linux cnc anlayamadıgım bır hata
Başlatan klax, 22 Şubat 2015, 21:34:56
klax
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.4
Machine configuration directory is '/home/cnc/linuxcnc/configs/stepper-xyza'
Machine configuration file is 'inch.ini'
INIFILE=/home/cnc/linuxcnc/configs/stepper-xyza/inch.ini
PARAMETER_FILE=stepper.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Realtime system did not load
Shutting down and cleaning up LinuxCNC...
Killing task linuxcncsvr, PID=3425
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 Operation not permitted
3425
  PID TTY      STAT   TIME COMMAND
Stopping realtime threads
RTAPI: ERROR: could not open shared memory (errno=2)
/usr/bin/linuxcnc: satır 433:  3463 Parçalama arızası    $HALCMD stop
Unloading hal components
/usr/bin/linuxcnc: satır 433:  3464 Parçalama arızası    $HALCMD unload all
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
ERROR: Module rtai_hal does not exist in /proc/modules
Kernel message information:
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 2.6.32-122-rtai (root@moses-6core) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #rtai SMP Tue Jul 27 12:44:07 CDT 2010 (Ubuntu 2.6.32-122.35.rtai-rtai 2.6.32.11+drm33.2)
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   NSC Geode by NSC
[    0.000000]   Cyrix CyrixInstead
[    0.000000]   Centaur CentaurHauls
[    0.000000]   Transmeta GenuineTMx86
[    0.000000]   Transmeta TransmetaCPU
[    0.000000]   UMC UMC UMC UMC
[    0.000000] BIOS-provided physical RAM map:
[    0.000000]  BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[    0.000000]  BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[    0.000000]  BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[    0.000000]  BIOS-e820: 0000000000100000 - 000000001fff0000 (usable)
[    0.000000]  BIOS-e820: 000000001fff0000 - 000000001fffffc0 (ACPI data)
[    0.000000]  BIOS-e820: 000000001fffffc0 - 0000000020000000 (ACPI NVS)
[    0.000000]  BIOS-e820: 00000000ffb80000 - 00000000ffc00000 (reserved)
[    0.000000]  BIOS-e820: 00000000fff80000 - 0000000100000000 (reserved)
[    0.000000] DMI 2.3 present.
[    0.000000] last_pfn = 0x1fff0 max_arch_pfn = 0x100000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-CFFFF write-protect
[    0.000000]   D0000-DFFFF uncachable
[    0.000000]   E0000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000 mask FE0000000 write-back
[    0.000000]   1 disabled
[    0.000000]   2 disabled
[    0.000000]   3 disabled
[    0.000000]   4 disabled
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] PAT not supported by CPU.
[    0.000000] e820 update range: 0000000000002000 - 0000000000006000 (usable) ==> (reserved)
[    0.000000] Scanning 1 areas for low memory corruption
[    0.000000] modified physical RAM map:
[    0.000000]  modified: 0000000000000000 - 0000000000002000 (usable)
[    0.000000]  modified: 0000000000002000 - 0000000000006000 (reserved)
[    0.000000]  modified: 0000000000006000 - 000000000009fc00 (usable)
[    0.000000]  modified: 000000000009fc00 - 00000000000a0000 (reserved)
[    0.000000]  modified: 00000000000e0000 - 0000000000100000 (reserved)
[    0.000000]  modified: 0000000000100000 - 000000001fff0000 (usable)
[    0.000000]  modified: 000000001fff0000 - 000000001fffffc0 (ACPI data)
[    0.000000]  modified: 000000001fffffc0 - 0000000020000000 (ACPI NVS)
[    0.000000]  modified: 00000000ffb80000 - 00000000ffc00000 (reserved)
[    0.000000]  modified: 00000000fff80000 - 0000000100000000 (reserved)
[    0.000000] initial memory mapped : 0 - 00c00000
[    0.000000] init_memory_mapping: 0000000000000000-000000001fff0000
[    0.000000] Using x86 segment limits to approximate NX protection
[    0.000000]  0000000000 - 0000400000 page 4k
[    0.000000]  0000400000 - 001fc00000 page 2M
[    0.000000]  001fc00000 - 001fff0000 page 4k
[    0.000000] kernel direct mapping tables up to 1fff0000 @ 7000-c000
[    0.000000] RAMDISK: 173a8000 - 180335a0
[    0.000000] ACPI: RSDP 000e6010 00014 (v00 OID_00)
[    0.000000] ACPI: RSDT 1fffb266 00034 (v01 INSYDE RSDT_000 00000001 _CSI 00010101)
[    0.000000] ACPI: FACP 1ffffb00 00074 (v01 INSYDE FACP_000 00000100 _CSI 00010101)
[    0.000000] ACPI: DSDT 1fffb6d0 04429 (v01 INSYDE   Canyon 00001004 INTL 02002036)
[    0.000000] ACPI: FACS 1fffffc0 00040
[    0.000000] ACPI: BOOT 1ffffb90 00028 (v01 INSYDE SYS_BOOT 00000100 _CSI 00010101)
[    0.000000] ACPI: DBGP 1ffffbc0 00034 (v01 INSYDE DBGP_000 00000100 _CSI 00010101)
[    0.000000] ACPI: SSDT 1fffb29a 00192 (v01  INTEL  EISTRef 00002000 INTL 20021002)
[    0.000000] 0MB HIGHMEM available.
[    0.000000] 511MB LOWMEM available.
[    0.000000]   mapped low ram: 0 - 1fff0000
[    0.000000]   low ram: 0 - 1fff0000
[    0.000000]   node 0 low ram: 00000000 - 1fff0000
[    0.000000]   node 0 bootmap 00008000 - 0000c000
[    0.000000] (9 early reservations) ==> bootmem [0000000000 - 001fff0000]
[    0.000000]   #0 [0000000000 - 0000001000]   BIOS data page ==> [0000000000 - 0000001000]
[    0.000000]   #1 [0000001000 - 0000002000]    EX TRAMPOLINE ==> [0000001000 - 0000002000]
[    0.000000]   #2 [0000006000 - 0000007000]       TRAMPOLINE ==> [0000006000 - 0000007000]
[    0.000000]   #3 [0000100000 - 00008b0db8]    TEXT DATA BSS ==> [0000100000 - 00008b0db8]
[    0.000000]   #4 [00173a8000 - 00180335a0]          RAMDISK ==> [00173a8000 - 00180335a0]
[    0.000000]   #5 [000009fc00 - 0000100000]    BIOS reserved ==> [000009fc00 - 0000100000]
[    0.000000]   #6 [00008b1000 - 00008b41a4]              BRK ==> [00008b1000 - 00008b41a4]
[    0.000000]   #7 [0000007000 - 0000008000]          PGTABLE ==> [0000007000 - 0000008000]
[    0.000000]   #8 [0000008000 - 000000c000]          BOOTMAP ==> [0000008000 - 000000c000]
[    0.000000] Zone PFN ranges:
[    0.000000]   DMA      0x00000000 -> 0x00001000
[    0.000000]   Normal   0x00001000 -> 0x0001fff0
[    0.000000]   HighMem  0x0001fff0 -> 0x0001fff0
[    0.000000] Movable zone start PFN for each node
[    0.000000] early_node_map[3] active PFN ranges
[    0.000000]     0: 0x00000000 -> 0x00000002
[    0.000000]     0: 0x00000006 -> 0x0000009f
[    0.000000]     0: 0x00000100 -> 0x0001fff0
[    0.000000] On node 0 totalpages: 130955
[    0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c1001000
[    0.000000]   DMA zone: 32 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 3963 pages, LIFO batch:0
[    0.000000]   Normal zone: 992 pages used for memmap
[    0.000000]   Normal zone: 125968 pages, LIFO batch:31
[    0.000000] Using APIC driver default
[    0.000000] ACPI: PM-Timer IO Port: 0x1008
[    0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[    0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[    0.000000] APIC: disable apic facility
[    0.000000] nr_irqs_gsi: 16
[    0.000000] Allocating PCI resources starting at 20000000 (gap: 20000000:dfb80000)
[    0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[    0.000000] PERCPU: Embedded 24 pages/cpu @c1800000 s74936 r0 d23368 u4194304
[    0.000000] pcpu-alloc: s74936 r0 d23368 u4194304 alloc=1*4194304
  • 0
    [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 129931
    [    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=76d29437-0acb-41e2-b446-0ce41444c6a4 ro quiet splash
    [    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
    [    0.000000] Enabling fast FPU save and restore... done.
