Ynt: ENC28J60 calisma sorusu
Başlatan Karamel, 26 Haziran 2015, 09:49:52
Karamel
merhaba. suan cinden aldigim ethernet module unu test etmeye calisiyorum. modulun resmini asagiya ekledim. gerekli baglantilari yaptim ve mikroc example ini discovery deney pcb sine yukledim.
program calismaya baslayinca once yesil isik yaniyor ve yanik kaliyor. sari isik ara ara yanip yanip sonuyor. sanirim libarary ve baglantilarim dogru? ama herhangi bir tarayiciya 192.168.20.60 yazinca hicbirsey gelmiyor. suan elimde hicbir test aletim yok. ethernet led lerinden durumu anlayabilirmiyim? yada pc uzerinden enc nin varligini gozlemleyebilirmiyim? ag baglantilarim vs gibi yerlerden?
 * Project Name:
     HTTP_Demo (Ethernet Library demo for ENC24J600 mcu)
 * Copyright:
     (c) Mikroelektronika, 2011.
 * Revision History:
     20110105:
       - initial release;
 * V1.0 : first release
 * V1.1 : bad MIME type for / path request, changed to HTML instead of SCRIPT (thanks Srdjan !)
 * description  :
 *      this code shows how to use the SPI_Ethernet_24j600 mini library :
 *              the board will reply to ARP & ICMP echo requests
 *              the board will reply to UDP requests on any port :
 *                      returns the request in upper char with a header made of remote host IP & port number
 *              the board will reply to HTTP requests on port 80, GET method with pathnames :
 *                      /               will return the HTML main page
 *                      /s              will return board status as text string
 *                      /t0 ... /t7     will toggle RE8 to RE15 bit and return HTML main page
 *                      all other requests return also HTML main page
 * target devices :
 *      any MCU with integrated SPI and more than 4 Kb ROM memory
 *      32 to 40 MHz clock is recommended to get from 8 to 10 Mhz SPI clock,
 *      otherwise MCU should be clocked by ENC clock output due to ENC silicon bug in SPI hardware
 *      if you try lower MCU clock speed, don't be surprised if the board hang or miss some requests !
 * Test configuration:
     MCU:             STM32F107VC
                      http://www.st.com/st-web-ui/static/active/en/resource/technical/document/datasheet/CD00220364.pdf
     Dev.Board:       EasyMx v7 for STM32 ® ARM ®
                      http://www.mikroe.com/easymx-pro/stm32/
     Oscillator:      HSE-PLL, 72.000MHz
     ext. modules:    ac:Serial_Ethernet_Board
                      ac:SmartADAPT
     SW:              mikroC PRO for ARM
                      http://www.mikroe.com/mikroc/arm/
 * NOTES:
     - Since the ENC28J60 doesn't support auto-negotiation, full-duplex mode is
       not compatible with most switches/routers.  If a dedicated network is used
       where the duplex of the remote node can be manually configured, you may
       change this configuration.  Otherwise, half duplex should always be used.
     - Use SmartADAPT board to connect Serial Ethernet 2 board to EasyMx v7 development system, on PORTB.
     - Pull-down PORTD/L at SW8, and put SW10.7 in VCC position (board specific)
     - Close pots PA3 at J8.
     - Turn ON PORTE/H LEDs at SW15.8.
     - External power supply should be used due to Serial Ethernet Board power consumption.
