Ardunio kodu hata veriyor.
Başlatan Melih1802, 26 Aralık 2014, 18:04:20
Melih1802
Kendi sitesinden aldığım kod derleme sırasında hata veriyor. http://playground.arduino.cc/Learning/MFRC522
 * MFRC522 - Library to use ARDUINO RFID MODULE KIT 13.56 MHZ WITH TAGS SPI W AND R BY COOQROBOT.
 * The library file MFRC522.h has a wealth of useful info. Please read it.
 * The functions are documented in MFRC522.cpp.
 * Based on code Dr.Leong   ( [url=http://WWW.B2CQSHOP.COM]WWW.B2CQSHOP.COM[/url] )
 * Created by Miguel Balboa (circuitito.com), Jan, 2012.
 * Rewritten by Søren Thing Andersen (access.thing.dk), fall of 2013 (Translation to English, refactored, comments, anti collision, cascade levels.)
 * Released into the public domain.
 * Sample program showing how to read data from a PICC using a MFRC522 reader on the Arduino SPI interface.
 *----------------------------------------------------------------------------- empty_skull
 * Aggiunti pin per arduino Mega
 * add pin configuration for arduino mega
 * http://mac86project.altervista.org/
 ----------------------------------------------------------------------------- Nicola Coppola
 * Pin layout should be as follows:
 * Signal     Pin              Pin               Pin
 *            Arduino Uno      Arduino Mega      MFRC522 board
 * Reset      9                5                 RST
 * SPI SS     10               53                SDA
 * SPI MOSI   11               51                MOSI
 * SPI MISO   12               50                MISO
 * SPI SCK    13               52                SCK
 * The reader can be found on eBay for around 5 dollars. Search for "mf-rc522" on ebay.com.
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
[b]MFRC522 mfrc522(SS_PIN, RST_PIN);	// Create MFRC522 instance.[/b]
void setup() {
	Serial.begin(9600);	// Initialize serial communications with the PC
	SPI.begin();			// Init SPI bus
	mfrc522.PCD_Init();	// Init MFRC522 card
	Serial.println("Scan PICC to see UID and type...");
void loop() {
	// Look for new cards
	if ( ! mfrc522.PICC_IsNewCardPresent()) {
		return;
	// Select one of the cards
	if ( ! mfrc522.PICC_ReadCardSerial()) {
		return;
	// Dump debug info about the card. PICC_HaltA() is automatically called.
	mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
MrDarK
Kütüphaneyi ; Belgelerim içinde bulunan Arduino klasörü içindeki examples veya library içine atıp oradan çalıştırın.
Veya kütüphane dosyasını kendi Program Files klasörü içindeki lib klasörü içine yükleyin.
Kabil ATICI
[b] MFRC522 mfrc522(SS_PIN, RST_PIN);	// Create MFRC522 instance.[/b]
hata buradaki satırdan kaynaklanıyor
[b]
   yazan yeri   sil.
Ek :
siz o yazıyı sildi iseniz ve hala düzelmedi ise derleyciyi kapatın
https://github.com/miguelbalboa/rfid
buradan kütüphaneyi indirin açın ve "Belgelerim" klasörü içindeki "Arduino" klasörün içinde "libraries" klasörü içine kopyalayın.
Derleyiciyi tekrar çalıştırın. Kodu derleyin.
ambar7
Melih1802
Programı  "Libraries" içine atınca çalıştı.
Fakat kart çalışmadı. Elimde Çin kopyası Arduino Mega 2560 var. Pinlerini Programda verildiği gibi değiştirdim.
Bir yerde yanlışım olmalı
* Typical pin layout used:
*             MFRC522       Arduino       Arduino   Arduino
*             Reader/PCD   Uno             Mega       Nano v3
* Signal      Pin              Pin              Pin           Pin
* RST/Reset   RST            9                   5         D9
* SPI SS      SDA(SS)      10                 53        D10
* SPI MOSI    MOSI         11 / ICSP-4   51        D11
* SPI MISO    MISO         12 / ICSP-1   50        D12
* SPI SCK     SCK            13 / ICSP-3   52        D13
Benim bağlantım:
RC522    MEGA
SDA        53
SCK        52
MOSI      51
MISO      50
IRQ         BOŞ
GND        GND
RST         PWM 5
3.3V        3.3V
Bağlantılarım doğrumu' dur.
Program üzerindende pin numaralarını MEGA' ya göre değiştirdim.
