PIC16C74 ile dijital termometre
Başlatan ilker_32, 26 Temmuz 2009, 02:47:10
ilker_32
       list    p=pic16c74
        __config h'3ffa'        ;HS crystal, 20Mhz
        include <p16c74.inc>
temp    equ     0x20
target  equ     0x21            ;target temp value to trigger relay
targdly equ     0x22            ;used to pause display when setting target
flag    equ     0x23
cntr    equ     0x24
        org     0               ;reset vector
        goto    start           ;go to beginning of program on reset
        org     4
        btfsc   PIR1,TMR1IF     ;timer 1 overflowed?
        goto    timer1
        retfie
start   movlw   0xbf            ;'-' segment value
        movwf   PORTB           ;set output
        movwf   PORTD           ;latches to initial value
        clrf    PORTA           ;clear port a latches
        bsf     STATUS,RP0      ;select register bank 1
        clrf    PIE1            ;disable all peripheral interrupts
        bsf     TRISC,0         ;RC0 needs to be input for osc to function
        bsf     PIE1,TMR1IE     ;enable TMR1 int
        movlw   b'00000011'     ;RA0=A/D input, RA1=A/D input, RA2=Relay output
        movwf   TRISA           ;porta all input/analog
        clrf    TRISB           ;PORTB/PORTD output to 7-segment LEDs
        clrf    TRISD
        movlw   0x04            ;RA0 and RA1 Analog, RA2 Digital, Vref=Vdd
        movwf   ADCON1          ;set
        bcf     STATUS,RP0      ;select register bank 0
        bcf     T1CON,TMR1ON    ;timer 1 not on
        movlw   0x80            ;TIM1H:TIM1L = 0x8000 = 1sec
        movwf   TMR1H
        clrf    TMR1L
        clrf    INTCON          ;disable all interrupts
        clrf    PIR1            ;clear all falgs
        movlw   0x0e            ;T1CKPS1 (Prescale) = 1, T1OSCEN (osc shutoff) = enabled
        movwf   T1CON           ;T1SYNC (ext clk input) = no sync, TMR1CS = external
        bsf     INTCON,PEIE     ;enable peripheral interrupts
        bsf     INTCON,GIE      ;enable global ints
        call    getAD1          ;get target temp value
        movwf   target          ;save for compare
        clrf    targdly         ;clear target display counter
        clrf    flag            ;to tell which a/d to perform, RA0 or RA1
        bsf     T1CON,TMR1ON    ;turn timer on
        sleep
        goto    $-1
timer1  bcf     PIR1,TMR1IF     ;clear flag
        bcf     INTCON,GIE      ;disable all ints
        movlw   0x01            ;halfadd value
        xorwf   flag,1          ;compute operation to perform
        movf    flag,0
        addwf   PCL,1           ;go to proper routine
        goto    trgsamp
        goto    temsamp
trgsamp call    getAD1          ;get target value
        movwf   temp
        subwf   target,0        ;check it
        btfsc   STATUS,Z        ;zero set if equal, same target
        goto    timerx
        movf    temp,0          ;get new target value
        movwf   target
        movlw   0x01
        movwf   flag            ;do trigger sample next go around also
        goto    dispit
temsamp call    getAD0          ;get RA0 thermister value
        movwf   temp
        subwf   target,0
        btfss   STATUS,C
        bsf     PORTA,2         ;trigger relay, temp has reached goal
dispit  movlw   .186
        subwf   temp,0          ;end of table values
        btfsc   STATUS,C
        goto    valerr          ;error, value out of range
        movlw   .98             ;base of table values
        subwf   temp,0
        btfss   STATUS,C        ;if carry clear then
        call    temptab         ;convert to temp
setleds movwf   temp
        andlw   0x0f
        call    ledtab
        movwf   PORTB
        swapf   temp,0
        andlw   0x0f
        call    ledtab
        movwf   PORTD