    [    0.000000] Enabling unmasked SIMD FPU exception support... done.
    [    0.000000] Initializing CPU#0
    [    0.000000] allocated 2621120 bytes of page_cgroup
    [    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
    [    0.000000] Initializing HighMem for node 0 (00000000:00000000)
    [    0.000000] Memory: 495624k/524224k available (4539k kernel code, 27920k reserved, 1928k data, 620k init, 0k highmem)
    [    0.000000] virtual kernel memory layout:
    [    0.000000]     fixmap  : 0xfff1e000 - 0xfffff000   ( 900 kB)
    [    0.000000]     pkmap   : 0xff800000 - 0xffc00000   (4096 kB)
    [    0.000000]     vmalloc : 0xe07f0000 - 0xff7fe000   ( 496 MB)
    [    0.000000]     lowmem  : 0xc0000000 - 0xdfff0000   ( 511 MB)
    [    0.000000]       .init : 0xc0751000 - 0xc07ec000   ( 620 kB)
    [    0.000000]       .data : 0xc056ecbc - 0xc0750e68   (1928 kB)
    [    0.000000]       .text : 0xc0100000 - 0xc056ecbc   (4539 kB)
    [    0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
    [    0.000000] SLUB: Genslabs=13, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    [    0.000000] Hierarchical RCU implementation.
    [    0.000000] NR_IRQS:2304 nr_irqs:256
    [    0.000000] I-pipe 2.6-03: pipeline enabled.
    [    0.000000] Console: colour VGA+ 80x25
    [    0.000000] console [tty0] enabled
    [    0.000000] Fast TSC calibration using PIT
    [    0.000000] Detected 1593.474 MHz processor.
    [    0.008009] Calibrating delay loop (skipped), value calculated using timer frequency.. 3186.94 BogoMIPS (lpj=6373896)
    [    0.008046] Security Framework initialized
    [    0.008097] AppArmor: AppArmor initialized
    [    0.008115] Mount-cache hash table entries: 512
    [    0.008356] Initializing cgroup subsys ns
    [    0.008368] Initializing cgroup subsys cpuacct
    [    0.008374] Initializing cgroup subsys memory
    [    0.008391] Initializing cgroup subsys devices
    [    0.008395] Initializing cgroup subsys freezer
    [    0.008399] Initializing cgroup subsys net_cls
    [    0.008443] CPU: L1 I cache: 32K, L1 D cache: 32K
    [    0.008452] mce: CPU supports 5 MCE banks
    [    0.008479] Performance Events:
    [    0.008483] no APIC, boot with the "lapic" boot parameter to force-enable it.
    [    0.008486] no hardware sampling interrupt available.
    [    0.008490] p6 PMU driver.
    [    0.008510] ... version:                0
    [    0.008512] ... bit width:              32
    [    0.008515] ... generic registers:      2
    [    0.008518] ... value mask:             00000000ffffffff
    [    0.008521] ... max period:             000000007fffffff
    [    0.008524] ... fixed-purpose events:   0
    [    0.008527] ... event mask:             0000000000000003
    [    0.008536] Checking 'hlt' instruction... OK.
    [    0.025188] SMP alternatives: switching to UP code
    [    0.033467] Freeing SMP alternatives: 31k freed
    [    0.033511] ACPI: Core revision 20090903
    [    0.042790] ACPI: setting ELCR to 0200 (from 0c28)
    [    0.044031] ftrace: converting mcount calls to 0f 1f 44 00 00
    [    0.044046] ftrace: allocating 21003 entries in 42 pages
    [    0.055786] Enabling APIC mode:  Flat.  Using 0 I/O APICs
    [    0.055794] weird, boot CPU (#0) not listed by the BIOS.
    [    0.055796] SMP motherboard not detected.
    [    0.055800] Local APIC not detected. Using dummy APIC emulation.
    [    0.055803] SMP disabled
    [    0.056256] Brought up 1 CPUs
    [    0.056264] Total of 1 processors activated (3186.94 BogoMIPS).
    [    0.056469] CPU0 attaching NULL sched-domain.
    [    0.056891] devtmpfs: initialized
    [    0.057609] regulator: core version 0.5
    [    0.057745] NET: Registered protocol family 16
    [    0.058018] EISA bus registered
    [    0.058052] ACPI: bus type pci registered
    [    0.058242] PCI: PCI BIOS revision 2.10 entry at 0xe99e4, last bus=2
    [    0.058248] PCI: Using configuration type 1 for base access
    [    0.059698] bio: create slab <bio-0> at 0
    [    0.060978] ACPI: EC: Look up EC in DSDT
    [    0.065531] ACPI: Interpreter enabled
    [    0.065539] ACPI: (supports S0 S5)
    [    0.065562] ACPI: Using PIC for interrupt routing
    [    0.074996] ACPI: EC: GPE = 0x18, I/O: command/status = 0x66, data = 0x62
    [    0.075298] ACPI: No dock devices found.
