16C54 İÇİN YAZILAN PRG. 16F84A DA ÇALIŞTIRABİLİRMİYÄ
Başlatan ta7om, 02 Mayıs 2005, 14:21:57
ta7om
Arkadaşlar DTMF receiver için yazılan bir program var.  Bu program PIC 16C54 için yazılmış  bunu 16F84 de çalıştırabilirmiyiz. Çalıştırmak için ne gibi değişiklikler yapmalıyız. Herkese teşekkürler.
;DTMFdat -- Receive the DTMF-Codes from a telephone line
; Copyright Ernst Pfenninger November 03, 2002
; Structure of the program:
;    The processing works with a cycle of 1 ms. A counter counts from 0 to
;    895 or with prescaler of 4 from 0 to 223. This makes a cycle of 1.0012 ms
;    or a deviation per day of 107 seconds.
;    A phase counter counts the cycles of 1 ms. After 10 cycles it is reset to 0,
;    making a slower cycle of 10 ms. This cycle consists of 10 phases each being 1 ms.
;    Each phase processes another task; we have a good division of the tasks over the
;    processing time.
; Processor: PIC 16C54
; Processor frequency 3.579545 MHz; 1 cycle = 1.117us
; Configuration-Word for programming the device: 0x0D (Watchdog enabled, XT-Oszillator)
; nominal watchdog timeout: 18 ms
; LCD-Display: single line with 16 characters, Hitachi-controller HD44780 compatible
; Inputs:
;    Port A Bit 0       dtmf-char bit 0
;    Port A Bit 1       dtmf-char bit 1
;    Port A Bit 2       dtmf-char bit 2
;    Port A Bit 3       dtmf-char bit 3
;    Port B Bit 6       reset display
;    Port B Bit 7       dtmf-char is ready
; Connection of the LCD-Display:
;    Port B Bit 0       DB4
;    Port B Bit 1       DB5
;    Port B Bit 2       DB6
;    Port B Bit 3       DB7
;    Port B Bit 4       E (Clock zum Datenspeichern)
;    Port B Bit 5       RS
;         R/W is always 0 (connect to GND)
   LIST   p=16c54b
   include   <p16c5x.inc>
; constants
midpos      equ   0x08   ; after mid pos of display
lastpos      equ   0x48   ; after last pos of display
; variables
phase   equ   0x07   ; phase (0..9) of the 10 ms-cycle
dlycnt   equ   0x08   ; delay counter
tmpData   equ   0x09   ; temp data for display send and delay
cnt10ms   equ   0x0A   ; 10 ms-counter (dec every 10 ms)
cursPos   equ   0x0B   ; place of cursor for next display update
state   equ   0x0C   ; bit 0 = 1: STD was high last time
;           bit 1 = 1: write points
;           bit 2 = 1: unused
;           bit 3 = 1: unused
;           bit 4 = 1: unused
;           bit 5 = 1: unused
ptcount   equ   0x0D   ; counter for writing points
unuse0E   equ   0x0E   ;
unuse0F   equ   0x0F   ;
unuse10   equ   0x10   ;
unuse11   equ   0x11   ;
unuse12   equ   0x12   ;
unuse13   equ   0x13   ;
unuse14   equ   0x14   ;
unuse15   equ   0x15   ;
unuse16   equ   0x16   ;
unuse17   equ   0x17   ;
unuse18   equ   0x18   ;
unuse19   equ   0x19   ;
unuse1A   equ   0x1A   ;
unuse1B   equ   0x1B   ;
unuse1C   equ   0x1C   ;
unuse1D   equ   0x1D   ;
unuse1E   equ   0x1E   ;
unuse1F   equ   0x1F   ;
   org   0x00      ; Set program memory base at reset vector 0x00
   goto   startall   ; goto start
; Delay_ms
; Makes a delay of xx *100 microseconds when the
; processor frequency is 3.579545 MHz.
