Ödev 1 : Karaşimşek
Başlatan alicavuslu, 20 Ekim 2015, 21:41:24
alicavuslu
Karaşimşek için aşağıdaki kod üzerinde geliştirme yapmaya devam edilinebilir. Bu kod 1 saniye aralıklar ile sola kayma işlemi yapmaktadır.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity kara_simsek is
   Port (
      in_clk : in std_logic;
      out_leds : out std_logic_vector(7 downto 0)
end kara_simsek;
architecture Behavioral of kara_simsek is
   constant CLK_PERIOD : integer := 10; -- ns cinsinden
   constant NEW_CLK_PERIDO : integer := 1_000; -- ms cinsinden
   constant CLK_COUNT_PARAM : integer := (NEW_CLK_PERIDO * (10**6)) /  (2 * CLK_PERIOD);
   signal r_clk_new : std_logic := '0';
   signal r_leds : std_logic_vector(7 downto 0) := X"01";
   signal r_clk_count : integer := 0;
begin
   out_leds <= r_leds;
   process(in_clk)
   begin
      if rising_edge(in_clk) then
         if r_clk_count = CLK_COUNT_PARAM - 1 then
            r_clk_count <= 0;
            r_clk_new <= not r_clk_new;
            r_clk_count <= r_clk_count + 1;
         end if;
      end if;
   end process;
   process(r_clk_new)
   begin
      if rising_edge(r_clk_new) then
         r_leds <= r_leds(r_leds'high - 1 downto 0) & r_leds(r_leds'high);
      end if;
   end process;
end Behavioral;
Ucundan azcık kopya çektim :)
library IEEE;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity KaraSimsek is
    Port ( clk : in STD_LOGIC;
           led015 : out STD_LOGIC_VECTOR (15 downto 0));
end KaraSimsek;
architecture Behavioral of KaraSimsek is
    constant SYS_CLK_PERIOD : integer := 10; -- ns cinsinden
    constant NEW_CLK_PERIOD : integer := 100_000_000; -- ns cinsinden
    constant CLK_COUNT : integer := NEW_CLK_PERIOD / (2 * SYS_CLK_PERIOD);
    signal counter: std_logic_vector(3 downto 0):= "0000";
    signal gecici: std_logic_vector(3 downto 0);
    signal clk_new : std_logic := '0';
    signal count : integer range 0 to 99999999 := 0;
    signal r_led015 : STD_LOGIC_VECTOR (15 downto 0):= X"0001";
    signal fwd : std_logic := '1';
begin
     process(clk)
     begin
        if clk= '1' and clk'event then
            if count = CLK_COUNT - 1 then
                count <= 0;
                clk_new <= not clk_new;
                count <= count + 1;
            end if;
        end if;
     end process;
     process(clk_new)
     begin
        if rising_edge(clk_new) then
            if (fwd = '1') then
                r_led015 <= r_led015(14 downto 0) & r_led015(15);
                    if (r_led015 = X"4000") then
                                fwd <= '0';
                    end if;
              r_led015 <= '0' & r_led015(15 downto 1);
             if (r_led015 = X"02") then
                  fwd <= '1';
             end if;
            end if;
        end if;
     end process;
     led015 <= r_led015;
end Behavioral;
https://youtu.be/rmpanx5cP8U
alicavuslu
Ellerinize sağlık Hocam. Güzel olmuş...
Hocam teşekürler yardımlarınız için.
Not: Video'yu değiştirdim :)
JOKERAS
Selam,
Ne zaman Karaşimşek lambası görsem kendimi alamıyorum,hatırası büyüktür bende.
Güzel olmuş, 10 numara 4 yıldız
Neden 4 yıldız?
Kuyruklu orijinal Karaşimşek olsaydı 5 yıldız olacaktı:)
Bunu kuyruklu yaparsanız harika olur.
ipek
ilgi ile izliyorum.hocam  5'li dizi ile kaymalı filmdeki aslı öyle idi.
Cylon_Data:
    LDATA 1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0
    LDATA 0,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0
    LDATA 0,0,1,1,1,1,1,0,0,0,0,0,0,0,0,0
    LDATA 0,0,0,1,1,1,1,1,0,0,0,0,0,0,0,0
    LDATA 0,0,0,0,1,1,1,1,1,0,0,0,0,0,0,0
    LDATA 0,0,0,0,0,1,1,1,1,1,0,0,0,0,0,0
    LDATA 0,0,0,0,0,0,1,1,1,1,1,0,0,0,0,0
    LDATA 0,0,0,0,0,0,0,1,1,1,1,1,0,0,0,0
    LDATA 0,0,0,0,0,0,0,0,1,1,1,1,1,0,0,0
    LDATA 0,0,0,0,0,0,0,0,0,1,1,1,1,1,0,0
    LDATA 0,0,0,0,0,0,0,0,0,0,1,1,1,1,1,0
    LDATA 0,0,0,0,0,0,0,0,0,0,0,1,1,1,1,1
JOKERAS
İpek usta bu yöntem aldatmaca ama.
Aslı öyle değil!
PWM ile yapınca tıpkı dizideki gibi oluyor.
JOKERAS
Alıntı yapılan: MC_Skywalker - 21 Ekim 2015, 13:13:13
Tamam işte bende onu diyorum.
Öyle yapsaydınız 5 yıldız olurdu onu demek istemiştim.
Hadi yapın bizde nemalanalım :)
alicavuslu
Onu daha sonraki ödevlerde verelim. Güzel fikir...
Firzen
Alıntı yapılan: JOKERAS - 21 Ekim 2015, 13:10:59
Aslı öyle değil!
Aslına bakarsan aldatmaca değil bu sisteme instantiation deniliyor PortMap metodu ile 3to8 gibi mux veya demux yapabilirsin.
mesaj birleştirme:: 21 Ekim 2015, 19:26:19
Alıntı yapılan: alicavuslu - 21 Ekim 2015, 13:31:35
hocam hem PWM hemde kayar sistem biraz sanki ağır olur gibi :)
Kararsız...
JOKERAS
Yok Firzen,Bence Aldatmaca o.
Kuyruk efektini vermek için uygulanmış bir taktik.
https://www.youtube.com/watch?v=-O6kMYTRyFY
Orj olan bu videodaki gibi.
alicavuslu
Şöyle düşünürsek 16 bitlik buffer tanımladık. Tanımlama işlemlerinde ilk 3  biti 1 olana kadar kaydırma yapmayacağız. Yani 1 ekleyeceğiz. Daha sonra 0 ekleyeceğiz. Bu şekilde kuyruk efektide eklenmiş olur. Ama onunda sırası gelcek :)
if count < 3 then
    r_leds <= r_leds(r_leds'high - 1 downto 0) & '1';
    r_leds <= r_leds(r_leds'high - 1 downto 0) & '0';
end if;
Firzen
Alıntı yapılan: JOKERAS - 21 Ekim 2015, 19:39:59
http://www.youtube.com/watch?v=-O6kMYTRyFY
Amplifier Tube + amplifier devresi + Shift Register ile yapılmış kayar sistem bunu direk yapar PWM bile gerek kalmaz Amp Tube zaten bu şekilde yanıp sönüyor
mesaj birleştirme:: 21 Ekim 2015, 23:07:17
Alıntı yapılan: alicavuslu - 21 Ekim 2015, 21:22:58
if count < 3 then
end if;
Hocam sanırım size gönderdiğim ödevde aynı bunu yapmıştım 3 bit kaydırma yapmıştım :D
Kararsız...