    [    0.075817] ACPI: PCI Root Bridge [PCI0] (0000:00)
    [    0.075918] pci 0000:00:00.0: reg 10 32bit mmio pref: [0xb0000000-0xb3ffffff]
    [    0.076098] pci 0000:00:1d.0: reg 20 io port: [0x1200-0x121f]
    [    0.076157] pci 0000:00:1d.1: reg 20 io port: [0x1600-0x161f]
    [    0.076222] pci 0000:00:1d.2: reg 20 io port: [0x1700-0x171f]
    [    0.076287] pci 0000:00:1d.7: reg 10 32bit mmio: [0xf0000000-0xf00003ff]
    [    0.076347] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
    [    0.076353] pci 0000:00:1d.7: PME# disabled
    [    0.076446] pci 0000:00:1f.0: quirk: region 1000-107f claimed by ICH4 ACPI/GPIO/TCO
    [    0.076451] pci 0000:00:1f.0: quirk: region 1300-133f claimed by ICH4 GPIO
    [    0.076477] pci 0000:00:1f.1: reg 10 io port: [0x00-0x07]
    [    0.076485] pci 0000:00:1f.1: reg 14 io port: [0x00-0x03]
    [    0.076493] pci 0000:00:1f.1: reg 18 io port: [0x00-0x07]
    [    0.076501] pci 0000:00:1f.1: reg 1c io port: [0x00-0x03]
    [    0.076509] pci 0000:00:1f.1: reg 20 io port: [0x1100-0x110f]
    [    0.076517] pci 0000:00:1f.1: reg 24 32bit mmio: [0x000000-0x0003ff]
    [    0.076571] pci 0000:00:1f.3: reg 20 io port: [0x1400-0x141f]
    [    0.076617] pci 0000:00:1f.5: reg 10 io port: [0xe000-0xe0ff]
    [    0.076625] pci 0000:00:1f.5: reg 14 io port: [0xe100-0xe13f]
    [    0.076632] pci 0000:00:1f.5: reg 18 32bit mmio: [0xf0000400-0xf00005ff]
    [    0.076640] pci 0000:00:1f.5: reg 1c 32bit mmio: [0xf0000600-0xf00006ff]
    [    0.076672] pci 0000:00:1f.5: PME# supported from D0 D3hot D3cold
    [    0.076677] pci 0000:00:1f.5: PME# disabled
    [    0.076709] pci 0000:00:1f.6: reg 10 io port: [0xe200-0xe2ff]
    [    0.076717] pci 0000:00:1f.6: reg 14 io port: [0xe300-0xe37f]
    [    0.076756] pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
    [    0.076761] pci 0000:00:1f.6: PME# disabled
    [    0.076805] pci 0000:01:00.0: reg 10 32bit mmio: [0xe1000000-0xe1ffffff]
    [    0.076813] pci 0000:01:00.0: reg 14 32bit mmio pref: [0xa0000000-0xa7ffffff]
    [    0.076832] pci 0000:01:00.0: reg 30 32bit mmio pref: [0x000000-0x01ffff]
    [    0.076888] pci 0000:00:01.0: bridge io port: [0xc000-0xdfff]
    [    0.076893] pci 0000:00:01.0: bridge 32bit mmio: [0xe0000000-0xefffffff]
    [    0.076898] pci 0000:00:01.0: bridge 32bit mmio pref: [0xa0000000-0xafffffff]
    [    0.076938] pci 0000:02:01.0: reg 10 32bit mmio: [0xd0009000-0xd0009fff]
    [    0.077017] pci 0000:02:02.0: reg 10 io port: [0xa000-0xa0ff]
    [    0.077025] pci 0000:02:02.0: reg 14 32bit mmio: [0xd0008000-0xd00080ff]
    [    0.077066] pci 0000:02:02.0: supports D1 D2
    [    0.077069] pci 0000:02:02.0: PME# supported from D1 D2 D3hot D3cold
    [    0.077074] pci 0000:02:02.0: PME# disabled
    [    0.077110] pci 0000:02:03.0: reg 10 32bit mmio: [0x000000-0x000fff]
    [    0.077130] pci 0000:02:03.0: supports D1 D2
    [    0.077133] pci 0000:02:03.0: PME# supported from D0 D1 D2 D3hot D3cold
    [    0.077138] pci 0000:02:03.0: PME# disabled
    [    0.077173] pci 0000:02:03.1: reg 10 32bit mmio: [0xd0000000-0xd00007ff]
    [    0.077182] pci 0000:02:03.1: reg 14 32bit mmio: [0xd0004000-0xd0007fff]
    [    0.077223] pci 0000:02:03.1: supports D1 D2
    [    0.077226] pci 0000:02:03.1: PME# supported from D0 D1 D2 D3hot
    [    0.077231] pci 0000:02:03.1: PME# disabled
    [    0.077279] pci 0000:00:1e.0: transparent bridge
    [    0.077285] pci 0000:00:1e.0: bridge io port: [0xa000-0xbfff]
    [    0.077290] pci 0000:00:1e.0: bridge 32bit mmio: [0xd0000000-0xdfffffff]
    [    0.077296] pci 0000:00:1e.0: bridge 32bit mmio pref: [0x90000000-0x9fffffff]
    [    0.077326] pci_bus 0000:00: on NUMA node 0
    [    0.077350] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
    [    0.077445] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
    [    0.077490] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI2._PRT]
    [    0.082929] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 5 7 9 *10 11)
    [    0.083190] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 *5 7 9 10 11)
    [    0.083445] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 5 7 9 10 *11)
    [    0.083699] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 5 7 *11)
    [    0.083941] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 10 *11)
    [    0.084243] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 5 7 9 10 *11)
    [    0.084457] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 9 10 11 14 15) *0, disabled.
    [    0.084694] ACPI: PCI Interrupt Link [LNKH] (IRQs *3 5 7 9 10 11)
    [    0.084964] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
    [    0.084975] vgaarb: loaded
    [    0.085267] SCSI subsystem initialized
    [    0.085498] libata version 3.00 loaded.
    [    0.085782] usbcore: registered new interface driver usbfs
    [    0.085810] usbcore: registered new interface driver hub
    [    0.085963] usbcore: registered new device driver usb
    [    0.086458] ACPI: WMI: Mapper loaded
    [    0.086465] PCI: Using ACPI for IRQ routing
    [    0.086777] NetLabel: Initializing
    [    0.086785] NetLabel:  domain hash size = 128
    [    0.086787] NetLabel:  protocols = UNLABELED CIPSOv4
    [    0.086811] NetLabel:  unlabeled traffic allowed by default
    [    0.086926] Switching to clocksource tsc
    [    0.087997] AppArmor: AppArmor Filesystem Enabled
    [    0.087997] pnp: PnP ACPI init
    [    0.087997] ACPI: bus type pnp registered
    [    0.091896] pnp: PnP ACPI: found 11 devices
    [    0.091904] ACPI: ACPI bus type pnp unregistered
    [    0.091911] PnPBIOS: Disabled by ACPI PNP
    [    0.091947] system 00:05: iomem range 0xfff00000-0xfff7ffff has been reserved
    [    0.091952] system 00:05: iomem range 0xfff80000-0xffffffff has been reserved
    [    0.091966] system 00:07: ioport range 0x680-0x6ff has been reserved
    [    0.091970] system 00:07: ioport range 0x200-0x20f has been reserved
    [    0.091974] system 00:07: ioport range 0x1000-0x107f has been reserved
    [    0.091979] system 00:07: ioport range 0x1300-0x133f has been reserved
    [    0.126976] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
    [    0.126984] pci 0000:00:01.0:   IO window: 0xc000-0xdfff
    [    0.126990] pci 0000:00:01.0:   MEM window: 0xe0000000-0xefffffff
    [    0.126996] pci 0000:00:01.0:   PREFETCH window: 0xa0000000-0xafffffff
    [    0.127011] pci 0000:02:03.0: CardBus bridge, secondary bus 0000:03
    [    0.127015] pci 0000:02:03.0:   IO window: 0x00a400-0x00a4ff
    [    0.127020] pci 0000:02:03.0:   IO window: 0x00a800-0x00a8ff
    [    0.127025] pci 0000:02:03.0:   PREFETCH window: 0x90000000-0x93ffffff
    [    0.127031] pci 0000:02:03.0:   MEM window: 0xd4000000-0xd7ffffff
    [    0.127036] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:02
    [    0.127041] pci 0000:00:1e.0:   IO window: 0xa000-0xbfff
    [    0.127047] pci 0000:00:1e.0:   MEM window: 0xd0000000-0xdfffffff
    [    0.127053] pci 0000:00:1e.0:   PREFETCH window: 0x90000000-0x9fffffff
    [    0.127077] pci 0000:00:1e.0: setting latency timer to 64
    [    0.127490] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
    [    0.127498] PCI: setting IRQ 11 as level-triggered
    [    0.127505] pci 0000:02:03.0: PCI INT A -> Link[LNKC] -> GSI 11 (level, low) -> IRQ 11
    [    0.127520] pci_bus 0000:00: resource 0 io:  [0x00-0xffff]
    [    0.127523] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
    [    0.127528] pci_bus 0000:01: resource 0 io:  [0xc000-0xdfff]
    [    0.127532] pci_bus 0000:01: resource 1 mem: [0xe0000000-0xefffffff]
    [    0.127535] pci_bus 0000:01: resource 2 pref mem [0xa0000000-0xafffffff]
    [    0.127540] pci_bus 0000:02: resource 0 io:  [0xa000-0xbfff]
    [    0.127544] pci_bus 0000:02: resource 1 mem: [0xd0000000-0xdfffffff]
    [    0.127548] pci_bus 0000:02: resource 2 pref mem [0x90000000-0x9fffffff]
    [    0.127551] pci_bus 0000:02: resource 3 io:  [0x00-0xffff]
    [    0.127555] pci_bus 0000:02: resource 4 mem: [0x000000-0xffffffff]
    [    0.127559] pci_bus 0000:03: resource 0 io:  [0xa400-0xa4ff]
    [    0.127562] pci_bus 0000:03: resource 1 io:  [0xa800-0xa8ff]
    [    0.127566] pci_bus 0000:03: resource 2 pref mem [0x90000000-0x93ffffff]
    [    0.127570] pci_bus 0000:03: resource 3 mem: [0xd4000000-0xd7ffffff]
    [    0.127636] NET: Registered protocol family 2
    [    0.127787] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.128230] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
    [    0.128445] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
    [    0.128661] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.128666] TCP reno registered
    [    0.128827] NET: Registered protocol family 1
    [    0.129012] pci 0000:01:00.0: Boot video device
    [    0.129187] Simple Boot Flag at 0x37 set to 0x1
    [    0.129372] Scanning for low memory corruption every 60 seconds
    [    0.129628] audit: initializing netlink socket (disabled)
    [    0.129664] type=2000 audit(1424638025.128:1): initialized
    [    0.141881] Trying to unpack rootfs image as initramfs...
