MicroC PİC16F877 LCD YAZDIRMA
Başlatan dex25, 22 Kasım 2014, 12:29:54
dex25
/ LCD module connections
sbit LCD_RS at RB0_bit;
sbit LCD_EN at RB1_bit;
sbit LCD_D4 at RB2_bit;
sbit LCD_D5 at RB3_bit;
sbit LCD_D6 at RB4_bit;
sbit LCD_D7 at RB5_bit;
sbit LCD_RS_Direction at TRISB0_bit;
sbit LCD_EN_Direction at TRISB1_bit;
sbit LCD_D4_Direction at TRISB2_bit;
sbit LCD_D5_Direction at TRISB3_bit;
sbit LCD_D6_Direction at TRISB4_bit;
sbit LCD_D7_Direction at TRISB5_bit;
// End LCD module connections
char uart_rd;
int res;
char txt[7];
int counter=1;
void main() {
PWM1_Init(4000); // Initialize PWM1 module at 4KHz
PWM1_Start(); // start PWM1
PWM1_Set_Duty(127); // Set current duty for PWM1 to 50%
TRISD=0;
//PORTD = 1; // Set RB0 to high
Lcd_Init();
Lcd_Cmd(_LCD_CLEAR);
Lcd_Cmd(_LCD_CURSOR_OFF);
UART1_Init(9600);
delay_ms(100);
while(1){
if(UART1_Data_Ready()){
uart_rd=UART1_Read();
if ( uart_rd=='a'){lcd_out(1,counter,"a");delay_ms(500);counter++;}
if ( uart_rd=='b'){lcd_out(1,counter,"b");delay_ms(500);counter++;}
if ( uart_rd=='c'){lcd_out(1,counter,"c");delay_ms(500);counter++;}
if ( uart_rd=='d'){lcd_out(1,counter,"d");delay_ms(500);counter++;}
if ( uart_rd=='e'){lcd_out(1,counter,"e");delay_ms(500);counter++;}
if ( uart_rd=='f'){lcd_out(1,counter,"f");delay_ms(500);counter++;}
if ( uart_rd=='g'){lcd_out(1,counter,"g");delay_ms(500);counter++;}
if ( uart_rd=='h'){lcd_out(1,counter,"h");delay_ms(500);counter++;}
if ( uart_rd=='i'){lcd_out(1,counter,"i");delay_ms(500);counter++;}
if ( uart_rd=='j'){lcd_out(1,counter,"j");delay_ms(500);counter++;}
if ( uart_rd=='k'){lcd_out(1,counter,"k");delay_ms(500);counter++;}
if ( uart_rd=='l'){lcd_out(1,counter,"l");delay_ms(500);counter++;}
if ( uart_rd=='m'){lcd_out(1,counter,"m");delay_ms(500);counter++;}
if ( uart_rd=='n'){lcd_out(1,counter,"n");delay_ms(500);counter++;}
if ( uart_rd=='o'){lcd_out(1,counter,"o");delay_ms(500);counter++;}
if ( uart_rd=='p'){lcd_out(1,counter,"p");delay_ms(500);counter++;}
if ( uart_rd=='q'){lcd_out(1,counter,"q");delay_ms(500);counter++;}
if ( uart_rd=='r'){lcd_out(1,counter,"r");delay_ms(500);counter++;}
if ( uart_rd=='s'){lcd_out(1,counter,"s");delay_ms(500);counter++;}
if ( uart_rd=='t'){lcd_out(1,counter,"t");delay_ms(500);counter++;}
if ( uart_rd=='u'){lcd_out(1,counter,"u");delay_ms(500);counter++;}
if ( uart_rd=='v'){lcd_out(1,counter,"v");delay_ms(500);counter++;}
if ( uart_rd=='w'){lcd_out(1,counter,"w");delay_ms(500);counter++;}
if ( uart_rd=='x'){lcd_out(1,counter,"x");delay_ms(500);counter++;}
if ( uart_rd=='y'){lcd_out(1,counter,"y");delay_ms(500);counter++;}
if ( uart_rd=='z'){lcd_out(1,counter,"z");delay_ms(500);counter++;}
if ( uart_rd==' '){lcd_out(1,counter," ");delay_ms(500);counter++;}
if ( uart_rd=='0′){Lcd_Cmd(_LCD_CLEAR); counter=1;}
ARKADAŞLAR C#DAN BURAYA GÖNDERDİĞİM VERİNİN LCD EKRANDA YAZILMASINI İSTİYORUM.FAKAT VERİNİN SADECE İLK 3 KARAKTERİ LCDYE YAZILIYOR.KODDAKİ SORUN SİZCE NE OLABİLİR