#include "__EthEnc28j60.h"
// mE ehternet NIC pinout
sfr sbit SPI_Ethernet_Rst at GPIOB_ODR.B0;
sfr sbit SPI_Ethernet_CS at GPIOB_ODR.B1;
 * ROM constant strings
const code unsigned char httpHeader[] = "HTTP/1.1 200 OKnContent-type: ";  // HTTP header
const code unsigned char httpMimeTypeHTML[] = "text/htmlnn";              // HTML MIME type
const code unsigned char httpMimeTypeScript[] = "text/plainnn";           // TEXT MIME type
unsigned char httpMethod[] = "GET /";
 * web page, splited into 2 parts :
 * when coming short of ROM, fragmented data is handled more efficiently by linker
 * this HTML page calls the boards to get its status, and builds itself with javascript
const code   char    *indexPage =                   // Change the IP address of the page to be refreshed
"<meta http-equiv="refresh" content="3;url=http://192.168.20.60">
<HTML><HEAD></HEAD><BODY>
<h1>MCU   ENC24J600 Mini Web Server</h1>
<a href=/>Reload</a>
<script src=/s></script>
<table><tr><td valign=top><table border=1 style="font-size:20px ;font-family: terminal ;">
<tr><th colspan=2>ADC</th></tr>
<tr><td>AN3</td><td><script>document.write(AN3)</script></td></tr>
</table></td><td><table border=1 style="font-size:20px ;font-family: terminal ;">
<tr><th colspan=2>PORTD</th></tr>
<script>
var str,i;
str="";
for(i=0;i<8;i  )
{str ="<tr><td bgcolor=pink>BUTTON #" i "</td>";
if(PORTD&(1<<i)){str ="<td bgcolor=red>ON";}
else {str ="<td bgcolor=#cccccc>OFF";}
str ="</td></tr>";}
document.write(str) ;
</script>
const code   char    *indexPage2 =  "</table></td><td>
<tr><th colspan=3>PORTE</th></tr>
<script>
var str,i;
str="";
for(i=0;i<8;i  )
{str ="<tr><td bgcolor=yellow>LED #" i "</td>";
if(PORTE&(1<<i)){str ="<td bgcolor=red>ON";}
str ="</td><td><a href=/t" i ">Toggle</a></td></tr>";}
</script>
</table></td></tr></table>
This is HTTP request #<script>document.write(REQ)</script></BODY></HTML>
 * RAM variables
unsigned char   myMacAddr[6] = {0x00, 0x14, 0xA5, 0x76, 0x19, 0x3f};   // my MAC address
unsigned char   myIpAddr[4]  = {192, 168,  20, 60 };                   // my IP address
unsigned char   gwIpAddr[4]  = {192, 168,  20, 66 };                   // gateway (router) IP address
unsigned char   ipMask[4]    = {255, 255, 255,  0 };                   // network mask (for example : 255.255.255.0)
unsigned char   dnsIpAddr[4] = {192, 168,  20,  1 };                   // DNS server IP address
unsigned char   getRequest[15];                                        // HTTP request buffer
unsigned char   dyna[31] ;                                             // buffer for dynamic response
unsigned long   httpCounter = 0;                                       // counter of HTTP requests
 * functions
 * put the constant string pointed to by s to the ENC transmit buffer.
/*unsigned int    putConstString(const code char *s)
        unsigned int ctr = 0;
        while(*s)
                SPI_Ethernet_putByte(*s  );
                ctr  ;
        return(ctr);
 * it will be much faster to use library SPI_Ethernet_putConstString routine
 * instead of putConstString routine above. However, the code will be a little
 * bit bigger. User should choose between size and speed and pick the implementation that
 * suites him best. If you choose to go with the putConstString definition above
 * the #define line below should be commented out.
#define putConstString  SPI_Ethernet_putConstString
 * put the string pointed to by s to the ENC transmit buffer
/*unsigned int    putString(char *s)
        while(*s)
                ctr  ;
        return(ctr);
 * it will be much faster to use library SPI_Ethernet_putString routine
 * instead of putString routine above. However, the code will be a little
 * suites him best. If you choose to go with the putString definition above
#define putString  SPI_Ethernet_putString
 * this function is called by the library
 * the user accesses to the HTTP request by successive calls to SPI_Ethernet_getByte()
 * the user puts data in the transmit buffer by successive calls to SPI_Ethernet_putByte()
 * the function must return the length in bytes of the HTTP reply, or 0 if nothing to transmit
 * if you don't need to reply to HTTP requests,
 * just define this function with a return(0) as single statement
unsigned int    SPI_Ethernet_UserTCP(unsigned char *remoteHost, unsigned int remotePort, unsigned int localPort, unsigned int reqLength, TEthPktFlags *flags)
        unsigned int    len;            // my reply length
        // should we close tcp socket after response is sent?