    [    0.157210] HugeTLB registered 4 MB page size, pre-allocated 0 pages
    [    0.159747] VFS: Disk quotas dquot_6.5.2
    [    0.159915] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    0.165077] fuse init (API version 7.13)
    [    0.165377] msgmni has been set to 968
    [    0.166116] alg: No test for stdrng (krng)
    [    0.166327] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
    [    0.166335] io scheduler noop registered
    [    0.166338] io scheduler anticipatory registered
    [    0.166341] io scheduler deadline registered
    [    0.166485] io scheduler cfq registered (default)
    [    0.166718] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
    [    0.166762] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
    [    0.166910] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
    [    0.167320] ACPI: Lid Switch [LID]
    [    0.167460] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
    [    0.167473] ACPI: Sleep Button [SLPB]
    [    0.167623] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
    [    0.167630] ACPI: Power Button [PWRF]
    [    0.177036] isapnp: Scanning for PnP cards...
    [    0.183056] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    0.184266] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 5
    [    0.184274] PCI: setting IRQ 5 as level-triggered
    [    0.184281] serial 0000:00:1f.6: PCI INT B -> Link[LNKB] -> GSI 5 (level, low) -> IRQ 5
    [    0.184295] serial 0000:00:1f.6: PCI INT B disabled
    [    0.191500] brd: module loaded
    [    0.192820] loop: module loaded
    [    0.236717] input: Macintosh mouse button emulation as /devices/virtual/input/input3
    [    0.237009] ata_piix 0000:00:1f.1: version 2.13
    [    0.237032] ata_piix 0000:00:1f.1: enabling device (0005 -> 0007)
    [    0.237043] ata_piix 0000:00:1f.1: PCI INT A -> Link[LNKC] -> GSI 11 (level, low) -> IRQ 11
    [    0.237127] ata_piix 0000:00:1f.1: setting latency timer to 64
    [    0.241163] scsi0 : ata_piix
    [    0.241481] scsi1 : ata_piix
    [    0.243084] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x1100 irq 14
    [    0.243092] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x1108 irq 15
    [    0.243833] Fixed MDIO Bus: probed
    [    0.243908] PPP generic driver version 2.4.2
    [    0.244040] tun: Universal TUN/TAP device driver, 1.6
    [    0.244045] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
    [    0.244352] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    0.244783] ACPI: PCI Interrupt Link [LNKH] enabled at IRQ 3
    [    0.244791] PCI: setting IRQ 3 as level-triggered
    [    0.244798] ehci_hcd 0000:00:1d.7: PCI INT D -> Link[LNKH] -> GSI 3 (level, low) -> IRQ 3
    [    0.244828] ehci_hcd 0000:00:1d.7: setting latency timer to 64
    [    0.244833] ehci_hcd 0000:00:1d.7: EHCI Host Controller
    [    0.245316] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
    [    0.245375] ehci_hcd 0000:00:1d.7: debug port 1
    [    0.249262] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported
    [    0.257015] ehci_hcd 0000:00:1d.7: irq 3, io mem 0xf0000000
    [    0.277145] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
    [    0.277421] usb usb1: configuration #1 chosen from 1 choice
    [    0.277495] hub 1-0:1.0: USB hub found
    [    0.277523] hub 1-0:1.0: 6 ports detected
    [    0.277665] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    [    0.277708] uhci_hcd: USB Universal Host Controller Interface driver
    [    0.278203] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 10
    [    0.278211] PCI: setting IRQ 10 as level-triggered
    [    0.278218] uhci_hcd 0000:00:1d.0: PCI INT A -> Link[LNKA] -> GSI 10 (level, low) -> IRQ 10
    [    0.278233] uhci_hcd 0000:00:1d.0: setting latency timer to 64
    [    0.278238] uhci_hcd 0000:00:1d.0: UHCI Host Controller
    [    0.278406] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
    [    0.278450] uhci_hcd 0000:00:1d.0: irq 10, io base 0x00001200
    [    0.278717] usb usb2: configuration #1 chosen from 1 choice
    [    0.278789] hub 2-0:1.0: USB hub found
    [    0.278816] hub 2-0:1.0: 2 ports detected
    [    0.279317] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11
    [    0.279328] uhci_hcd 0000:00:1d.1: PCI INT B -> Link[LNKD] -> GSI 11 (level, low) -> IRQ 11
    [    0.279344] uhci_hcd 0000:00:1d.1: setting latency timer to 64
    [    0.279349] uhci_hcd 0000:00:1d.1: UHCI Host Controller
    [    0.279491] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
    [    0.279536] uhci_hcd 0000:00:1d.1: irq 11, io base 0x00001600
    [    0.279798] usb usb3: configuration #1 chosen from 1 choice
    [    0.279870] hub 3-0:1.0: USB hub found
    [    0.279898] hub 3-0:1.0: 2 ports detected
    [    0.280019] uhci_hcd 0000:00:1d.2: PCI INT C -> Link[LNKC] -> GSI 11 (level, low) -> IRQ 11
    [    0.280035] uhci_hcd 0000:00:1d.2: setting latency timer to 64
    [    0.280041] uhci_hcd 0000:00:1d.2: UHCI Host Controller
    [    0.280173] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
    [    0.280214] uhci_hcd 0000:00:1d.2: irq 11, io base 0x00001700
    [    0.280463] usb usb4: configuration #1 chosen from 1 choice
    [    0.280547] hub 4-0:1.0: USB hub found
    [    0.280575] hub 4-0:1.0: 2 ports detected
    [    0.280771] PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
    [    0.285645] i8042.c: Detected active multiplexing controller, rev 1.1.