; Input: W; delay = W * 100 microseconds
delay_ms
   movwf   dlycnt
   goto   dly2
dly1
   clrwdt         ; clear watchdog
   goto $+1
   goto $+1
   goto $+1
dly2
   movlw   .26      ; setup inner loop
   movwf   tmpData      ; save in internal delay counter
dly3
   decfsz   tmpData,F   ; dec
   goto   dly3      ; end inner loop
   decfsz   dlycnt,F   ; dec
   goto   dly1      ; end outer loop
   retlw   0x00      ; return with 0
; Send a command to the display (RS = 0)
cmdDisp
   movwf   tmpData      ; save value
   bcf   PORTB,5      ; clear RS
cmdDisp1
   movlw   b'11110000'   ; load mask
   andwf   PORTB,F      ; clear low order bits
;         zuerst high order bits transfer
   swapf   tmpData,W   ; swap byte
   andlw   b'00001111'   ; clear high order bits
   iorwf   PORTB,F      ; put low order bits to port
   bsf   PORTB,4      ; set E
   nop         ; wait
   bcf   PORTB,4      ; clear E
;         now low order bits transfer
   movf   tmpData,W   ; load value
   bsf   PORTB,4      ; set E
   nop         ; wait
;         delay of 150 microsec
   movlw   .44      ; setup loop
cmdds3
   goto   cmdds3      ; loop
; Send a special init command to the display (RS = 0)
spcDisp
   bsf   PORTB,4      ; set E
   nop         ; wait
spcds3
   goto   spcds3      ; loop
; Send a char to the display (RS = 1)
; A wait of 150 microsec is automatically done.
charDisp
   bsf   PORTB,5      ; set RS
   goto   cmdDisp1   ; goto command send routine
; Convert from binary value to ascii
; Input:  W = 0..15
; Output: W = corresponding ascii-char
binasc
   addwf PCL,f
   retlw   'D'
   retlw   '1'
   retlw   '2'
   retlw   '3'
   retlw   '4'
   retlw   '5'
   retlw   '6'
   retlw   '7'
   retlw   '8'
   retlw   '9'
   retlw   '0'
   retlw   '*'
   retlw   '#'
   retlw   'A'
   retlw   'B'
   retlw   'C'
; Start main program
;   init all
startall
   clrf   PORTA      ; clear all bits of port A
   movlw   b'00001111'   ; 4 bits input
   tris   PORTA      ; set i/o direction
   movlw   b'00000000'   ; init value port B
   movwf   PORTB      ; set bits of port B
   movlw   b'11000000'   ; 6 bits output
   tris   PORTB      ; set i/o direction
   movlw   b'00000001'   ; prescaler 1:4; all others 0
   option         ; set option reg.
   clrf   phase      ; init phase
   clrf   cursPos      ; init cursor position
   movlw   .100      ; 100 * 10 ms
   movwf   cnt10ms      ; init
   movlw   .200      ; 200 * 100 microsec
   call   delay_ms   ; delay 20 ms
;         init LCD-Display
   movlw   b'00110000'   ; command 'function set'
   call   spcDisp
   movlw   .50      ; 50 * 100 microsec
   call   spcDisp
   call   spcDisp
   movlw   b'00100000'   ; command 'function set'
   call   spcDisp
;            ; now it is 4 bit interface
   movlw   b'00101000'   ; command 'function set'
   call   cmdDisp      ; send to display
   movlw   b'00001000'   ; command 'display off'
   movlw   b'00000001'   ; command 'clear display'
   movlw   .20      ; 20 * 100 microsec
   call   delay_ms   ; delay 2 ms
   movlw   b'00000110'   ; command 'set entry mode'
   movlw   b'00001100'   ; command 'on-off control'
   clrf   TMR0      ; init timer 0
   bsf   state,1      ; must write points
;   start of main loop
start
; wait until 1 ms gone
loop1
   movf   TMR0,W      ; check if equal
   btfss   STATUS,Z   ; skip if time reached
   goto   loop1      ; goto loop3
   movlw   .33
   movwf   TMR0      ; set timer startvalue
; jump to processing of actual phase in the 10-ms-cycle
   movf   phase,W      ; load phase
   addwf   PCL,f      ; calc entry in jump table
;         jump table
   goto   prcPhas0
   goto   prcPhas1
   goto   prcPhas2
   goto   prcPhas3
   goto   prcPhas4
   goto   prcPhas5
   goto   prcPhas6
   goto   prcPhas7
   goto   prcPhas8
   goto   prcPhas9
;         end of jump table
; process phase 0
; count time in seconds; actually not used
prcPhas0
   decfsz   cnt10ms,F   ; dec 10 ms-counter
   goto   pp090      ; exit if not zero
;         counter zero
pp090
   goto   phasEEE      ; end
; process phase 1
; check the dtmf-receiver-ic and display if digit ready
prcPhas1
   btfsc   PORTB,7      ; test if data, skip if no data ready
   goto   pp120      ;
;         no data ready
   bcf   state,0      ; no data last time
   goto   pp190      ; --> exit!