#include <SPI.h>
#define RST_PIN      5      //
#define SS_PIN      53      //
mesaj birleştirme:: 27 Aralık 2014, 11:24:26
Kartı yeniden başlatınca çalıştı.
mesaj birleştirme:: 26 Aralık 2014, 21:31:19
MFRC522 Software Version: 0x91 = v1.0
Scan PICC to see UID, type, and data blocks...
Card UID: EE 33 CA 55
PICC type: MIFARE 1KB
Sector Block   0  1  2  3   4  5  6  7   8  9 10 11  12 13 14 15  AccessBits
  15     63   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         62   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         61   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         60   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
  14     59   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         58   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         57   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         56   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
  13     55   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         54   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         53   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         52   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
  12     51   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         50   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         49   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         48   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
  11     47   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         46   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         45   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         44   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
  10     43   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         42   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         41   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         40   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
   9     39   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         38   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         37   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         36   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
   8     35   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         34   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         33   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         32   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
   7     31   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         30   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         29   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         28   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
   6     27   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         26   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         25   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         24   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
   5     23   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         22   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         21   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         20   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
   4     19   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         18   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         17   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         16   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
   3     15   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         14   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         13   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         12   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
   2     11   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         10   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
   1      7   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
   0      3   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
          0   EE 33 CA 55  42 88 04 00  85 00 B4 2E  F0 BB 6A A8  [ 0 0 0 ]
bir kaç sn sonunda okuduğu kodlar bunlar.
MrDarK
Tebrikler ;
Artık mifare'ın detaylarına inebilirsiniz. Aşağıdaki linki iyice inceleyip anlamaya çalışmanızı öneririm.
https://www.picproje.org/index.php?topic=52963.0
Melih1802
Şimdi yapmak istediğim Ardunio içine sadece bir kart kodunu tanıtıp başka bir kart kodunda işlem yapmamasını istiyorum.
Ardunio sadece kendine ait kart kodunu okuyunca PWM13 çıkışındaki sarı led' i 1 sn yakacak.
Kabil ATICI
Kütüphane içinde birkaç tane kod örneği var, hatta istersen içine şifre yazıp, okuyabilirsin
Ama başka bir şeyle değil de kartın kendisi için ise Card UID için
mfrc522.uid.uidByte, mfrc522.uid.size parametreleri var.Sanırım bunları başta okunuyor. Bir şekilde bunlar kullanılabilir sanırım.
Deneme şansım yok tabii..
ambar7
Melih1802
delete
Kabil ATICI
Kodlarınızı, kod bloğu (kod ekle butonu ile) içine almanız mümkün mü?
Bu şekilde takip etmek bir zor oluyor. Daha doğrusu yazdığınız mesajlara odaklanmak zorlaşıyor.
ambar7
Melih1802
#include <SPI.h>
#define RST_PIN		9		//
#define SS_PIN		10		//
void setup() {
	ShowReaderDetails();	// Show details of PCD - MFRC522 Card Reader details
	Serial.println("Scan PICC to see UID, type, and data blocks...");
void loop() {
		return;
		return;
	// Dump debug info about the card; PICC_HaltA() is automatically called
void ShowReaderDetails() {
	// Get the MFRC522 software version
	byte v = mfrc522.PCD_ReadRegister(mfrc522.VersionReg);
	Serial.print("MFRC522 Software Version: 0x");
	Serial.print(v, HEX);
	if (v == 0x91)
		Serial.print(" = v1.0");
	else if (v == 0x92)
		Serial.print(" = v2.0");
		Serial.print(" (unknown)");
	Serial.println("");
	// When 0x00 or 0xFF is returned, communication probably failed
	if ((v == 0x00) || (v == 0xFF)) {
		Serial.println("WARNING: Communication failure, is the MFRC522 properly connected?");
mesaj birleştirme:: 27 Aralık 2014, 13:37:07
#include <SPI.h>
#define RST_PIN         9           // Configurable, see typical pin layout above
#define SS_PIN          10          // Configurable, see typical pin layout above
MFRC522::MIFARE_Key key;
 * Initialize.
void setup() {
    // Prepare the key (used both as key A and as key B)
    // using FFFFFFFFFFFFh which is the default at chip delivery from the factory
    for (byte i = 0; i < 6; i++) {
        key.keyByte[i] = 0xFF;
    Serial.println("Scan a MIFARE Classic PICC to demonstrate Value Block mode.");
    Serial.print("Using key (for A and B):");
    dump_byte_array(key.keyByte, MFRC522::MF_KEY_SIZE);
    Serial.println();
    Serial.println("BEWARE: Data will be written to the PICC, in sector #1");
 * Main loop.