    [    0.295212] serio: i8042 KBD port at 0x60,0x64 irq 1
    [    0.295237] serio: i8042 AUX0 port at 0x60,0x64 irq 12
    [    0.301251] serio: i8042 AUX1 port at 0x60,0x64 irq 12
    [    0.301370] serio: i8042 AUX2 port at 0x60,0x64 irq 12
    [    0.301443] serio: i8042 AUX3 port at 0x60,0x64 irq 12
    [    0.301884] mice: PS/2 mouse device common for all mice
    [    0.302624] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
    [    0.302656] rtc0: alarms up to one month, 242 bytes nvram
    [    0.302967] device-mapper: uevent: version 1.0.3
    [    0.303372] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: dm-devel@redhat.com
    [    0.304483] device-mapper: multipath: version 1.1.0 loaded
    [    0.304493] device-mapper: multipath round-robin: version 1.0.0 loaded
    [    0.349485] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
    [    0.350008] EISA: Probing bus 0 at eisa.0
    [    0.350020] Cannot allocate resource for EISA slot 1
    [    0.350050] EISA: Detected 0 cards.
    [    0.350055] cpuidle: using governor ladder
    [    0.350058] cpuidle: using governor menu
    [    0.350725] TCP cubic registered
    [    0.351172] NET: Registered protocol family 10
    [    0.351998] lo: Disabled Privacy Extensions
    [    0.352440] NET: Registered protocol family 17
    [    0.352542] Using IPI No-Shortcut mode
    [    0.352846] registered taskstats version 1
    [    0.356227] rtc_cmos 00:03: setting system clock to 2015-02-22 20:47:06 UTC (1424638026)
    [    0.356235] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
    [    0.356238] EDD information not available.
    [    0.445508] ata1.00: ATA-7: SAMSUNG MP0402H, UC100-11, max UDMA/100
    [    0.445515] ata1.00: 78242976 sectors, multi 16: LBA48
    [    0.445553] ata1.00: limited to UDMA/33 due to 40-wire cable
    [    0.453665] ata2.00: ATAPI: MATSHITAUJ-815A, D100, max UDMA/66
    [    0.453701] ata2.00: limited to UDMA/33 due to 40-wire cable
    [    0.461675] ata1.00: configured for UDMA/33
    [    0.469319] ata2.00: configured for UDMA/33
    [    0.880591] isapnp: No Plug & Play device found
    [    0.881021] scsi 0:0:0:0: Direct-Access     ATA      SAMSUNG MP0402H  UC10 PQ: 0 ANSI: 5
    [    0.881391] sd 0:0:0:0: Attached scsi generic sg0 type 0
    [    0.881975] sd 0:0:0:0: [sda] 78242976 512-byte logical blocks: (40.0 GB/37.3 GiB)
    [    0.882280] sd 0:0:0:0: [sda] Write Protect is off
    [    0.882288] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
    [    0.882438] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
    [    0.883451]  sda:
    [    0.883728] scsi 1:0:0:0: CD-ROM            MATSHITA UJ-815A          D100 PQ: 0 ANSI: 5
    [    0.891579] sr0: scsi3-mmc drive: 24x/24x writer cd/rw xa/form2 cdda caddy
    [    0.891589] Uniform CD-ROM driver Revision: 3.20
    [    0.891823] sr 1:0:0:0: Attached scsi CD-ROM sr0
    [    0.892011] sr 1:0:0:0: Attached scsi generic sg1 type 5
    [    0.896678]  sda1 sda2 < sda5 sda6
    [    0.933195] usb 2-1: new low speed USB device using uhci_hcd and address 2
    [    0.950118]  sda7 >
    [    0.951359] sd 0:0:0:0: [sda] Attached SCSI disk
    [    1.106113] usb 2-1: configuration #1 chosen from 1 choice
    [    1.282561] Freeing initrd memory: 12845k freed
    [    1.296478] Freeing unused kernel memory: 620k freed
    [    1.297229] Write protecting the kernel text: 4540k
    [    1.297265] Write protecting the kernel read-only data: 1668k
    [    1.352114] usb 3-1: new low speed USB device using uhci_hcd and address 2
    [    1.356687] udev: starting version 151
    [    1.564679] usb 3-1: configuration #1 chosen from 1 choice
    [    2.137390] Linux agpgart interface v0.103
    [    2.194896] usbcore: registered new interface driver hiddev
    [    2.221217] input:  USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1:1.0/input/input5
    [    2.223095] generic-usb 0003:0000:0538.0001: input,hidraw0: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.0-1/input0
    [    2.233279] agpgart-intel 0000:00:00.0: Intel 855PM Chipset
    [    2.238071] input: USB USB Keykoard as /devices/pci0000:00/0000:00:1d.1/usb3/3-1/3-1:1.0/input/input6
    [    2.238790] generic-usb 0003:1A2C:0027.0002: input,hidraw1: USB HID v1.10 Keyboard [USB USB Keykoard] on usb-0000:00:1d.1-1/input0
    [    2.249322] agpgart-intel 0000:00:00.0: AGP aperture is 64M @ 0xb0000000
    [    2.260866] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:00/LNXVIDEO:00/input/input7
    [    2.261234] ACPI: Video Device [VID] (multi-head: yes  rom: no  post: no)
    [    2.275031] vga16fb: initializing
    [    2.275045] vga16fb: mapped to 0xc00a0000
    [    2.275423] fb0: VGA16 VGA frame buffer device
    [    2.299015] 8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004)
    [    2.299072] 8139cp 0000:02:02.0: This (id 10ec:8139 rev 10) is not an 8139C+ compatible chip, use 8139too
    [    2.327019] ACPI: PCI Interrupt Link [LNKF] enabled at IRQ 11
    [    2.327030] ohci1394 0000:02:03.1: PCI INT B -> Link[LNKF] -> GSI 11 (level, low) -> IRQ 11
    [    2.354779] 8139too Fast Ethernet driver 0.9.28
    [    2.481505] ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[11]  MMIO=[d0000000-d00007ff]  Max Packet=[2048]  IR/IT contexts=[4/8]
    [    2.488452] 8139too 0000:02:02.0: PCI INT A -> Link[LNKD] -> GSI 11 (level, low) -> IRQ 11
    [    2.489797] eth0: RealTek RTL8139 at 0xa000, 00:40:d0:3d:ab:a8, IRQ 11
    [    2.553238] Console: switching to colour frame buffer device 80x30
    [    3.760344] ieee1394: Host added: ID:BUS[0-00:1023]  GUID[0040d0010013af8a]
    [   12.258026] /home/moses/Projects/emc2/ubuntu-lucid/drivers/hid/usbhid/hid-core.c: usb_submit_urb(ctrl) failed
    [   12.258068] generic-usb 0003:1A2C:0027.0003: timeout initializing reports
    [   12.258291] input: USB USB Keykoard as /devices/pci0000:00/0000:00:1d.1/usb3/3-1/3-1:1.1/input/input8
