I2C Protokolü ile DS1621 Dijital Termosmetre
Başlatan ovaliiismail, 24 Mart 2018, 19:15:14
ovaliiismail
Merhaba arkadaşlar.I2C protokolünü kullanarak ds1621 ile dijital termosmetre tasarladım.Ama iki sorunla karşı karşıyayım.Birincisi buçuklu derecelerde ortam sıcaklığı TH'dan küçük olsa bile Tout lojik 1 oluyor.İkincisi TH veya TL buçuklu ayarlarsam Tout çıkışı hep lojik 0 oluyor.
#include <16f877.h>
#use delay (clock=4000000)
#define use_portb_lcd TRUE
#include <lcd.c>
#use i2c(master,sda=pin_c1,scl=pin_c0,slow=100000)
float ds1621_oku(void)
   float th,tl;
   float sicaklik;
   i2c_start();
   i2c_write(0x90);
   i2c_write(0x22);
   i2c_stop();
   i2c_start();
   i2c_write(0x90);
   i2c_write(0xee);
   i2c_stop();
   i2c_start();
   i2c_write(0x90);
   i2c_write(0xaa);
   i2c_start();
   i2c_write(0x91);
   th=i2c_read(0);
   i2c_start();
   i2c_write(0x91);
   tl=i2c_read(0);
   i2c_stop();
   if(tl==0x80)
      sicaklik=th+0.5;
      sicaklik=th;
   delay_ms(11);
   return(sicaklik);
void yaz_ds1621_th_tl(byte th_h, byte th_l, byte tl_h, byte tl_l)
   if(th_l==0x05)
      th_l=0x80;
   if(tl_l==0x05)
      tl_l=0x80;
   i2c_start();
   i2c_write(0x90);
   i2c_write(0xa1);
   i2c_write(th_h);
   i2c_write(th_l);
   i2c_stop();
   delay_ms(11);
   i2c_start();
   i2c_write(0x90);
   i2c_write(0xa2);
   i2c_write(tl_h);
   i2c_write(tl_l);
   i2c_stop();
   delay_ms(11);
void yaz_ds1621_ayar (byte deger)
   i2c_start();
   i2c_write(0x90);
   i2c_write(0xac);
   i2c_write(deger);
   i2c_stop();
   delay_ms(11);
byte oku_ds1621_ayar(void)
   byte con;
   i2c_start();
   i2c_write(0x90);
   i2c_write(0xac);
   i2c_start();
   i2c_write(0x91);
   con=i2c_read(0);
   i2c_stop();
   return(con);
char sonuc[17];
byte ayar;
void main()
   setup_psp(PSP_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_CCP1(CCP_OFF);
   setup_CCP2(CCP_OFF);
   lcd_init();
   delay_ms(5);
   ayar=oku_ds1621_ayar();
   bit_set(ayar,1);
   bit_clear(ayar,0);
   yaz_ds1621_ayar(ayar);
   yaz_ds1621_th_tl(24,0,21,0);
   while(1)
      sprintf(sonuc,"\fSicaklik=%0.1fC",ds1621_oku());
      printf(lcd_putc,"%s",sonuc);
      delay_ms(500);