void loop() {
        return;
        return;
    // Show some details of the PICC (that is: the tag/card)
    Serial.print("Card UID:");
    dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size);
    Serial.println();
    Serial.print("PICC type: ");
    byte piccType = mfrc522.PICC_GetType(mfrc522.uid.sak);
    Serial.println(mfrc522.PICC_GetTypeName(piccType));
    // Check for compatibility
    if (    piccType != MFRC522::PICC_TYPE_MIFARE_MINI
        &&  piccType != MFRC522::PICC_TYPE_MIFARE_1K
        &&  piccType != MFRC522::PICC_TYPE_MIFARE_4K) {
        Serial.println("This sample only works with MIFARE Classic cards.");
        return;
    // In this sample we use the second sector,
    // that is: sector #1, covering block #4 up to and including block #7
    byte sector         = 1;
    byte valueBlockA    = 5;
    byte valueBlockB    = 6;
    byte trailerBlock   = 7;
    byte status;
    byte buffer[18];
    byte size = sizeof(buffer);
    long value;
    // Authenticate using key A
    Serial.println("Authenticating using key A...");
    status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, trailerBlock, &key, &(mfrc522.uid));
    if (status != MFRC522::STATUS_OK) {
        Serial.print("PCD_Authenticate() failed: ");
        Serial.println(mfrc522.GetStatusCodeName(status));
        return;
    // Show the whole sector as it currently is
    Serial.println("Current data in sector:");
    mfrc522.PICC_DumpMifareClassicSectorToSerial(&(mfrc522.uid), &key, sector);
    Serial.println();
    // We need a sector trailer that defines blocks 5 and 6 as Value Blocks and enables key B
    // The last block in a sector (block #3 for Mifare Classic 1K) is the Sector Trailer.
    // See http://www.nxp.com/documents/data_sheet/MF1S503x.pdf sections 8.6 and 8.7:
    //      Bytes 0-5:   Key A
    //      Bytes 6-8:   Access Bits
    //      Bytes 9:     User data
    //      Bytes 10-15: Key B (or user data)
    byte trailerBuffer[] = {
        255, 255, 255, 255, 255, 255,       // Keep default key A
        0, 0, 0,
        0,
        255, 255, 255, 255, 255, 255};      // Keep default key B
    // The access bits are stored in a peculiar fashion.
    // There are four groups:
    //      g[0]    Access bits for block 0 (for sectors 0-31)
    //              or blocks 0-4 (for sectors 32-39)
    //      g[1]    Access bits for block 1 (for sectors 0-31)
    //              or blocks 5-9 (for sectors 32-39)
    //      g[2]    Access bits for block 2 (for sectors 0-31)
    //              or blocks 10-14 (for sectors 32-39)
    //      g[3]    Access bits for the Sector Trailer: block 3 (for sectors 0-31)
    //              or block 15 (for sectors 32-39)
    // Each group has access bits [C1 C2 C3], in this code C1 is MSB and C3 is LSB.
    // Determine the bit pattern needed using MIFARE_SetAccessBits:
    //      g0=0    access bits for block 0 (of this sector) using [0 0 0] = 000b = 0
    //              which means key A|B have r/w for block 0 of this sector
    //              which (in this example) translates to block #4 within sector #1;
    //              this is the transport configuration (at factory delivery).
    //      g1=6    access bits for block 1 (of this sector) using [1 1 0] = 110b = 6
    //              which means block 1 (of this sector) is used as a value block,
    //              which (in this example) translates to block #5 within sector #1;
    //              where key A|B have r, key B has w, key B can increment,
    //              and key A|B can decrement, transfer, and restore.
    //      g2=6    same thing for block 2 (of this sector): set it to a value block;
    //              which (in this example) translates to block #6 within sector #1;
    //      g3=3    access bits for block 3 (of this sector): the Sector Trailer here;
    //              using [0 1 1] = 011b = 3 which means only key B has r/w access
    //              to the Sector Trailer (block 3 of this sector) from now on
    //              which (in this example) translates to block #7 within sector #1;
    mfrc522.MIFARE_SetAccessBits(&trailerBuffer[6], 0, 6, 6, 3);
    // Read the sector trailer as it is currently stored on the PICC
    Serial.println("Reading sector trailer...");
    status = mfrc522.MIFARE_Read(trailerBlock, buffer, &size);
        Serial.print("MIFARE_Read() failed: ");
        return;
    // Check if it matches the desired access pattern already;
    // because if it does, we don't need to write it again...
