd_read_nibble();
 #else
   output_drive(LCD_DATA4);
   output_drive(LCD_DATA5);
   output_drive(LCD_DATA6);
   output_drive(LCD_DATA7);
  #else
   lcdtris.data = 0x0;
  #endif
 #endif
   return( (high<<4) | low);
   BYTE n = 0x00;
   /* Read the data port */
   n |= input(LCD_DATA4);
   n |= input(LCD_DATA5) << 1;
   n |= input(LCD_DATA6) << 2;
   n |= input(LCD_DATA7) << 3;
   return(n);
  #else
   return(lcd.data);
  #endif
void lcd_send_nibble(BYTE n)
   /* Write to the data port */
   output_bit(LCD_DATA4, BIT_TEST(n, 0));
   output_bit(LCD_DATA5, BIT_TEST(n, 1));
   output_bit(LCD_DATA6, BIT_TEST(n, 2));
   output_bit(LCD_DATA7, BIT_TEST(n, 3));
  #else
   lcdlat.data = n;
  #endif
   delay_cycles(1);
   delay_us(2);
void lcd_send_byte(BYTE address, BYTE n)
   lcd_output_rs(0);
   while ( bit_test(lcd_read_byte(),7) ) ;
   lcd_output_rs(address);
   delay_cycles(1);
   lcd_output_rw(0);
   delay_cycles(1);
   lcd_send_nibble(n >> 4);
   lcd_send_nibble(n & 0xf);
void lcd_init(void)
   BYTE i;
   set_tris_lcd(LCD_OUTPUT_MAP);
 #else
  #else
   lcdtris.data = 0x0;
  #endif
   lcd_enable_tris();
   lcd_rs_tris();
   lcd_rw_tris();
 #endif
   lcd_output_rs(0);
   lcd_output_rw(0);
   delay_ms(15);
   for(i=1;i<=3;++i)
       lcd_send_nibble(3);
       delay_ms(5);
   lcd_send_nibble(2);
   for(i=0;i<=3;++i)
      lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy(BYTE x, BYTE y)
   BYTE address;
   if(y!=1)
      address=LCD_LINE_TWO;
      address=0;
   address+=x-1;
   lcd_send_byte(0,0x80|address);
void lcd_putc(char c)
   switch (c)
      case '\f'   :  lcd_send_byte(0,1);
                     delay_ms(2);
                     break;
      case '\n'   : lcd_gotoxy(1,2);        break;
      case '\b'   : lcd_send_byte(0,0x10);  break;
      default     : lcd_send_byte(1,c);     break;
char lcd_getc(BYTE x, BYTE y)
   char value;
   lcd_gotoxy(x,y);
   while ( bit_test(lcd_read_byte(),7) ); // wait until busy flag is low
   lcd_output_rs(1);
   value = lcd_read_byte();
   lcd_output_rs(0);
   return(value);
burak ozturk
kütüphane dosyasına istediginiz pinleri yazıp, ana programla aynı dosyaya attıktan sonra;
#include "DS1302.c"
şeklinde kütüphaneyi eklemeyi deneyin.muhtemel çözülecektir.
happy coding.
esensoy
lcd.c içinde use_portb_lcd değişkeni ile ayarlanan bir çıkış yok,
aşağıda ki koddan değiştirmelisin
   #endif
#endif
ya da
#define LCD_DATA_PORT  getenv("SFR:PORTB")
yazmalısın
ziyaretci
@burak ozturk teşekkürler sorun   @emresenyon'un dediği gibi
Alıntı yapılan: emresensoy - 10 Ağustos 2012, 17:34:47
   #endif
#endif
ya da
yazmalısın
@emresensoy teşekkürler.
