ioccc yarışması
Başlatan Gökhan BEKEN, 18 Eylül 2015, 00:27:46
Gökhan BEKEN
açılımı: the international obfuscated c code contest.
c dili kullanarak en belirsiz, en anlaşılmaz hale getirilmiş kodu yazma yarışmasıymış, her sene yapılıyormuş.
http://ioccc.org/
2012 yılında endoh2 adlı yaptığı ve ödül alan programı:
#define  \
                        D(s)"<<"#s">>"
                      #define  q(s)p(#s)
                     #define S " endobj "
                    #define Y "endstream"S
                    #include     <stdio.h>
                    #define  o(s) b[s]=_;\
                     p("%u    0  obj",s);
#define E for         (c=d;c  < 123;c++)
  #define DANCE         "trailer   "D\
    (/Root 3 0            R /Size %d)            "\nstartxref %u %%%%EOF\n*/"
      #define              p(s, ...)             _+=printf(s,  ##__VA_ARGS__)
       #define C         "<</Type/Page         /Parent %d %d R /Resources <<\
        /ProcSet[       /PDF/Text]/Font       <</U"D(/Subtype/Type1/BaseFont\
          /Courier) "  /T<</Subtype/Type3   /FontBBox[0 0 10 10]/FontMatrix[\
           %f 0 0 %f 0 0]/FirstChar %d/LastChar %d/Encoding<</Differences[%d"
            typedef int N;typedef char*Nyan;typedef char A;N a,b[64],d=65,_,v
              [32]={84,0,64,282,90,74,330,85,93,173,167,176,80,208,81,13,7,87
                ,160,346,32,128,170,218,16,26}; Nyan w[]={"+*-(,&-&","+*,&-&"
                     ,"10 0 d0 ","8 7 2 2 re "   ,"+*+.'`'@'mi +/+/(mi"};Nyan
                       nyan(Nyan _,N y,A n){
                        N g=v[~-y%32];Nyan
                         s=w[g>>n&3|n*2];
                         for(a=0;*_=*s++;
                         a++,_++,*_++=32)
                         {*_+=*_-32?10:0;
                         if(a%2&&*_/16==3
                         ){if(g>>8)*_=105-*_;
                        _++;*_++=32;*_=~-a&&a-13
                        ?108:109;}}return n?n-9?nyan
                       (_,y,n-2):_:nyan(_+=~y&' '?sprintf
                      (_,17[w]):0,y,9);}N main(N c){A e[256];
                     p("/*%%PDF-1.3%%*/")-2;q(#include<stdio.h>\n);
                    q(#define o *_++&& *_-41\n#define);p(" endstream ");q
                   (main(){for(;*_++;      *_-40?:putchar(o?*_:o?10:41));\n)
                  ;q(#define  endobj          return 0;}\n);q(typedef int ET;/)
                 ;q(*);o(1)*b=~(p(D                 (/Length 2 0 R)"stream\n"))
                ;for(p("BT 12 818"                    " Td/%c 12 Tf 12 TL%%%c/"
               "static char*_=\""                       " \\\n",7[v],*v/2);c=
              getchar(),~c;c-10?                         p("/%c 12 Tf(\\%o)"
             "Tj",v[~-c%' '<25[                         v]&&!~-(~-c/'@')?0
            :7],c):(p("()'")))                         ;p("%%\";\nET ");*
           b-=~_;p(Y"/*");E{a                         =nyan(e+sprintf(e,
          16[w]),c,6)-e;o(c-                         59)p(D(/Length %d)
         "stream\n%s"Y,a,e)                         ;}o(2)p(" %u"S,*b);
        o(3)p(D(/Pages 4 0                         R)S);o(4)p(D(/Count
       1/MediaBox[0 0 595                         842]/Kids[5 0 R])S)
      ;o(5)p(C,4,0,6e-2,                         6e-2f,d,122,d);E p(
     "/%c",~-c/6+~14?c:                         d);q(]>>/CharProcs<<)
    ;E if(~-c/6+~14)p(                           "/%c %d 0 R",c,c+~58);
   for(q(>>/Widths[),                             c=59;--c;p(" 10"));a=p
  ("]>>>>>>/Contents 1                              0 R>>"S);for(p("xref\
 0 %d ",--d);c<d;p("%010u\
 %05d n  ",*(c+++b),NULL));
  return!(p(DANCE,d,a));}
burda bir arkadaş açıklamış: http://blog.burakkutbay.com/obfuscated-c-code-contest.html/
bu yarışmaya benzer bir yarışma da: the grand c++ error explosion competition
bu yarışma, en kısa kaynak koduyla en fazla hata mesajını alanın kazandığı bir programlama yarışmasıymış.
web sitesi : http://tgceec.tumblr.com/
kaynak kodunun 5.9 milyar kati buyuklugunde bir hata mesaji iceren bu kod, kazanmış
#include ".//.//.//.//jeh.cpp"
#include "jeh.cpp"
MrDarK
Amaçsızlık, ağır işsizlik gibi geliyor bana :)
Böyle birşey yapmak için hem kafada sanat koşturmak gerekiyor. C kodunu ezberlet adamlara her türlü yaparlar. Yazılımcı olmalarına gerek yok :)
Enteresan bir hobi ama