    [   12.258589] generic-usb 0003:1A2C:0027.0003: input,hidraw2: USB HID v1.10 Device [USB USB Keykoard] on usb-0000:00:1d.1-1/input1
    [   12.258654] usbcore: registered new interface driver usbhid
    [   12.258661] usbhid: v2.6:USB HID core driver
    [   12.700125] xor: automatically using best checksumming function: pIII_sse
    [   12.720022]    pIII_sse  :  4255.000 MB/sec
    [   12.720027] xor: using function: pIII_sse (4255.000 MB/sec)
    [   12.756887] device-mapper: dm-raid45: initialized v0.2594b
    [   13.425734] EXT4-fs (sda6): mounted filesystem with ordered data mode
    [   33.140974] Adding 495608k swap on /dev/sda7.  Priority:-1 extents:1 across:495608k
    [   33.668560] udev: starting version 151
    [   34.245039] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
    [   34.482850] intel_rng: FWH not detected
    [   35.657343] type=1505 audit(1424630861.799:2):  operation="profile_load" pid=609 name="/sbin/dhclient3"
    [   35.658292] type=1505 audit(1424630861.799:3):  operation="profile_load" pid=609 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
    [   35.658817] type=1505 audit(1424630861.799:4):  operation="profile_load" pid=609 name="/usr/lib/connman/scripts/dhclient-script"
    [   35.660856] type=1505 audit(1424630861.803:5):  operation="profile_replace" pid=611 name="/sbin/dhclient3"
    [   35.661838] type=1505 audit(1424630861.803:6):  operation="profile_replace" pid=611 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
    [   35.662380] type=1505 audit(1424630861.803:7):  operation="profile_replace" pid=611 name="/usr/lib/connman/scripts/dhclient-script"
    [   35.984523] type=1505 audit(1424630862.127:8):  operation="profile_load" pid=676 name="/usr/share/gdm/guest-session/Xsession"
    [   36.000279] type=1505 audit(1424630862.143:9):  operation="profile_replace" pid=679 name="/sbin/dhclient3"
    [   36.001259] type=1505 audit(1424630862.143:10):  operation="profile_replace" pid=679 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
    [   36.001804] type=1505 audit(1424630862.143:11):  operation="profile_replace" pid=679 name="/usr/lib/connman/scripts/dhclient-script"
    [   36.318075] nvidia: module license 'NVIDIA' taints kernel.
    [   36.318084] Disabling lock debugging due to kernel taint
    [   37.168650] lib80211: common routines for IEEE802.11 drivers
    [   37.168662] lib80211_crypt: registered algorithm 'NULL'
    [   37.261971] parport_pc 00:0a: reported by Plug and Play ACPI
    [   37.262080] parport0: PC-style at 0x378 (0x778), irq 7, dma 1 [PCSPP,TRISTATE,COMPAT,EPP,ECP,DMA]
    [   37.269242] nvidia 0000:01:00.0: PCI INT A -> Link[LNKA] -> GSI 10 (level, low) -> IRQ 10
    [   37.271743] NVRM: loading NVIDIA UNIX x86 Kernel Module  173.14.22  Sun Nov  8 20:26:31 PST 2009
    [   37.337033] ieee80211: 802.11 data/management/control stack, git-1.1.13
    [   37.337043] ieee80211: Copyright (C) 2004-2005 Intel Corporation <jketreno@linux.intel.com>
    [   37.429919] lp0: using parport0 (interrupt-driven).
    [   37.586154] ipw2100: Intel(R) PRO/Wireless 2100 Network Driver, git-1.2.2
    [   37.586164] ipw2100: Copyright(c) 2003-2006 Intel Corporation
    [   37.591694] ACPI: PCI Interrupt Link [LNKE] enabled at IRQ 11
    [   37.591706] ipw2100 0000:02:01.0: PCI INT A -> Link[LNKE] -> GSI 11 (level, low) -> IRQ 11
    [   37.592984] ipw2100: Detected Intel PRO/Wireless 2100 Network Connection
    [   37.593017] ipw2100 0000:02:01.0: firmware: requesting ipw2100-1.3.fw
    [   37.610595] ppdev: user-space parallel port driver
    [   37.960718] eth0: link down
    [   37.960878] ADDRCONF(NETDEV_UP): eth0: link is not ready
    [   37.980818] yenta_cardbus 0000:02:03.0: CardBus bridge found [1071:8160]
    [   37.980842] yenta_cardbus 0000:02:03.0: Using CSCINT to route CSC interrupts to PCI
    [   37.980846] yenta_cardbus 0000:02:03.0: Routing CardBus interrupts to PCI
    [   37.980853] yenta_cardbus 0000:02:03.0: TI: mfunc 0x01001c22, devctl 0x64
    [   38.072142] ADDRCONF(NETDEV_UP): eth1: link is not ready
    [   38.213113] yenta_cardbus 0000:02:03.0: ISA IRQ mask 0x0050, PCI irq 11
    [   38.213121] yenta_cardbus 0000:02:03.0: Socket status: 30000086
    [   38.213128] pci_bus 0000:02: Raising subordinate bus# of parent bus (#02) from #02 to #06
    [   38.213147] yenta_cardbus 0000:02:03.0: pcmcia: parent PCI bridge I/O window: 0xa000 - 0xbfff
    [   38.213153] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa000-0xbfff: clean.
    [   38.213804] yenta_cardbus 0000:02:03.0: pcmcia: parent PCI bridge Memory window: 0xd0000000 - 0xdfffffff
    [   38.213809] yenta_cardbus 0000:02:03.0: pcmcia: parent PCI bridge Memory window: 0x90000000 - 0x9fffffff
    [   38.791916] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af: clean.
    [   38.793949] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff: excluding 0x4d0-0x4d7
    [   38.794847] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff: clean.
    [   38.795605] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7: clean.
    [   38.800962] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff: clean.
    [   39.154434] Intel ICH 0000:00:1f.5: PCI INT B -> Link[LNKB] -> GSI 5 (level, low) -> IRQ 5
    [   39.154538] Intel ICH 0000:00:1f.5: setting latency timer to 64
    [   39.984064] intel8x0_measure_ac97_clock: measured 55198 usecs (2659 samples)
    [   39.984071] intel8x0: clocking to 48000
    [   41.946106] agpgart-intel 0000:00:00.0: AGP 2.0 bridge
    [   41.946128] agpgart-intel 0000:00:00.0: putting AGP V2 device into 4x mode
    [   41.946172] nvidia 0000:01:00.0: putting AGP V2 device into 4x mode
    [   79.308191] ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
    [   80.597577] lib80211_crypt: registered algorithm 'CCMP'
    [   80.621885] padlock: VIA PadLock not detected.
