Bu Programda bir hata varmı?
Başlatan Ankaralı, 04 Mart 2008, 19:16:09
Ankaralı
Merhabalar;
Programı derleyince Warning (102) code crosses boundary @800h veriyor.
Programda bir hata varmı?Ve ileri olarak portc.0 bitini high yapabiliyorum fakat geride portc.1 high olmuyor  :?   Teşekkürler.
BASLA:
IF PORTB.7=0 AND PORTB.6=1 AND PORTB.5=1 AND PORTB.4=1 AND PORTB.3=1 AND PORTB.2=1 AND PORTB.1=1 THEN ILERI
IF PORTB.7=0 AND PORTB.6=1 AND PORTB.5=1 AND PORTB.4=1 AND PORTB.3=1 AND PORTB.2=1 AND PORTB.1=0 THEN BEKLE
IF PORTB.7=0 AND PORTB.6=0 AND PORTB.5=1 AND PORTB.4=1 AND PORTB.3=1 AND PORTB.2=1 AND PORTB.1=0 THEN ILERI
IF PORTB.7=0 AND PORTB.6=0 AND PORTB.5=1 AND PORTB.4=1 AND PORTB.3=1 AND PORTB.2=1 AND PORTB.0=0 THEN BEKLE
IF PORTB.7=0 AND PORTB.6=0 AND PORTB.5=0 AND PORTB.4=1 AND PORTB.3=1 AND PORTB.2=1 AND PORTB.0=0 THEN ILERI
IF PORTB.7=0 AND PORTB.6=0 AND PORTB.5=0 AND PORTB.4=1 AND PORTB.3=1 AND PORTB.2=1 AND PORTC.7=0 THEN BEKLE
IF PORTB.7=0 AND PORTB.6=0 AND PORTB.5=0 AND PORTB.4=0 AND PORTB.3=1 AND PORTB.2=1 AND PORTC.7=0 THEN ILERI
IF PORTB.7=0 AND PORTB.6=0 AND PORTB.5=0 AND PORTB.4=0 AND PORTB.3=1 AND PORTB.2=1 AND PORTC.6=0 THEN BEKLE
IF PORTB.7=0 AND PORTB.6=0 AND PORTB.5=0 AND PORTB.4=0 AND PORTB.3=0 AND PORTB.2=1 AND PORTC.6=0 THEN ILERI
IF PORTB.7=0 AND PORTB.6=0 AND PORTB.5=0 AND PORTB.4=0 AND PORTB.3=0 AND PORTB.2=1 AND PORTC.5=0 THEN BEKLE
IF PORTB.7=0 AND PORTB.6=0 AND PORTB.5=0 AND PORTB.4=0 AND PORTB.3=0 AND PORTB.2=0 AND PORTC.5=0 THEN ILERI
IF PORTB.7=0 AND PORTB.6=0 AND PORTB.5=0 AND PORTB.4=0 AND PORTB.3=0 AND PORTB.2=0 AND PORTC.4=0 THEN BEKLE
IF PORTB.7=1 AND PORTB.6=0 AND PORTB.5=0 AND PORTB.4=0 AND PORTB.3=0 AND PORTB.2=0 AND PORTC.4=0 THEN GERI
IF PORTB.7=1 AND PORTB.6=0 AND PORTB.5=0 AND PORTB.4=0 AND PORTB.3=0 AND PORTB.2=0 AND PORTC.5=0 THEN BEKLE
IF PORTB.7=1 AND PORTB.6=1 AND PORTB.5=0 AND PORTB.4=0 AND PORTB.3=0 AND PORTB.2=0 AND PORTC.5=0 THEN GERI
IF PORTB.7=1 AND PORTB.6=1 AND PORTB.5=0 AND PORTB.4=0 AND PORTB.3=0 AND PORTB.2=0 AND PORTC.6=0 THEN BEKLE
IF PORTB.7=1 AND PORTB.6=1 AND PORTB.5=1 AND PORTB.4=0 AND PORTB.3=0 AND PORTB.2=0 AND PORTC.6=0 THEN GERI
IF PORTB.7=1 AND PORTB.6=1 AND PORTB.5=1 AND PORTB.4=0 AND PORTB.3=0 AND PORTB.2=0 AND PORTC.7=0 THEN BEKLE
IF PORTB.7=1 AND PORTB.6=1 AND PORTB.5=1 AND PORTB.4=1 AND PORTB.3=0 AND PORTB.2=0 AND PORTC.7=0 THEN GERI
IF PORTB.7=1 AND PORTB.6=1 AND PORTB.5=1 AND PORTB.4=1 AND PORTB.3=0 AND PORTB.2=0 AND PORTB.0=0 THEN BEKLE
IF PORTB.7=1 AND PORTB.6=1 AND PORTB.5=1 AND PORTB.4=1 AND PORTB.3=1 AND PORTB.2=0 AND PORTB.0=0 THEN GERI
IF PORTB.7=1 AND PORTB.6=1 AND PORTB.5=1 AND PORTB.4=1 AND PORTB.3=1 AND PORTB.2=0 AND PORTB.1=0 THEN BEKLE
IF PORTB.7=1 AND PORTB.6=1 AND PORTB.5=1 AND PORTB.4=1 AND PORTB.3=1 AND PORTB.2=1 AND PORTB.1=0 THEN GERI
IF PORTB.7=1 AND PORTB.6=1 AND PORTB.5=1 AND PORTB.4=1 AND PORTB.3=1 AND PORTB.2=1 AND PORTB.1=1 THEN BEKLE
BEKLE:
LOW PORTC.0
LOW PORTC.1
GOTO BASLA
ILERI:
HIGH PORTC.0
GOTO BASLA
GERI:
HIGH PORTC.1
GOTO BASLA
END
@ NEXYS2
Ankaralı
Bi fikri olan yokmu arkadaşlar  :lol:
@ NEXYS2
recebcolak
selam bende pıcbasici yeni yeni ögreniyorum bu eklentiler programın başında mevcut demi.mevcut değilse hata verebilir.
ILERI  var byte
BEKLE  var byte
ben herkesi sevdim bilmiyorum sevildimmi?
Logan
Bu hata, oluşturulan ASM dosyasının işlemci kapasitesini aştığını gösteriyor. Aynı programı başka bir işlemci ile denemeni tavsiye ederim.Ayrıca;
Alıntı Yap
değil,
Alıntı Yap
IF PORTB=%01111111 then ileri
deseydin, hex dosyanda ciddi bir azalma olurdu...
İmza.
Ankaralı
Alıntı yapılan: "Logan"Bu hata, oluşturulan ASM dosyasının işlemci kapasitesini aştığını gösteriyor. Aynı programı başka bir işlemci ile denemeni tavsiye ederim.Ayrıca;
Alıntı Yap
değil,
Alıntı Yap
Hocam 877 kullanıyorum 2850words toplam hex boyutu...Ben girişleri and lemek istediğim için bu şekilde yazdım...
@ NEXYS2
canbulut
bencede boundry=800h demesi yalnız normal istediklerin olmuyorsa inceleyemedim ama programsal hata olabilir...
Ankaralı
Alıntı yapılan: "canbulut"bencede boundry=800h demesi yalnız normal istediklerin olmuyorsa inceleyemedim ama programsal hata olabilir...
Evet program istediğim gibi çalışmıyor...Mantıksal bir hata var ama çözemedim...
@ NEXYS2