;         data are ready
pp120
   btfsc   state,0      ; test if data last time, skip if no data last time
;         no data last time
   bsf   state,0      ; data last time
   movlw   lastpos      ; compare with lastpos
   subwf   cursPos,W   ;
   btfsc   STATUS,Z   ; skip if not lastpos
   goto   pp190      ;
   movf   cursPos,W   ; load pos
   iorlw   b'10000000'   ; command 'DD-RAM'
   movf   PORTA,W      ; load char
   call   binasc      ; convert to ascii
   call   charDisp   ; display char
   incf   cursPos,F   ; inc pos
   movlw   midpos      ; compare with midpos
   subwf   cursPos,W   ;
   btfss   STATUS,Z   ; skip if =midpos
;         it is midpos
   movlw   0x40      ; cursor pos
   movwf   cursPos      ; set cursor position
pp190
   goto   phasEEE      ; end
; process phase 2
prcPhas2
   btfsc   state,1      ; test if must write points
   goto   pp210      ;
   btfsc   PORTB,6      ; test if reset-switch, skip if reset
   goto   pp290      ; --> exit!
;         reset switch active
;         fill points in display
pp210
   movlw   0x00      ; curs pos
   movlw   .8      ; setup loop
   movwf   ptcount      ; save in counter
pp220
   movlw   '.'      ; char
   decfsz   ptcount,F   ; dec
   goto   pp220      ; loop
   movlw   0x40      ; curs pos
pp230
   movlw   '.'      ; char
   goto   pp230      ; loop
   bcf   state,1      ; not write points
pp290
   goto   phasEEE      ; end
; process phase 3
prcPhas3
pp390
   goto   phasEEE      ; end
; process phase 4
prcPhas4
   goto   phasEEE      ; end
; process phase 5
prcPhas5
   goto   phasEEE      ; end
; process phase 6, 7, 8
prcPhas6
prcPhas7
prcPhas8
   goto   phasEEE      ; end
; process phase 9
prcPhas9
   movlw   .255
   movwf   phase      ; init phase
;   goto   phasEEE      ; end
phasEEE
   incf   phase,F      ; increment phase
   goto   start
   end
CaFFeiNe
;    processing time.
; Inputs:
;    Port B Bit 0       DB4
;    Port B Bit 1       DB5
;    Port B Bit 2       DB6
;    Port B Bit 3       DB7
;    Port B Bit 5       RS
	LIST	p=16f84
	include	<p16f84.inc>
; constants
; variables
phase	equ	0x20	; phase (0..9) of the 10 ms-cycle
dlycnt	equ	0x21	; delay counter
tmpData	equ	0x22	; temp data for display send and delay
cnt10ms	equ	0x23	; 10 ms-counter (dec every 10 ms)
cursPos	equ	0x24	; place of cursor for next display update
;			  bit 2 = 1: unused
;			  bit 3 = 1: unused
;			  bit 4 = 1: unused
;			  bit 5 = 1: unused
unuse0E	equ	0x0E	;
unuse0F	equ	0x0F	;
unuse10	equ	0x10	;
unuse11	equ	0x11	;
unuse12	equ	0x12	;
unuse13	equ	0x13	;
unuse14	equ	0x14	;
unuse15	equ	0x15	;
unuse16	equ	0x16	;
unuse17	equ	0x17	;
unuse18	equ	0x18	;
unuse19	equ	0x19	;
unuse1A	equ	0x1A	;
unuse1B	equ	0x1B	;
unuse1C	equ	0x1C	;
unuse1D	equ	0x1D	;
unuse1E	equ	0x1E	;
unuse1F	equ	0x1F	;
; Delay_ms
delay_ms
	movwf	dlycnt
	goto	dly2
dly1
	goto $+1
	goto $+1
	goto $+1
dly2
dly3
cmdDisp
cmdDisp1
	bsf	PORTB,4		; set E
	nop			; wait
	bsf	PORTB,4		; set E
	nop			; wait
cmdds3
	goto	cmdds3		; loop
spcDisp
	bsf	PORTB,4		; set E
	nop			; wait
spcds3
	goto	spcds3		; loop
charDisp
; Input:  W = 0..15
binasc
	addwf PCL,f
	retlw	'D'
	retlw	'1'
	retlw	'2'
	retlw	'3'
	retlw	'4'
	retlw	'5'
	retlw	'6'
	retlw	'7'
	retlw	'8'
	retlw	'9'
	retlw	'0'
	retlw	'*'
	retlw	'#'
	retlw	'A'
	retlw	'B'
	retlw	'C'
;	init all
startall
	movwf	TRISA		; set i/o direction
	movwf	TRISB		; set i/o direction
	movwf	OPTION_REG	; set option reg.