    if (    buffer[6] != trailerBuffer[6]
        &&  buffer[7] != trailerBuffer[7]
        &&  buffer[8] != trailerBuffer[8]) {
        // They don't match (yet), so write it to the PICC
        Serial.println("Writing new sector trailer...");
        status = mfrc522.MIFARE_Write(trailerBlock, trailerBuffer, 16);
            Serial.print("MIFARE_Write() failed: ");
            return;
    // Authenticate using key B
    Serial.println("Authenticating again using key B...");
    status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_B, trailerBlock, &key, &(mfrc522.uid));
        return;
    // A value block has a 32 bit signed value stored three times
    // and an 8 bit address stored 4 times. Make sure that valueBlockA
    // and valueBlockB have that format (note that it will only format
    // the block when it doesn't comply to the expected format already).
    formatValueBlock(valueBlockA);
    formatValueBlock(valueBlockB);
    // Add 1 to the value of valueBlockA and store the result in valueBlockA.
    Serial.print("Adding 1 to value of block "); Serial.println(valueBlockA);
    status = mfrc522.MIFARE_Increment(valueBlockA, 1);
        Serial.print("MIFARE_Increment() failed: ");
        return;
    status = mfrc522.MIFARE_Transfer(valueBlockA);
        Serial.print("MIFARE_Transfer() failed: ");
        return;
    // Show the new value of valueBlockA
    status = mfrc522.MIFARE_GetValue(valueBlockA, &value);
        Serial.print("mifare_GetValue() failed: ");
        return;
    Serial.print("New value of value block "); Serial.print(valueBlockA);
    Serial.print(" = "); Serial.println(value);
    // Decrement 10 from the value of valueBlockB and store the result in valueBlockB.
    Serial.print("Subtracting 10 from value of block "); Serial.println(valueBlockB);
    status = mfrc522.MIFARE_Decrement(valueBlockB, 10);
        Serial.print("MIFARE_Decrement() failed: ");
        return;
    status = mfrc522.MIFARE_Transfer(valueBlockB);
        return;
    // Show the new value of valueBlockB
    status = mfrc522.MIFARE_GetValue(valueBlockB, &value);
        return;
    Serial.print("New value of value block "); Serial.print(valueBlockB);
    // Check some boundary...
    if (value <= -100) {
        Serial.println("Below -100, so resetting it to 255 = 0xFF just for fun...");
        status = mfrc522.MIFARE_SetValue(valueBlockB, 255);
            Serial.print("mifare_SetValue() failed: ");
            return;
    // Dump the sector data
    Serial.println();
    // Halt PICC
    mfrc522.PICC_HaltA();
    // Stop encryption on PCD
    mfrc522.PCD_StopCrypto1();
 * Helper routine to dump a byte array as hex values to Serial.
void dump_byte_array(byte *buffer, byte bufferSize) {
    for (byte i = 0; i < bufferSize; i++) {
        Serial.print(buffer[i] < 0x10 ? " 0" : " ");
        Serial.print(buffer[i], HEX);
 * Ensure that a given block is formatted as a Value Block.
void formatValueBlock(byte blockAddr) {
    byte buffer[18];
    byte status;
    Serial.print("Reading block "); Serial.println(blockAddr);
    status = mfrc522.MIFARE_Read(blockAddr, buffer, &size);
        return;
    if (    (buffer[0] == (byte)~buffer[4])
        &&  (buffer[1] == (byte)~buffer[5])
        &&  (buffer[2] == (byte)~buffer[6])
        &&  (buffer[3] == (byte)~buffer[7])
        &&  (buffer[0] == buffer[8])
        &&  (buffer[1] == buffer[9])
        &&  (buffer[2] == buffer[10])
        &&  (buffer[3] == buffer[11])
        &&  (buffer[12] == (byte)~buffer[13])
        &&  (buffer[12] ==        buffer[14])
        &&  (buffer[12] == (byte)~buffer[15])) {
        Serial.println("Block has correct Value Block format.");
    else {
        Serial.println("Formatting as Value Block...");
        byte valueBlock[] = {
            0, 0, 0, 0,
            255, 255, 255, 255,
            0, 0, 0, 0,
            blockAddr, ~blockAddr, blockAddr, ~blockAddr };
        status = mfrc522.MIFARE_Write(blockAddr, valueBlock, 16);
mesaj birleştirme:: 27 Aralık 2014, 13:38:03
#include <SPI.h>
 * Initialize.