    [   89.892047] eth1: no IPv6 routers present
    [  409.898361] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
    [  927.031603] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
    [  928.609069] __ratelimit: 18 callbacks suppressed
    [  928.609079] halcmd[1938]: segfault at 8 ip 001a96bc sp bf8b5ee0 error 6 in liblinuxcnchal.so.0[1a4000+8000]
    [  928.624139] halcmd[1939]: segfault at 8 ip 0058d6bc sp bfc8bed0 error 6 in liblinuxcnchal.so.0[588000+8000]
    [  928.652209] halcmd[1942]: segfault at 8 ip 007066bc sp bffa5d70 error 6 in liblinuxcnchal.so.0[701000+8000]
    [  928.911762] halcmd[1946]: segfault at 8 ip 006856bc sp bfebdee0 error 6 in liblinuxcnchal.so.0[680000+8000]
    [  929.130914] halcmd[1950]: segfault at 8 ip 003126bc sp bf993620 error 6 in liblinuxcnchal.so.0[30d000+8000]
    [  929.350117] halcmd[1954]: segfault at 8 ip 002b16bc sp bff7c8f0 error 6 in liblinuxcnchal.so.0[2ac000+8000]
    [  929.569313] halcmd[1958]: segfault at 8 ip 00a476bc sp bfb66cc0 error 6 in liblinuxcnchal.so.0[a42000+8000]
    [  929.790081] halcmd[1962]: segfault at 8 ip 00fd56bc sp bf9c8ca0 error 6 in liblinuxcnchal.so.0[fd0000+8000]
    [  930.009242] halcmd[1966]: segfault at 8 ip 0035d6bc sp bfc9c9d0 error 6 in liblinuxcnchal.so.0[358000+8000]
    [  930.228230] halcmd[1970]: segfault at 8 ip 008306bc sp bf9e2c90 error 6 in liblinuxcnchal.so.0[82b000+8000]
    [ 1448.635027] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
    [ 1450.147278] __ratelimit: 2 callbacks suppressed
    [ 1450.147286] halcmd[2460]: segfault at 8 ip 0097f6bc sp bfcd9580 error 6 in liblinuxcnchal.so.0[97a000+8000]
    [ 1450.155752] halcmd[2461]: segfault at 8 ip 003e46bc sp bfa89e60 error 6 in liblinuxcnchal.so.0[3df000+8000]
    [ 1450.174498] halcmd[2464]: segfault at 8 ip 004c66bc sp bfc9a3d0 error 6 in liblinuxcnchal.so.0[4c1000+8000]
    [ 1450.393489] halcmd[2468]: segfault at 8 ip 007f36bc sp bfd06220 error 6 in liblinuxcnchal.so.0[7ee000+8000]
    [ 1450.612762] halcmd[2472]: segfault at 8 ip 0058c6bc sp bfccd3a0 error 6 in liblinuxcnchal.so.0[587000+8000]
    [ 1450.835045] halcmd[2476]: segfault at 8 ip 0099c6bc sp bfb5d490 error 6 in liblinuxcnchal.so.0[997000+8000]
    [ 1451.054328] halcmd[2480]: segfault at 8 ip 00a046bc sp bfdb5320 error 6 in liblinuxcnchal.so.0[9ff000+8000]
    [ 1451.273308] halcmd[2484]: segfault at 8 ip 00f6e6bc sp bf82ae80 error 6 in liblinuxcnchal.so.0[f69000+8000]
    [ 1451.492219] halcmd[2488]: segfault at 8 ip 001636bc sp bfec4860 error 6 in liblinuxcnchal.so.0[15e000+8000]
    [ 1451.711273] halcmd[2492]: segfault at 8 ip 008566bc sp bf9aaa40 error 6 in liblinuxcnchal.so.0[851000+8000]
    [ 1964.335367] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
    [ 1966.066215] __ratelimit: 2 callbacks suppressed
    [ 1966.066224] halcmd[2923]: segfault at 8 ip 0049e6bc sp bf953ab0 error 6 in liblinuxcnchal.so.0[499000+8000]
    [ 1966.074683] halcmd[2924]: segfault at 8 ip 00fe66bc sp bf9a02f0 error 6 in liblinuxcnchal.so.0[fe1000+8000]
    [ 1966.109038] halcmd[2927]: segfault at 8 ip 002a56bc sp bfeaa550 error 6 in liblinuxcnchal.so.0[2a0000+8000]
    [ 1966.336396] halcmd[2931]: segfault at 8 ip 00c3f6bc sp bff65650 error 6 in liblinuxcnchal.so.0[c3a000+8000]
    [ 1966.556009] halcmd[2935]: segfault at 8 ip 001fc6bc sp bfcac1e0 error 6 in liblinuxcnchal.so.0[1f7000+8000]
    [ 1966.777116] halcmd[2939]: segfault at 8 ip 00ac66bc sp bffcce80 error 6 in liblinuxcnchal.so.0[ac1000+8000]
    [ 1966.998023] halcmd[2943]: segfault at 8 ip 0076b6bc sp bfbc4570 error 6 in liblinuxcnchal.so.0[766000+8000]
    [ 1967.217646] halcmd[2947]: segfault at 8 ip 00b886bc sp bff6e570 error 6 in liblinuxcnchal.so.0[b83000+8000]
    [ 1967.437300] halcmd[2951]: segfault at 8 ip 001d06bc sp bfca7290 error 6 in liblinuxcnchal.so.0[1cb000+8000]
    [ 1967.656818] halcmd[2955]: segfault at 8 ip 00d326bc sp bfb7bb90 error 6 in liblinuxcnchal.so.0[d2d000+8000]
    [ 1975.028302] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
    [ 1975.952670] __ratelimit: 2 callbacks suppressed
    [ 1975.952680] halcmd[3073]: segfault at 8 ip 00f366bc sp bfba7e60 error 6 in liblinuxcnchal.so.0[f31000+8000]
    [ 1975.961533] halcmd[3074]: segfault at 8 ip 007e26bc sp bfea7920 error 6 in liblinuxcnchal.so.0[7dd000+8000]
    [ 1975.980732] halcmd[3077]: segfault at 8 ip 003296bc sp bf969680 error 6 in liblinuxcnchal.so.0[324000+8000]
    [ 1976.199836] halcmd[3081]: segfault at 8 ip 00ebd6bc sp bfcb8c00 error 6 in liblinuxcnchal.so.0[eb8000+8000]
    [ 1976.419800] halcmd[3085]: segfault at 8 ip 007626bc sp bfe5b380 error 6 in liblinuxcnchal.so.0[75d000+8000]
    [ 1976.639458] halcmd[3089]: segfault at 8 ip 002416bc sp bff86b20 error 6 in liblinuxcnchal.so.0[23c000+8000]
    [ 1976.859147] halcmd[3093]: segfault at 8 ip 002ff6bc sp bfce9250 error 6 in liblinuxcnchal.so.0[2fa000+8000]
    [ 1977.075617] halcmd[3097]: segfault at 8 ip 00c946bc sp bfdb70a0 error 6 in liblinuxcnchal.so.0[c8f000+8000]
    [ 1977.298054] halcmd[3101]: segfault at 8 ip 00cf06bc sp bfd264c0 error 6 in liblinuxcnchal.so.0[ceb000+8000]
    [ 1977.518470] halcmd[3105]: segfault at 8 ip 00fc56bc sp bfe00f60 error 6 in liblinuxcnchal.so.0[fc0000+8000]
    [ 2243.095299] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
    [ 2256.981434] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
    [ 2820.427250] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
    [ 2821.387886] __ratelimit: 2 callbacks suppressed
    [ 2821.387895] halcmd[3463]: segfault at 8 ip 007856bc sp bff6b230 error 6 in liblinuxcnchal.so.0[780000+8000]
    [ 2821.397910] halcmd[3464]: segfault at 8 ip 0033a6bc sp bfb87c40 error 6 in liblinuxcnchal.so.0[335000+8000]
    [ 2821.420930] halcmd[3467]: segfault at 8 ip 003886bc sp bfe20140 error 6 in liblinuxcnchal.so.0[383000+8000]
    [ 2821.641500] halcmd[3471]: segfault at 8 ip 00b006bc sp bfd03a40 error 6 in liblinuxcnchal.so.0[afb000+8000]
    [ 2821.862111] halcmd[3475]: segfault at 8 ip 00c2a6bc sp bff044b0 error 6 in liblinuxcnchal.so.0[c25000+8000]
    [ 2822.081899] halcmd[3479]: segfault at 8 ip 009556bc sp bfaae480 error 6 in liblinuxcnchal.so.0[950000+8000]
    [ 2822.302802] halcmd[3483]: segfault at 8 ip 00df26bc sp bf9d5770 error 6 in liblinuxcnchal.so.0[ded000+8000]
    [ 2822.521860] halcmd[3487]: segfault at 8 ip 00a9c6bc sp bfb28e80 error 6 in liblinuxcnchal.so.0[a97000+8000]
    [ 2822.742190] halcmd[3491]: segfault at 8 ip 002f96bc sp bf971040 error 6 in liblinuxcnchal.so.0[2f4000+8000]
    [ 2822.962477] halcmd[3495]: segfault at 8 ip 003bc6bc sp bfb2cab0 error 6 in liblinuxcnchal.so.0[3b7000+8000]
TB2EOS
erenbasturk
root yekisi yok sende. linuxcnc ye web tabanlı gui geldi mi?
