cons tanımlanmış değeri bilmek istiyorum.
Başlatan z, 01 Şubat 2016, 22:06:44
Keildeki örnek programları inceliyorum.
Örneğin aşağıdaki descriptörde USB_CONFIGURATION_DESCRIPTOR_TYPE değerinin ne olduğunu bir çırpıda görmek istiyorum. Headerlaredan birinde tanımlıdır ama aramak istemiyorum.
Kolay bir  yolu varmı?
const uint8_t Virtual_Com_Port_ConfigDescriptor[] =
    /*Configuration Descriptor*/
    0x09,   /* bLength: Configuration Descriptor size */
    USB_CONFIGURATION_DESCRIPTOR_TYPE,      /* bDescriptorType: Configuration */
    VIRTUAL_COM_PORT_SIZ_CONFIG_DESC,       /* wTotalLength:no of returned bytes */
    0x00,
    0x02,   /* bNumInterfaces: 2 interface */
    0x01,   /* bConfigurationValue: Configuration value */
    0x00,   /* iConfiguration: Index of string descriptor describing the configuration */
    0xC0,   /* bmAttributes: self powered */
    0x32,   /* MaxPower 0 mA */
    /*Interface Descriptor*/
    0x09,   /* bLength: Interface Descriptor size */
    USB_INTERFACE_DESCRIPTOR_TYPE,  /* bDescriptorType: Interface */
    /* Interface descriptor type */
    0x00,   /* bInterfaceNumber: Number of Interface */
    0x00,   /* bAlternateSetting: Alternate setting */
    0x01,   /* bNumEndpoints: One endpoints used */
    0x02,   /* bInterfaceClass: Communication Interface Class */
    0x02,   /* bInterfaceSubClass: Abstract Control Model */
    0x01,   /* bInterfaceProtocol: Common AT commands */
    0x00,   /* iInterface: */
    /*Header Functional Descriptor*/
    0x05,   /* bLength: Endpoint Descriptor size */
    0x24,   /* bDescriptorType: CS_INTERFACE */
    0x00,   /* bDescriptorSubtype: Header Func Desc */
    0x10,   /* bcdCDC: spec release number */
    0x01,
    /*Call Management Functional Descriptor*/
    0x05,   /* bFunctionLength */
    0x01,   /* bDescriptorSubtype: Call Management Func Desc */
    0x00,   /* bmCapabilities: D0+D1 */
    0x01,   /* bDataInterface: 1 */
    /*ACM Functional Descriptor*/
    0x04,   /* bFunctionLength */
    0x02,   /* bDescriptorSubtype: Abstract Control Management desc */
    0x02,   /* bmCapabilities */
    /*Union Functional Descriptor*/
    0x06,   /* bDescriptorSubtype: Union func desc */
    0x00,   /* bMasterInterface: Communication class interface */
    0x01,   /* bSlaveInterface0: Data Class Interface */
    /*Endpoint 2 Descriptor*/
    0x07,   /* bLength: Endpoint Descriptor size */
    USB_ENDPOINT_DESCRIPTOR_TYPE,   /* bDescriptorType: Endpoint */
    0x82,   /* bEndpointAddress: (IN2) */
    0x03,   /* bmAttributes: Interrupt */
    VIRTUAL_COM_PORT_INT_SIZE,      /* wMaxPacketSize: */
    0x00,
    0xFF,   /* bInterval: */
    /*Data class interface descriptor*/
    0x09,   /* bLength: Endpoint Descriptor size */
    USB_INTERFACE_DESCRIPTOR_TYPE,  /* bDescriptorType: */
    0x01,   /* bInterfaceNumber: Number of Interface */
    0x02,   /* bNumEndpoints: Two endpoints used */
    0x0A,   /* bInterfaceClass: CDC */
    0x00,   /* bInterfaceSubClass: */
    0x00,   /* bInterfaceProtocol: */
    /*Endpoint 3 Descriptor*/
    0x03,   /* bEndpointAddress: (OUT3) */
    0x02,   /* bmAttributes: Bulk */
    VIRTUAL_COM_PORT_DATA_SIZE,             /* wMaxPacketSize: */
    0x00,
    0x00,   /* bInterval: ignore for Bulk transfer */
    /*Endpoint 1 Descriptor*/
    0x81,   /* bEndpointAddress: (IN1) */
    0x00,
    0x00    /* bInterval */
Elektroemre
Burak B
MrDarK
Emblocks kullan, imleci üzerinde tut yansıma olarak değeri görebilirsin.