void setup() {
    Serial.println("Scan a MIFARE Classic PICC to demonstrate read and write.");
    Serial.println();
 * Main loop.
void loop() {
        return;
        return;
    Serial.println();
        return;
    byte sector         = 1;
    byte blockAddr      = 4;
    byte dataBlock[]    = {
        0x01, 0x02, 0x03, 0x04, //  1,  2,   3,  4,
        0x05, 0x06, 0x07, 0x08, //  5,  6,   7,  8,
        0x08, 0x09, 0xff, 0x0b, //  9, 10, 255, 12,
        0x0c, 0x0d, 0x0e, 0x0f  // 13, 14,  15, 16
    byte status;
    byte buffer[18];
        return;
    Serial.println();
    // Read data from the block
    Serial.print("Reading data from block "); Serial.print(blockAddr);
    Serial.println(" ...");
    Serial.print("Data in block "); Serial.print(blockAddr); Serial.println(":");
    dump_byte_array(buffer, 16); Serial.println();
    Serial.println();
        return;
    // Write data to the block
    Serial.print("Writing data into block "); Serial.print(blockAddr);
    dump_byte_array(dataBlock, 16); Serial.println();
    status = mfrc522.MIFARE_Write(blockAddr, dataBlock, 16);
    Serial.println();
    // Read data from the block (again, should now be what we have written)
    // Check that data in block is what we have written
    // by counting the number of bytes that are equal
    Serial.println("Checking result...");
    byte count = 0;
    for (byte i = 0; i < 16; i++) {
        // Compare buffer (= what we've read) with dataBlock (= what we've written)
        if (buffer[i] == dataBlock[i])
            count++;
    Serial.print("Number of bytes that match = "); Serial.println(count);
    if (count == 16) {
        Serial.println("Success :-)");
    } else {
        Serial.println("Failure, no match :-(");
        Serial.println("  perhaps the write didn't work properly...");
    Serial.println();
    Serial.println();
    // Halt PICC
mesaj birleştirme:: 27 Aralık 2014, 13:38:48
#include <SPI.h>
// Number of known default keys (hard-coded)
// NOTE: Synchronize the NR_KNOWN_KEYS define with the defaultKeys[] array
#define NR_KNOWN_KEYS   8
// Known keys, see: https://code.google.com/p/mfcuk/wiki/MifareClassicDefaultKeys
byte knownKeys[NR_KNOWN_KEYS][MFRC522::MF_KEY_SIZE] =  {
    {0xff, 0xff, 0xff, 0xff, 0xff, 0xff}, // FF FF FF FF FF FF = factory default
    {0xa0, 0xa1, 0xa2, 0xa3, 0xa4, 0xa5}, // A0 A1 A2 A3 A4 A5
    {0xb0, 0xb1, 0xb2, 0xb3, 0xb4, 0xb5}, // B0 B1 B2 B3 B4 B5
    {0x4d, 0x3a, 0x99, 0xc3, 0x51, 0xdd}, // 4D 3A 99 C3 51 DD
    {0x1a, 0x98, 0x2c, 0x7e, 0x45, 0x9a}, // 1A 98 2C 7E 45 9A
    {0xd3, 0xf7, 0xd3, 0xf7, 0xd3, 0xf7}, // D3 F7 D3 F7 D3 F7
    {0xaa, 0xbb, 0xcc, 0xdd, 0xee, 0xff}, // AA BB CC DD EE FF
    {0x00, 0x00, 0x00, 0x00, 0x00, 0x00}  // 00 00 00 00 00 00
 * Initialize.
void setup() {
    Serial.println("Try the most used default keys to print block 0 of a MIFARE PICC.");
 * Try using the PICC (the tag/card) with the given key to access block 0.
 * On success, it will show the key details, and dump the block data on Serial.