timerx  bcf     PIR1,TMR1IF     ;clear flag
        movlw   0x80
        movwf   TMR1H
        clrf    TMR1L
        retfie                  ;enable ints and return to sleep
valerr  movlw   0xaa            ;0x0a is disp in ledtab to special out of range value
        goto    setleds
getAD0  movlw   b'10000001'     ;fosc/32, chan0 (RA0),  ADON
adconv  movwf   ADCON0
        clrf    cntr
        decfsz  cntr,1
        goto    $-1
        clrf    cntr
        decfsz  cntr,1
        goto    $-1
        bsf     ADCON0,GO
        btfsc   ADCON0,NOT_DONE  ;check if A/D complete
        goto    $-1
        movf    ADRES,0
        clrf    ADCON0          ;clear reg and shutdown AD logic
        return
getAD1  movlw   b'10001101'     ;fosc/32, chan1 (RA1), GO, ADON
        goto    adconv
; 7-segment conversion
ledtab  addwf   PCL,1
        retlw   0xc0    ;0
        retlw   0xfc    ;1
        retlw   0x92    ;2
        retlw   0x98    ;3
        retlw   0xac    ;4
        retlw   0x89    ;5
        retlw   0x81    ;6
        retlw   0xdc    ;7
        retlw   0x80    ;8
        retlw   0x8c    ;9
        retlw   0xbf    ;-
;tempature table
temptab addwf   PCL,1
        retlw   0x99    ;98
        retlw   0x98    ;99
        retlw   0x98    ;100
        retlw   0x97    ;101
        retlw   0x96    ;102
        retlw   0x95    ;103
        retlw   0x94    ;104
        retlw   0x93    ;105
        retlw   0x93    ;106
        retlw   0x92    ;107
        retlw   0x91    ;108
        retlw   0x90    ;109
        retlw   0x89    ;110
        retlw   0x89    ;111
        retlw   0x88    ;112
        retlw   0x87    ;113
        retlw   0x86    ;114
        retlw   0x86    ;115
        retlw   0x85    ;116
        retlw   0x85    ;117
        retlw   0x84    ;118
        retlw   0x83    ;119
        retlw   0x82    ;120
        retlw   0x81    ;121
        retlw   0x80    ;122
        retlw   0x80    ;123
        retlw   0x79    ;124
        retlw   0x78    ;125
        retlw   0x78    ;126
        retlw   0x77    ;127
        retlw   0x76    ;128
        retlw   0x76    ;129
        retlw   0x75    ;130
        retlw   0x74    ;131
        retlw   0x73    ;132
        retlw   0x72    ;133
        retlw   0x71    ;134
        retlw   0x70    ;135
        retlw   0x70    ;136
        retlw   0x69    ;137
        retlw   0x69    ;138
        retlw   0x68    ;139
        retlw   0x67    ;140
        retlw   0x67    ;141
        retlw   0x66    ;142
        retlw   0x65    ;143
        retlw   0x64    ;144
        retlw   0x63    ;145
        retlw   0x62    ;146
        retlw   0x62    ;147
        retlw   0x61    ;148
        retlw   0x60    ;149
        retlw   0x59    ;150
        retlw   0x59    ;151
        retlw   0x58    ;152
        retlw   0x58    ;153
        retlw   0x57    ;154
        retlw   0x56    ;155
        retlw   0x55    ;156
        retlw   0x54    ;157
        retlw   0x53    ;158
        retlw   0x53    ;159
        retlw   0x52    ;160
        retlw   0x51    ;161
        retlw   0x51    ;162
        retlw   0x50    ;163
        retlw   0x49    ;164
        retlw   0x49    ;165
        retlw   0x48    ;166
        retlw   0x47    ;167
        retlw   0x46    ;168
        retlw   0x45    ;169
        retlw   0x44    ;170
        retlw   0x44    ;171
        retlw   0x43    ;172
        retlw   0x42    ;173
        retlw   0x41    ;174
        retlw   0x40    ;175
        retlw   0x39    ;176
        retlw   0x39    ;177
        retlw   0x38    ;178
        retlw   0x37    ;179
        retlw   0x37    ;180
        retlw   0x36    ;181
        retlw   0x35    ;182
        retlw   0x34    ;183
        retlw   0x33    ;184
        retlw   0x32    ;185
        retlw   0x32    ;186
        end
