3-Pin Microprocessor Supervisor
Başlatan M.Salim GÜLLÜCE, 07 Aralık 2020, 03:57:27
Mikroişlemcilerde Besleme voltajındaki pürüzler zaman zaman kilitlenmesine sebep olabilir.
Microchip bu ürünle işlemciyi resetlemiş.
Oldukçada ufak Sot-23 kılıfında
Features:
•  4.5 μA Supply Current (Typical) at 3.6V
•  Open-Drain /RESET Output
•  /RESET Remains Valid with VCC as Low as 1V
•  20 ms, 140 ms, or 1120 ms Minimum Reset Timeout Options
•  2.63V to 4.63V Preset Voltage Threshold Options
•  2.5% Voltage Threshold Accuracy over Temperature
•  3-Pin SC-70 Package (2.0 mm x 2.1 mm)
•  3-Pin SOT-23 Package (2.3 mm x 2.9 mm)
•  –40°C to +125°C Junction Temperature Range
Applications:
•  Critical Microcomputer Power Monitoring
•  Portable Equipment
•  Solid State Drives
•  Printers/Computers
•  Embedded Controllers
https://ww1.microchip.com/downloads/en/DeviceDoc/MIC803-3-Pin-Microprocessor-Supervisor-Circuit-with-Open-Drain-Reset-Output-DS20006456A.pdf
ipek
Maxim'in MAX803'nü bire bir kopyalamış..
Alıntı yapılan: ipek - 07 Aralık 2020, 10:42:58Maxim'in MAX803'nü bire bir kopyalamış..
İlginç. Adıda aynı-> xxx803...
