android java program yardım-1 !
Başlatan armsistem, 30 Ekim 2013, 17:54:21
armsistem
Arkadaşlar merhaba , aşağıdaki kodlarda anlayamadığım detaylar var yardımcı olursanız sevinirim.
UsbHid ilgili örnekleri inceliyorum. Aşağıdaki şekilde sınıfa ulaşıyorum
UsbDevice usb_sinif = new UsbDevice(name, vendorId, productId, Classs, subClass, protocol, interfaces);
- mesela UsbDevice(name...... -> buradaki name nereden nasıl çekiyor. Veya main metodunda verileri nasıl çekebilirim.
- Parcelable nedir ?
[u]MainActivity.java[/u]
package com.Usb_deneme;
import android.os.Bundle;
import android.os.Parcelable;
import android.app.Activity;
import android.view.View;
import android.view.View.OnClickListener;
import android.widget.Button;
import android.widget.TextView;
public class MainActivity extends Activity {
	protected static final int Class = 0;
	Button button1;
  	TextView textView1;
 @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
      setContentView(R.layout.activity_main);
	button1 = (Button) findViewById(R.id.button1);
textView1 =(TextView) findViewById(R.id.textView1);
	button1.setOnClickListener(new OnClickListener() {
	@Override
	    	public void onClick(View v) {
		String name = null;
		int vendorId = (Integer) null;
		int productId = (Integer) null;
		int subClass = (Integer) null;
		int	Classs = (Integer) null;
		int protocol = (Integer) null;
		Parcelable[] interfaces = null;
//textView1.setText(device.getDeviceName());
[u]UsbDevice.java[/u]
import android.hardware.usb.UsbInterface;
//import android.os.Bundle;
import android.os.Parcel;
//import android.util.Log;
//import java.io.FileDescriptor;
 * A class representing a USB device.
public class UsbDevice implements Parcelable {
    private static final String TAG = "UsbDevice";
    private final String mName;
    private final int mVendorId;
    private final int mProductId;
    private final int mClass;
    private final int mSubclass;
    private final int mProtocol;
    private final Parcelable[] mInterfaces;
     * UsbDevice should only be instantiated by UsbService implementation
     * @hide
    public UsbDevice(String name, int vendorId, int productId,
            int Class, int subClass, int protocol, Parcelable[] interfaces) {
        mName = name;
        mVendorId = vendorId;
        mProductId = productId;
        mClass = Class;
        mSubclass = subClass;
        mProtocol = protocol;
        mInterfaces = interfaces;
     * Returns the name of the device.
     * In the standard implementation, this is the path of the device file
     * for the device in the usbfs file system.
     * @return the device name
    public String getDeviceName() {
        return mName;
     * Returns a unique integer ID for the device.
     * This is a convenience for clients that want to use an integer to represent
     * the device, rather than the device name.
     * IDs are not persistent across USB disconnects.
     * @return the device ID
    public int getDeviceId() {
        return getDeviceId(mName);
     * Returns a vendor ID for the device.
     * @return the device vendor ID
    public int getVendorId() {
        return mVendorId;
     * Returns a product ID for the device.
     * @return the device product ID
    public int getProductId() {
        return mProductId;
     * Returns the devices's class field.
     * Some useful constants for USB device classes can be found in
     * {@link android.hardware.usb.UsbConstants}
     * @return the devices's class
    public int getDeviceClass() {
        return mClass;
     * Returns the device's subclass field.
     * @return the device's subclass
    public int getDeviceSubclass() {
        return mSubclass;
     * @return the device's protocol
    public int getDeviceProtocol() {
        return mProtocol;
     * Returns the number of {@link android.hardware.usb.UsbInterface}s this device contains.
     * @return the number of interfaces
    public int getInterfaceCount() {
        return mInterfaces.length;
     * Returns the {@link android.hardware.usb.UsbInterface} at the given index.
     * @return the interface
    public UsbInterface getInterface(int index) {
        return (UsbInterface)mInterfaces[index];
    @Override
    public boolean equals(Object o) {
        if (o instanceof UsbDevice) {
            return ((UsbDevice)o).mName.equals(mName);
        } else if (o instanceof String) {
            return ((String)o).equals(mName);
        } else {
            return false;
    @Override
    public int hashCode() {
        return mName.hashCode();
    @Override
    public String toString() {
        return "UsbDevice[mName=" + mName + ",mVendorId=" + mVendorId +
                ",mProductId=" + mProductId + ",mClass=" + mClass +
                ",mSubclass=" + mSubclass + ",mProtocol=" + mProtocol +
                ",mInterfaces=" + mInterfaces + "]";
    public static final Parcelable.Creator<UsbDevice> CREATOR =
        new Parcelable.Creator<UsbDevice>() {
        public UsbDevice createFromParcel(Parcel in) {
            String name = in.readString();
            int vendorId = in.readInt();
            int productId = in.readInt();
            int clasz = in.readInt();
            int subClass = in.readInt();
            int protocol = in.readInt();
            Parcelable[] interfaces = in.readParcelableArray(UsbInterface.class.getClassLoader());
            return new UsbDevice(name, vendorId, productId, clasz, subClass, protocol, interfaces);
        public UsbDevice[] newArray(int size) {
            return new UsbDevice[size];
    public int describeContents() {
        return 0;
    public void writeToParcel(Parcel parcel, int flags) {
        parcel.writeString(mName);
        parcel.writeInt(mVendorId);
        parcel.writeInt(mProductId);
        parcel.writeInt(mClass);
        parcel.writeInt(mSubclass);
        parcel.writeInt(mProtocol);
        parcel.writeParcelableArray(mInterfaces, 0);
    public static int getDeviceId(String name) {
        return native_get_device_id(name);
    public static String getDeviceName(int id) {
        return native_get_device_name(id);
    private static native int native_get_device_id(String name);
    private static native String native_get_device_name(int id);
Edit Subram: Uzun kodlarınızı kod bloğunun içine alın.
