PC açılışta 9C ve 99 hatası veriyor.
Başlatan z, 06 Mayıs 2016, 12:27:01
PC açılışta 9C vermeye başladı.  Tekrar kapatıp açarsam sadece 99 hatası veriyor ardından açılıyor.
Bu hatayı ilk açılışta ekran kapkara iken ekranın sağ alt köşesinde veriyor.
Sanki PC yarı yolda bırakacak gibi.
Bu hatalar için fikri olan varmı?
Hata mesajı aşağıdaki gibi mi?
BCCode: 9c  BCP1: 00000000 BCP2: 80346E70 BCP3: B2000040 BCP4: 00000800
RAM, USB gibi donanım arızasına işaret ediyor. aşağıda bir çözüm var Microsoft sitesinden aldığım. olmazsa minidump dosyasını paylaşırsanız analiz ederim.
Alıntı Yap
Looks like some BSOD and it says there was a minidump, so you have things (dump files) you can interpret/analyze.
A BSOD with 9c is usually a hardware problem - RAM, video card, some loose USB connection, some cable inside, overheating (is there gaming involved?).
Here is what MS has to say about it:
http://support.microsoft.com/?kbid=329284&sd=RMVP
http://support.microsoft.com/?kbid=162363&sd=RMVP
But reading about it, while entertaining and educational does not (usually) help you figure it out and fix it.
Is ZoneAlarm installed or has ZoneAlarm ever been installed? Since it is homebuilt, I would reseat the RAM and video card (if there is one - is there?), all the cables, etc. - it is probably hardware somewhere. I would take a look at the last few minidumps and look for some more clues - a pattern.
Download BlueScreenView from here:
http://www.nirsoft.net/utils/blue_screen_view.html
Unzip and run it (BSV installs nothing) and let it finish scanning all your dump files.
If you double click one me the dumps, you will get some information about it and you may be able to spot the problem right away - especially if you see a pattern in the dumps. Select the most recent dump files by clicking them and holding down the Ctrl key to select multiples files.  Try to select just the most recent ones that relate to your issue (maybe five or so dump files to get started). Click File, Save Selected Items and save the information from the dumps to a text file on your desktop called BSOD.txt.  Open BSOD.txt with a text editor, copy all the text and paste it into your next reply.
Please provide additional information about your system:
Click Start, Run and in the box enter:
msinfo32
Click OK, and when the System Summary info appears, click Edit, Select All, Copy and then paste the information back here. There will be some personal information (like System Name and User Name), and whatever appears to be private information to you, just delete it from the pasted information. For video driver information, expand the Components, click Display, click Edit, Select All, Copy and then paste the information. This will minimize back and forth Q&A and eliminate guesswork.
Perform some scans for malicious software:
Download, install, update and do a full scan with these free malware detection programs:
Malwarebytes (MBAM):  http://malwarebytes.org/
SUPERAntiSpyware: (SAS):  http://www.superantispyware.com/
They can be uninstalled later if desired.
Run a test of your RAM with memtest86+ (I know it is boring and will cost you a CD).  Memtest86+ is a more up to date version of the old memtest86 program and they are not the same. The memtest86+ will not run under Windows, so you will need to download the ISO file and create a bootable CD, boot on that and then run the memtest86+ program.   If even a single error is reported that is a failure and should make you suspicious of your RAM. If you have multiple sticks of RAM you may need to run the test on them one at a time and change them out to isolate the failure to a particular single stick. Always keep at least the first bank of RAM occupied so the Test will find something to do and there is enough to boot your system. Sometimes, reseating the RAM in the slots will relieve the error but a failure is still cause for suspicion.
The file and instructions are here:
http://www.memtest.org/
Here is a link that show you have to create and use the memtest86+ CD:
http://www.geekstogo.com/forum/Guide-to-using-Memtest86-t246994.html
If someone says to run memtest86, you can tell them to go pound sand and that you know memtest86+ supercedes memtest86 and here's why:
http://en.wikipedia.org/wiki/Memtest86
http://www.intel.com/content/www/us/en/support/boards-and-kits/000005500.html
Sleep moddan kaldırdığımda sorun yok. Power offdan kaldırınca sorun oluyor fakat ikinci kez kapatıp açınca sorun düzeliyor.