        // library closes tcp socket by default if canCloseTCP flag is not reset here
        // flags->canCloseTCP = 0; // 0 - do not close socket
                                   // otherwise - close socket
        if(localPort != 80)                         // I listen only to web request on port 80
                return(0);
        // get 10 first bytes only of the request, the rest does not matter here
        for(len = 0; len < 10; len  )
        getRequest[len] = SPI_Ethernet_getByte();
        getRequest[len] = 0;
        len = 0;
        if(memcmp(getRequest, httpMethod, 5))       // only GET method is supported here
                return(0);
        httpCounter  ;                             // one more request done
        if(getRequest[5] == 's')                    // if request path name starts with s, store dynamic data in transmit buffer
                // the text string replied by this request can be interpreted as javascript statements
                // by browsers
                len = putConstString(httpHeader);              // HTTP header
                len  = putConstString(httpMimeTypeScript);     // with text MIME type
                // add AN3 value to reply
                WordToStr(ADC1_Get_Sample(3), dyna) ;
                len  = putConstString("var AN3=") ;
                len  = putString(dyna) ;
                len  = putConstString(";") ;
                // add PORTD value (buttons) to reply
                len  = putConstString("var PORTD=");
                WordToStr(GPIOD_IDR, dyna);
                len  = putString(dyna);
                len  = putConstString(";");
                // add PORTE value (LEDs) to reply
                len  = putConstString("var PORTE=");
                WordToStr(GPIOE_ODR>>8, dyna);
                // add HTTP requests counter to reply
                WordToStr(httpCounter, dyna);
                len  = putConstString("var REQ=");
        else if(getRequest[5] == 't')                           // if request path name starts with t, toggle PORTE (LED) bit number that comes after
                unsigned long   bitMask = 0;                   // for bit mask
                if(isdigit(getRequest[6]))                      // if 0 <= bit number <= 9, bits 8 & 9 does not exist but does not matter
                        bitMask = getRequest[6] - '0';         // convert ASCII to integer
                        bitMask = 1 << (bitMask   8);                // create bit mask
                        GPIOE_ODR = GPIOE_ODR ^ bitMask;     // toggle PORTE with xor operator
        if(len == 0)                                            // what do to by default
                len  = putConstString(httpMimeTypeHTML);       // with HTML MIME type
                len  = putConstString(indexPage);              // HTML page first part
                len  = putConstString(indexPage2);             // HTML page second part
        return(len);                                           // return to the library with the number of bytes to transmit
 * the user accesses to the UDP request by successive calls to SPI_Ethernet_getByte()
 * the function must return the length in bytes of the UDP reply, or 0 if nothing to transmit
 * if you don't need to reply to UDP requests,
unsigned int    SPI_Ethernet_UserUDP(unsigned char *remoteHost, unsigned int remotePort, unsigned int destPort, unsigned int reqLength, TEthPktFlags *flags)
        // reply is made of the remote host IP address in human readable format
        ByteToStr(remoteHost[0], dyna);                // first IP address byte
        dyna[3] = '.';
        ByteToStr(remoteHost[1], dyna   4);            // second
        dyna[7] = '.';