klax
root yetkısı ve web tabanlı gui nasıl oluyor bılmıyorum . Linux hıc anlamıyorum
mesaj birleştirme:: 23 Şubat 2015, 11:02:48
guncelleme yaptı ama ondan oncede calıstıramadım aynı hataları verıyor
TB2EOS
erenbasturk
" insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': "
burada rtai kernelini sisteme yüklemiyor izinden dolayı. Bu rtai kerneli'linuxcnc nin koşmasını saglayan alt yapıyı hazırlıyor.
komut satırında  alttaki komutları sırasıyla denermisin
sudo su
linuxcnc&
LinuxCNC'yi bilgisayarına nasıl kurdun?
klax
dedigini yaptım ama gene aynı.yenıden kurdum.sorun ubuntu genelınde. acılısta  wifi baglanmak icin bile yetkı sıfresi soruyor. genel olarak root etmem gerekıyor.paralolar otorumlar her turlu ayarı dendim ama gozden kacan bır sey var
TB2EOS
linux  butur işler için güvenlik açısında root şifresi sorar. buyuk ihtimalle şifresiz user ile oturum sçıyorsunuz.  bu kullanıcıyı superuser/poweruser yapıp deneye birsiniz
erenbasturk
Alıntı yapılan: klax - 24 Şubat 2015, 02:51:51
cd den mi kuruyorsun? yoksa yükseltme yapıp ubuntu üzerine mi kuruyorsun? http://dsplabs.upt.ro/~juve/emc/ buradaki 12.04 imajı mı kullanıyorsun alt sürümleri mi?
Hazır imaj üzerinden kurulum gerekiyor. Yukarıdaki soruyu kendim için değil, klax'ın nasıl kurduğunu anlamak için sormuştum. Kendi verdikleri imajdaki kernel modifiye edilmiş ve gerçek zamanlı (real-time) çalışma özelliğine sahip. Normal yollardan kurulmuş Ubuntu vb. bir sistem üzerine LinuxCNC kurulursa sorun çıkması normal. Ben doğrudan bu sayfada bulunan ilk "Download the ISO" bağlantısına tıklayarak indirip kurdum.
klax
linux cnc 2.5 imajını ındırp kurdum. acılıyor ama run vermıyor rtai hatıası veriyor.baska bır pc denedım genel olarak realtime hatası verıyor. normal ubuntu imajı ındırıp onu kuracam. sonra icine lınıx cnc programını yukleyecem. paket yukleyıcı ıle.
ondan once http://dsplabs.upt.ro/~juve/emc/ linktekı iso deneyecem
TB2EOS
klax
#11
iso calısmadı. ubuntu 12.04 yukseltıyorum. linuxcnc source code veya dep paketi arıyom. gelısmelerı yazacam. su anladım linuxcnc sıtesındekı ıso her pc çalışmıyor.root lama duzgun degıl  her pc uyumu denemiyorlar. sorun ortak rti çalışmıyor genelde. 2 ayrı pc denedım
tagli bende aynı yerden indirdim ama çalışmıyor işte
TB2EOS
Kurulum sorunsuz olarak tamamlandı mı? Yani normal masaüstü açılıyor ama ondan sonra mı hata veriyor?
Bu arada yanlış anlaşılma olmasın, bu konuda deneyimli falan değilim, ben de öğrenmeye çalışıyorum. Kurulumu eski bilgisayarımda denedim. Pentium D 2.66 GHz işlemcisi, ASUS P5PL2 anakartı ve anakart üzerinde paralel portu var. Şansıma sorun çıkmadı ama gecikme testi sonuçları çok iyi değil. Yine de dün ilk kez motor sürmeyi denedim ve düzgün çalıştı.
Yeni bilgisayarım üzerinde de sırf denemek için kaynak koddan derlemiştim. Program açılıyordu ama tabi paralel port, realtime kernel falan olmadığı için bir anlamı yok.
erenbasturk
mesaj birleştirme:: 25 Şubat 2015, 06:23:48
beaglebone icin imaj bulunuyor beaglebonedaki islemler PRU(Programmable RealTime Unit) üzerinde çalışıyor ve  gecikmelerden uzak bir sistem saglanıyor. şuan rtai kerneli ile beaglebone'un 3d grafik işlemcisi için kullanılabilen stabil bir driver olmadığı için işlemlecinin üzerinde biraz fazla yük var fakat bu sorunda grafiği web e taşıyarak beaglebone üstünde matematiksel işlemlerin ve verilerin işlenmesi üzerine çalışyorlardı en son.
Alıntı yapılan: Tagli - 24 Şubat 2015, 14:31:41
mesaj birleştirme:: 24 Şubat 2015, 16:28:08
Alıntı yapılan: klax - 24 Şubat 2015, 14:01:25
klax denediğin bilgisayarlardaki işlemciler nedir? birde nasıl kurulum yaptığını tam anlatır mısın?
klax
#14
Linuxcnc 2.5(ubuntu10.04lts)
gericom hollwod 8060b ->  hdd kurulum real time kernel hatası  (Rtai) linuxcnc açmıyor.
exper ms1682 -> cd deneme program çalışıyor. fakat ekrena rtai hata mesaj kutucukları geliyor.
Coolcnc - Linux cnc ilk surumu
gericom hollwod 8060b -> yükleme sırasında pc donuyor.
exper ms1682 ->  virtual pc programı ile gayet güzel calısyor.
linuxcnc 2.2.2 (ubuntu 6.06.1)
gericom hollwod 8060b ->  hdd kurulum gayet güzel on numara calıstı sıkıntı yok.lakin wifi gormedı. herhalde o zamanlar wifi yoktu. :)
exper ms1682 -> cd içinde ubuntu dene ile çalışıyor. hata yok
linuxcnc 2.3 Ubuntu 8.04 Hardy Heron LTS
iso dosyasını yenı ındırdım . yarın deneyecem.
Su ana kadar  yaptığım denemlerde pc uygun ubuntu surumu yuklemedıgınız zaman kernel hatası verıyor ve Linuxcnc (emec2) duzgun çalışmıyor.
iso dosyalarının kaynakları http://dsplabs.upt.ro/~juve/emc/
TB2EOS