Verdiğim link 99 9A kodları için mouse ile sıkıntılı diyor fakat kablosuz mouse sorunlu olsa bile windowsun açması lazım değilmi?
restore
tahminim kartınız msi . bende de vardı. ekran kartıyla uyumsuz oldugunda böyle bi sorun yapıyordu. işlemci frekans degerlerini yükseltince sorun kalkıyordu.  ekran kartını cıkarın anakart üzerinden deneyin. yada yeni bios güncellemesi.
kayatech
Anakartta şişmiş kondansatörler  varsa bu tip hatalar yapabiliyor. Bir kontrol edin şişenleri değiştirin. Çok garip hatalara neden olabiliyor çünkü. Değiştirince her şey düzeliyor.
HexfeT
Progress Codes
00 - Not used
01 - Power on. Reset type detection (soft/hard)
02 - AP initialization before microcode loading
03 - System Agent initialization before microcode loading
04 - PCH initialization before microcode loading
05 - OEM initialization before microcode loading
06 - Microcode loading
07 - AP initialization after microcode loading
08 - System Agent initialization after microcode loading
09 - PCH initialization after microcode loading
0A - OEM initialization after microcode loading
0B - Cache initialization
SEC Error Codes
0C - Reserved for future AMI SEC error codes
0D - Reserved for future AMI SEC error codes
0E - Microcode not found
0F - Microcode not loaded
PEI Phase
10 - PEI Core is started
11 - Pre-memory CPU initialization is started
12 - Pre-memory CPU initialization (CPU module specific)
13 - Pre-memory CPU initialization (CPU module specific)
14 - Pre-memory CPU initialization (CPU module specific)
15 - Pre-memory System Agent initialization is started
16 - Pre-Memory System Agent initialization (System Agent module specific)
17 - Pre-Memory System Agent initialization (System Agent module specific)
18 - Pre-Memory System Agent initialization (System Agent module specific)
19 - Pre-memory PCH initialization is started
1A - Pre-memory PCH initialization (PCH module specific)
1B - Pre-memory PCH initialization (PCH module specific)
1C - Pre-memory PCH initialization (PCH module specific)
1D - OEM pre-memory initialization codes
1E - OEM pre-memory initialization codes
1F - OEM pre-memory initialization codes
20 - OEM pre-memory initialization codes
21 - OEM pre-memory initialization codes
22 - OEM pre-memory initialization codes
23 - OEM pre-memory initialization codes
24 - OEM pre-memory initialization codes
25 - OEM pre-memory initialization codes
26 - OEM pre-memory initialization codes
27 - OEM pre-memory initialization codes
28 - OEM pre-memory initialization codes
29 - OEM pre-memory initialization codes
2A - OEM pre-memory initialization codes
2B - Memory initialization. Serial Presence Detect (SPD) data reading
2C - Memory initialization. Memory presence detection
2D - Memory initialization. Programming memory timing information
2E - Memory initialization. Confi guring memory
2F - Memory initialization (other)
30 - Reserved for ASL (see ASL Status Codes section below)
31 - Memory Installed
32 - CPU post-memory initialization is started
33 - CPU post-memory initialization. Cache initialization
34 - CPU post-memory initialization. Application Processor(s) (AP) initialization
35 - CPU post-memory initialization. Boot Strap Processor (BSP) selection
36 - CPU post-memory initialization. System Management Mode (SMM) initialization
37 - Post-Memory System Agent initialization is started
38 - Post-Memory System Agent initialization (System Agent module specific)
39 - Post-Memory System Agent initialization (System Agent module specific)
3A - Post-Memory System Agent initialization (System Agent module specific)
3B - Post-Memory PCH initialization is started
3C - Post-Memory PCH initialization (PCH module specific)
3D - Post-Memory PCH initialization (PCH module specific)
3E - Post-Memory PCH initialization (PCH module specific)
3F - OEM post memory initialization codes
40 - OEM post memory initialization codes
41 - OEM post memory initialization codes