        ByteToStr(remoteHost[2], dyna   8);            // third
        dyna[11] = '.';
        ByteToStr(remoteHost[3], dyna   12);           // fourth
        dyna[15] = ':';                                // add separator
        // then remote host port number
        WordToStr(remotePort, dyna   16);
        dyna[21] = '[';
        WordToStr(destPort, dyna   22);
        dyna[27] = ']';
        dyna[28] = 0;
        // the total length of the request is the length of the dynamic string plus the text of the request
        len = 28   reqLength;
        // puts the dynamic string into the transmit buffer
        SPI_Ethernet_putBytes(dyna, 28);
        // then puts the request string converted into upper char into the transmit buffer
        while(reqLength--)
                SPI_Ethernet_putByte(toupper(SPI_Ethernet_getByte()));
        return(len);           // back to the library with the length of the UDP reply
 * main entry
void main() {
        GPIO_Digital_Input(&GPIOD_BASE, _GPIO_PINMASK_ALL);
        GPIO_Digital_Output(&GPIOE_BASE, _GPIO_PINMASK_ALL);
        ADC1_Init();
        ADC_Set_Input_Channel(_ADC_CHANNEL_3);
        SPI3_Init_Advanced(_SPI_FPCLK_DIV16, _SPI_MASTER  | _SPI_8_BIT |
                     _SPI_CLK_IDLE_LOW | _SPI_FIRST_CLK_EDGE_TRANSITION |
                     _SPI_MSB_FIRST | _SPI_SS_DISABLE | _SPI_SSM_ENABLE | _SPI_SSI_1,
                     &_GPIO_MODULE_SPI3_PB345);
        //GPIO_Alternate_Function_Enable(&_GPIO_MODULE_SWJ_JTAGDISABLE);
        SPI_Ethernet_Init(myMacAddr, myIpAddr, SPI_Ethernet_FULLDUPLEX); // init ethernet board
        // dhcp will not be used here, so use preconfigured addresses
        SPI_Ethernet_confNetwork(ipMask, gwIpAddr, dnsIpAddr);
        while(1) {                           // do forever
                 * if necessary, test the return value to get error code
                SPI_Ethernet_doPacket();   // process incoming Ethernet packets
                 * add your stuff here if needed
                 * SPI_Ethernet_doPacket() must be called as often as possible
                 * otherwise packets could be lost
mesaj birleştirme:: 26 Haziran 2015, 09:50:24
bu arada enc entegresini discovery pcb si uzerinden besledim. 3v ucundan.
mesaj birleştirme:: 26 Haziran 2015, 10:11:10
anladigim kadariyla asagidaki address leri kendi ag yapima gore degistirmem lazim.
mesaj birleştirme:: 26 Haziran 2015, 10:13:18
bende bu rakamlar soyle
Karamel
mac address ini modeme el ile calisti ::)
simdi aklimda bazi soru isaretleri olustu.
bu aletin ip address ini. mac address ini hep el ile girdim ama normal device lar boyle calismiyorlar. otomatik ip aliyorlar. mac i otomatik taniyorlar. ENC ile bunu yapmak mumkunmu?
MrDarK
DHCP şekilde konfigure edeceksin cihazı ondan sonra otomatik alacak hepsini. Fakat bu söylediğim IP için geçerliydi. MAC adreslerini ne yazık ki kendin belirlemek zorundasın :)
Karamel
hocam bu konuyu favorite larima ekledim. birkac hafta kadar bu konu uzerine calisamayacagim. musait oldugumda. yukaridaki example code larini kendim yazmak istiyorum ::) sadece request olunca. ilgili requesti okuyan. karsilinda sadece web sayfasini gonderip. iletisimi kapatan birsey yapacagim. :)
mesaj birleştirme:: 26 Haziran 2015, 12:44:34
hocam bu arada bu kisa arada bu konu ile ilgili hangi kitabi onerirsiniz? ben ethhernet uzerine neredeyse hicbirsey bilmiyorum. sadece rs485 gibi calistigini biliyorum.
iyildirim
MAC adresi genellikle chip ile gelir.
ENC28J60 MAC adresi içermez. Ama mesela ENC24J600, LPC1769  vs. Wiznetin bazı chip leri  legal MAC adresi içerir.
Tek tek kopya, sallama MAC adresi vermek istemezseniz  legal MAC adresi içeren eepromlar kullanılabilir. 11AA02E48, 25AA02E48 gibi.