 * @return true when the given key worked, false otherwise.
boolean try_key(MFRC522::MIFARE_Key *key)
    boolean result = false;
    byte buffer[18];
    byte block = 0;
    byte status;
    // Serial.println("Authenticating using key A...");
    status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, block, key, &(mfrc522.uid));
        // Serial.print("PCD_Authenticate() failed: ");
        // Serial.println(mfrc522.GetStatusCodeName(status));
        return false;
    // Read block
    byte byteCount = sizeof(buffer);
    status = mfrc522.MIFARE_Read(block, buffer, &byteCount);
        // Serial.print("MIFARE_Read() failed: ");
    else {
        // Successful read
        result = true;
        Serial.print("Success with key:");
        dump_byte_array((*key).keyByte, MFRC522::MF_KEY_SIZE);
        Serial.println();
        // Dump block data
        Serial.print("Block "); Serial.print(block); Serial.print(":");
        Serial.println();
    Serial.println();
    mfrc522.PICC_HaltA();       // Halt PICC
    mfrc522.PCD_StopCrypto1();  // Stop encryption on PCD
    return result;
 * Main loop.
void loop() {
        return;
        return;
    Serial.println();
    // Try the known default keys
    for (byte k = 0; k < NR_KNOWN_KEYS; k++) {
        // Copy the known key into the MIFARE_Key structure
        for (byte i = 0; i < MFRC522::MF_KEY_SIZE; i++) {
            key.keyByte[i] = knownKeys[k][i];
        // Try the key
        if (try_key(&key)) {
            // Found and reported on the key and block,
            // no need to try other keys for this PICC
            break;
mesaj birleştirme:: 26 Aralık 2014, 23:39:24
#include <SPI.h>
#define SS_PIN 10    //Arduino Uno
#define RST_PIN 9
void setup() {
        Serial.println("Write personal data on a MIFARE PICC ");
void loop() {
        // Prepare key - all keys are set to FFFFFFFFFFFFh at chip delivery from the factory.
        for (byte i = 0; i < 6; i++) key.keyByte[i] = 0xFF;
                return;
        if ( ! mfrc522.PICC_ReadCardSerial())    return;
        Serial.print("Card UID:");    //Dump UID
        for (byte i = 0; i < mfrc522.uid.size; i++) {
          Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
          Serial.print(mfrc522.uid.uidByte[i], HEX);
        Serial.print(" PICC type: ");   // Dump PICC type
        byte buffer[34];
        byte block;
        byte status, len;
        Serial.setTimeout(20000L) ;     // wait until 20 seconds for input from serial
        // Ask personal data: Family name
        Serial.println("Type Family name, ending with #");
        len=Serial.readBytesUntil('#', (char *) buffer, 30) ; // read family name from serial
        for (byte i = len; i < 30; i++) buffer[i] = '\s';     // pad with spaces
        block = 1;
        //Serial.println("Authenticating using key A...");
        status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, block, &key, &(mfrc522.uid));
           return;
        // Write block
	status = mfrc522.MIFARE_Write(block, buffer, 16);
            return;
        else Serial.println("MIFARE_Write() success: ");
        block = 2;
           return;
        // Write block
	status = mfrc522.MIFARE_Write(block, &buffer[16], 16);
            return;
        // Ask personal data: First name
        Serial.println("Type First name, ending with #");
        len=Serial.readBytesUntil('#', (char *) buffer, 20) ; // read first name from serial
        for (byte i = len; i < 20; i++) buffer[i] = '\s';     // pad with spaces
        block = 4;
           return;
        // Write block
            return;
        block = 5;
           return;
        // Write block
            return;
        Serial.println(" ");
Birşey sorayım.
Arduino uno ile 2x16LCD ye birşeyler yazıyorum. Yazma yapıldığı zaman kendi kendine seri porttan birşeyler gönderiyor. Terminalden bakıyorum ama gelen karakterler anlamsız. üstelik seri portu aktif etmiyorum bile.
lcd.setCursor fonksiyonununda bile benzer bir durum var. Kodum çalışıyor ama nedenini merak ettim. Neden olur bu
MrDarK
Lcd kütüphanesinin kullandığı pinlerden biri seriportun txine denk geliyor olabilir.
6 hat bağlantı yaptığınızı düşünerek RW pinini direk GND'ye çektiğinizi düşünüyorum. Büyük ihtimalle arduino driver'ınızın RW pini TX piniyle bir şekilde çakışıyor :)
Manual olarak drivera müdahale etmeniz gerek. Yoksa arduino kendi kendine seri porttan data basmaz diye düşünüyorum :)
Kabil ATICI
baktım arduino LCD kodunu anlamak zamanımı alacak bende kendi kodumu yazdım. 8 bitlik+3 kontrol hatlı.Hala bazı yerleri eksik olsada idare eder.
LCD bağlantı bacaklarına bir bakmak gerek, 0 ve 1 kullanılıyorsa bir yaklaşım olabilir.
Kendi kütüphanesini kullanıyorsan, orada seri portu kullanacak bir kod yok.
ambar7
Gözümden kaçmış. Evet TX pini ile çakışma oluyormuş.
