4lü Yüksek Voltajlı Amplifikatör (Opamp)
Başlatan M.Salim GÜLLÜCE, 29 Ocak 2021, 02:50:00
Zaman zaman ihtiyaç duyuluyor.
Şöyle bir kenarda dursun deyu ekledim.
Belki ihtiyacı olanlar da olur.
HV56264 Quad High Voltage Amplifier Array
Features:
•  Four Independent High Voltage Amplifiers
•  219V Output Voltage Swing
•  11V/µs Output Slew Rate
•  410µA Maximum Operating Current for High Voltage Supply
•  Wide Operating Close Loop Gain Range: 50 to 100V/V
•  150 kHz, -3 dB Bandwidth with 15 pF Load
•  AEC-Q100 Qualified
•  TSSOP and TFBGA Packages
Application:
•  Tunable Laser
•  Micro-Electromechanical Systems (MEMS) Driver
•  Test Equipment
•  Piezoelectric Transducer Driver
https://ww1.microchip.com/downloads/en/DeviceDoc/HV56264-Data-Sheet-DS20006477.pdf