Karamel
hocam example da mikroe 0x00, 0x14, 0xA5, 0x76, 0x19, 0x3f boyle vermis mac address ini. yani 0014A576193F seklinde. bu gecerli bir address mi? birde evde deney yapmak icin kafamdan asallasam ne olur ki?  :-\
mesaj birleştirme:: 26 Haziran 2015, 13:08:13
sanirim simdi anladim.
sadece evde değilde dunyaya acilan bir alet yaptigimi hayal ettim. birisi Ingilterede . birisi Turkiye de tabiki bunlar farkli ip kullaniyorlar ama mac address lerini ayni verirsem cakisacaklar değilmi? tezim dogrumu hocam?
iyildirim
Hiç bir sorun olmaz.
Dilediğin gibi kullanabilirsin.
Karamel
hocam o zaman mac address i olan entegreler neden varlar?  :-\
mesaj birleştirme:: 26 Haziran 2015, 13:13:23
yani sorun olmuyorsa benim tezim dogru cikmiyor. mac address tam olarak ne ise yariyor?
iyildirim
Aynı fiziksel ağda bir MAC adresinden birden fazla olamaz.
Milyonlarca üretilen bir chip'in de nerede kullanılacağı ile ilgili bir kısıt olması sözkonusu değil.
MAC adresleri yönetici kuruluşlar tarafından standartları belirlenmiş ve üretici firmalara belli sayıda rezerve edilmiş.
48 bit veya 64 bit olabilir. İlk 24 bit üretici firma kodudur.  Mesela örnek verdiğim chipler Microchip'in ve MAC adresleri 0x00-0x04-0xA3  ile başlar.
MAC adresinin elle verilebilir olması USB deki sallama VID, PID kullanımı gibi.
MAC adres chipleri niye var ın cevabı, Legal olmak yada ürettiğiniz her karta ayrı program atmamak gibi nedenler olabilir.
Yanlış hatırlamıyorsam @muhittin_kaplan ın bir konusu vardı. Aldıkları iki makinanın MAC leri çakışmış gibi bir konuydu.
Karamel
hocam o konuyu okumustum ama anlamamistim. simdi hatirladim ve sanirim meseleyide az cok anladim. tesekkur ederim hocam ::)
bu arada. sanirim mikroe nin example i 3-5 dk sonra takiliyor. ethernet cable ini sokup yeniden takinca duzeliyor. 5 dk sonra yine cokuyor server. sorun bendede olabilir. bilemiyorum. oncelikle ethernet meselesini iyice kavrayip. sonra oturup. code lari tek tek yazmak lazim. suan nere ne oluyor. hic birsey anlayamiyorum....  :-\
iyildirim
Fiziksel katman için ENC nin datasheet ine bakabilirsin. IP, ARP, TCP, UDP gibi konular içinde yine ENC serilerinin app.note larında güzel anlatılmış dökümanlar vardı.
Okumayı seviyorsun zaten.
Ama kodarı tek tek yazmak yerine kütüphaneyi anlamaya çalışmak daha yerinde olur.
Recep METE
Bende enc modulunden sipariş verdim. Bu bilgiler önden çok faydalı oldu.
AsHeS
Ethernet işleri için wiznet in çipleri daha uygun stack arama/yazma derdi yok ama ona göre fiyatı yüksek 2-3 dolar.
Karamel
su library deki sever http://www.libstock.com/projects/view/107/network-ethernet-library yarim saattir cokmedi. buyuk olasilikla sorun bendedir ama ustteki example dada sorun olabilir. linkini verdigim libraryde close socket gibi ozellikler var. ve anladigim kadariyla udp. tcp nin bir tik ustu gibi birsey. bildigimiz internet sayfasi geldi enc den...
Alıntı yapılan: iyildirim - 26 Haziran 2015, 14:15:03
hocam konu hakkinda biraz bilgi edineyim. kendi web serverimi yapmak istiyorum ::)
mesaj birleştirme:: 26 Haziran 2015, 16:05:37
az once. en son linkini verdigim example da ki server da coktu. ethernet cable ini sokup takinca duzeliyor. sanirim benim cable da sorun var.
Alıntı yapılan: iyildirim - 26 Haziran 2015, 13:57:19
aynen. firmaya yolladık macler değişti geldi.