42 - OEM post memory initialization codes
43 - OEM post memory initialization codes
44 - OEM post memory initialization codes
45 - OEM post memory initialization codes
46 - OEM post memory initialization codes
47 - OEM post memory initialization codes
48 - OEM post memory initialization codes
49 - OEM post memory initialization codes
4A - OEM post memory initialization codes
4B - OEM post memory initialization codes
4C - OEM post memory initialization codes
4D - OEM post memory initialization codes
4E - OEM post memory initialization codes
4F - DXE IPL is started
PEI Error Codes
50 - Memory initialization error. Invalid memory type or incompatible memory speed
51 - Memory initialization error. SPD reading has failed
52 - Memory initialization error. Invalid memory size or memory modules do not match
53 - Memory initialization error. No usable memory detected
54 - Unspecifi ed memory initialization error
55 - Memory not installed
56 - Invalid CPU type or Speed
57 - CPU mismatch
58 - CPU self test failed or possible CPU cache error
59 - CPU micro-code is not found or micro-code update is failed
5A - Internal CPU error
5B - reset PPI is not available
5C - Reserved for future AMI error codes
5D - Reserved for future AMI error codes
5E - Reserved for future AMI error codes
5F - Reserved for future AMI error codes
DXE Phase
60 - DXE Core is started
61 - NVRAM initialization
62 - Installation of the PCH Runtime Services
63 - CPU DXE initialization is started
64 - CPU DXE initialization (CPU module specific)
65 - CPU DXE initialization (CPU module specific)
66 - CPU DXE initialization (CPU module specific)
67 - CPU DXE initialization (CPU module specific)
68 - PCI host bridge initialization
69 - System Agent DXE initialization is started
6A - System Agent DXE SMM initialization is started
6B - System Agent DXE initialization (System Agent module specific)
6C - System Agent DXE initialization (System Agent module specific)
6D - System Agent DXE initialization (System Agent module specific)
6E - System Agent DXE initialization (System Agent module specific)
6F - System Agent DXE initialization (System Agent module specific)
70 - PCH DXE initialization is started
71 - PCH DXE SMM initialization is started
72 - PCH devices initialization
73 - PCH DXE Initialization (PCH module specific)
74 - PCH DXE Initialization (PCH module specific)
75 - PCH DXE Initialization (PCH module specific)
76 - PCH DXE Initialization (PCH module specific)
77 - PCH DXE Initialization (PCH module specific)
78 - ACPI module initialization
79 - CSM initialization
7A - Reserved for future AMI DXE codes
7B - Reserved for future AMI DXE codes
7C - Reserved for future AMI DXE codes
7D - Reserved for future AMI DXE codes
7E - Reserved for future AMI DXE codes
7F - Reserved for future AMI DXE codes
80 - OEM DXE initialization codes
81 - OEM DXE initialization codes
82 - OEM DXE initialization codes
83 - OEM DXE initialization codes
84 - OEM DXE initialization codes
85 - OEM DXE initialization codes
86 - OEM DXE initialization codes
87 - OEM DXE initialization codes
88 - OEM DXE initialization codes
89 - OEM DXE initialization codes
8A - OEM DXE initialization codes
8B - OEM DXE initialization codes
8C - OEM DXE initialization codes
8D - OEM DXE initialization codes
8E - OEM DXE initialization codes
8F - OEM DXE initialization codes
90 - Boot Device Selection (BDS) phase is started
91 - Driver connecting is started
92 - PCI Bus initialization is started
93 - PCI Bus Hot Plug Controller Initialization
94 - PCI Bus Enumeration 32
95 - PCI Bus Request Resources
96 - PCI Bus Assign Resources
97 - Console Output devices connect
98 - Console input devices connect
99 - Super IO Initialization
9A - USB initialization is started
9B - USB Reset
9C - USB Detect
9D - USB Enable
9E - Reserved for future AMI codes
9F - Reserved for future AMI codes
A0 - IDE initialization is started
A1 - IDE Reset
A2 - IDE Detect