;			init LCD-Display
	call	spcDisp
	call	spcDisp
	call	spcDisp
	call	spcDisp
start
loop1
	movlw	.33
;			jump table
	goto	prcPhas0
	goto	prcPhas1
	goto	prcPhas2
	goto	prcPhas3
	goto	prcPhas4
	goto	prcPhas5
	goto	prcPhas6
	goto	prcPhas7
	goto	prcPhas8
	goto	prcPhas9
;			end of jump table
; process phase 0
prcPhas0
;			counter zero
pp090
	goto	phasEEE		; end
; process phase 1
prcPhas1
	goto	pp120		;
;			no data ready
;			data are ready
pp120
;			no data last time
	subwf	cursPos,W	;
	goto	pp190		;
	subwf	cursPos,W	;
;			it is midpos
pp190
	goto	phasEEE		; end
; process phase 2
prcPhas2
	goto	pp210		;
pp210
pp220
	movlw	'.'		; char
	goto	pp220		; loop
pp230
	movlw	'.'		; char
	goto	pp230		; loop
pp290
	goto	phasEEE		; end
; process phase 3
prcPhas3
pp390
	goto	phasEEE		; end
; process phase 4
prcPhas4
	goto	phasEEE		; end
; process phase 5
prcPhas5
	goto	phasEEE		; end
prcPhas6
prcPhas7
prcPhas8
	goto	phasEEE		; end
; process phase 9
prcPhas9
	movlw	.255
phasEEE
	goto	start
	end
bu şekilde derlendi ama bir dene istersen ram başlangıç adresini 0C yaptım bide 54 te bulunan eski komutları değiştirdim "tris porta" gibi
buda hex dosyası
:020000040000FA
:100000004828A100072864000528062807281A3078
:10001000A200A20B0928A10B03280034A20086121B
:10002000F0308605220E0F398604061600000612EF
:10003000F030860522080F398604061600000612E5
:100040002C30A200A20B22280034A2008612F0302D
:100050008605220E0F3986040616000006122C3083
:10006000A200A20B31280034A200861610288207B5
:100070004434313432343334343435343634373430
:100080003834393430342A3423344134423443341C
:1000900085010F30850000308600C03086000130B9
:1000A0008100A001A4016430A300C83001203030D9
:1000B00025203230012030302520303025202030DE
:1000C000252028300E2008300E2001300E2014305C
:1000D000012006300E200C300E2081018C14010806
:1000E000031D6F2821308100200882078028852881
:1000F0009F28B828B928BA28BB28BB28BB28BD2808
:10010000A30B84286430A300BF28861B89280C1009
:100110009E280C189E280C144830240203199E288F
:10012000240880380E2005080F3937203420A40A0F
:1001300008302402031D9E284030A400BF288C18DC
:10014000A428061BB728A401003080380E200830F0
:100150008D002E3034208D0BA928403080380E20A1
:1001600008308D002E3034208D0BB2288C10BF2823
:10017000BF28BF28BF286400BF28FF30A000A00A06
:020180006F28E6
:00000001FF
ayhani
Merhaba ben pic ile 3 numara aramalı hırsız alarmı yaptım. Arama ünitesi olarak piyasada 10 milyona satılan 3 hafızalı telefonlardan kullandım. Fakat telefon numaralarını direk aramak yapmak istiyorum. Telefon arama devreleri hakkında araştırmalar yapıyorum. Foruma gönderdiğin devre şekli anlaşılır değil. devrenin detaylı resmini gönderirsen ve devrenin çalışması hakkında bilgi verirsen gerekli programı ben parsicte yazabilirim. Saygılarımla: ayhani@postamatik.com
www.kolaypic.com
ta7om
Sayın;
caffeine; ilginiz için teşekkür ediyorum. Bunu deneyip size bildirecem saygılar.