A3 - IDE Enable
A4 - SCSI initialization is started
A5 - SCSI Reset
A6 - SCSI Detect
A7 - SCSI Enable
A8 - Setup Verifying Password
A9 - Start of Setup
AA - Reserved for ASL (see ASL Status Codes section below)
AB - Setup Input Wait
AC - Reserved for ASL (see ASL Status Codes section below)
AD - Ready To Boot event
AE - Legacy Boot event
AF - Exit Boot Services event
B0 - Runtime Set Virtual Address MAP Begin
B1 - Runtime Set Virtual Address MAP End
B2 - Legacy Option ROM Initialization
B3 - System Reset
B4 - USB hot plug
B5 - PCI bus hot plug
B6 - Clean-up of NVRAM
B7 - Confi guration Reset (reset of NVRAM settings)
B8 - Reserved for future AMI codes
B9 - Reserved for future AMI codes
BA - Reserved for future AMI codes
BB - Reserved for future AMI codes
BC - Reserved for future AMI codes
BD - Reserved for future AMI codes
BE - Reserved for future AMI codes
BF - Reserved for future AMI codes
C0 - OEM BDS initialization codes
C1 - OEM BDS initialization codes
C2 - OEM BDS initialization codes
C3 - OEM BDS initialization codes
C4 - OEM BDS initialization codes
C5 - OEM BDS initialization codes
C6 - OEM BDS initialization codes
C7 - OEM BDS initialization codes
C8 - OEM BDS initialization codes
C9 - OEM BDS initialization codes
CA - OEM BDS initialization codes
CB - OEM BDS initialization codes
CC - OEM BDS initialization codes
CD - OEM BDS initialization codes
CE - OEM BDS initialization codes
CF - OEM BDS initialization codes
DXE Error Codes
D0 - CPU initialization error
D1 - System Agent initialization error
D2 - PCH initialization error
D3 - Some of the Architectural Protocols are not available
D4 - PCI resource allocation error. Out of Resources
D5 - No Space for Legacy Option ROM
D6 - No Console Output Devices are found
D7 - No Console Input Devices are found
D8 - Invalid password
D9 - Error loading Boot Option (LoadImage returned error)
DA - Boot Option is failed (StartImage returned error)
DB - Flash update is failed
DC - Reset protocol is not available
S3 Resume Progress Codes
E0 - S3 Resume is stared (S3 Resume PPI is called by the DXE IPL)
E1 - S3 Boot Script execution
E2 - Video repost
E3 - OS S3 wake vector call
E4 - Reserved for future AMI progress codes
E5 - Reserved for future AMI progress codes
E6 - Reserved for future AMI progress codes
E7 - Reserved for future AMI progress codes
S3 Resume Error Codes
E8 - S3 Resume Failed
E9 - S3 Resume PPI not Found
EA - S3 Resume Boot Script Error
EB - S3 OS Wake Error
EC - Reserved for future AMI error codes 31
ED - Reserved for future AMI error codes 31
EE - Reserved for future AMI error codes 31
EF - Reserved for future AMI error codes 31
Recovery Progress Codes
F0 - Recovery condition triggered by firmware (Auto recovery)
F1 - Recovery condition triggered by user (Forced recovery)
F2 - Recovery process started
F3 - Recovery fi rmware image is found
F4 - Recovery fi rmware image is loaded
F5 - Reserved for future AMI progress codes
F6 - Reserved for future AMI progress codes
F7 - Reserved for future AMI progress codes
Recovery Error Codes
F8 - Recovery PPI is not available
F9 - Recovery capsule is not found
FA - Invalid recovery capsule
FB - Reserved for future AMI error codes
FC - Reserved for future AMI error codes
FD - Reserved for future AMI error codes
FE - Reserved for future AMI error codes
FF - Reserved for future AMI error codes
ACPI/ASL Checkpoints
01 - System is entering S1 sleep state
02 - System is entering S2 sleep state
03 - System is entering S3 sleep state
04 - System is entering S4 sleep state
05 - System is entering S5 sleep state
10 - System is waking up from the S1 sleep state
20 - System is waking up from the S2 sleep state
30 - System is waking up from the S3 sleep state
40 - System is waking up from the S4 sleep state
AC - System has transitioned into ACPI mode. Interrupt controller is in APIC mode
AA - System has transitioned into ACPI mode. Interrupt controller is in APIC mode
