En ucuz DSP kiti
Başlatan picusta, 19 Kasım 2009, 00:53:52
picusta
100 MHz + 320KB RAM +  donanimsal FFT hizlandiricisi + USB + emulator.
ögrenciyken bir DSP kartim olmasini hayal ederdim
ama bin dolarlik DSP kartlari, birkaç bin dollarlik gelistirme ortami bu hayalimi suya düsürdü.
O zaman böyle bir kartim olsaydi ne projeler yapardim  : Active noise cancelling, ultrasonik radar,  sesin geldigi yeri bulma, görüntü isleme vs...
Bu kartla tabii ki kayan yazi uygulamasi da yapilir, hiz ve bellek bol nasil olsa.
Debugger ve emulatör kartin üzerinde olup USB'den programlanip debug ediliyor.
Yakinda Matlab bu board'u destekleyecemis, böylece tek satir kod yazmadan Simulink'te çizidigimiz algoritma dogrudan kosacak.
Bugün siparis verdim :
49 dollar + 15 dollar yol parasi. gümrüge takilma riski çok düsük.
The TMS320VC5504 and TMS320VC5505 are industry's lowest power 16-bit processors helping conserve energy at exceptional levels and enabling longer battery life. With 200 MIPS performance, upto 320KB on-chip memory, higher integration (including a hardware accelerator for FFT computation) than comparable devices at a competitive price, C5504 and C5505 provide a foundation for a range of signal processing applications, including voice recorder, musical instruments, portable medical solutions and other consumer electronics in industrial and security applications.
Features of the TMDX5505eZdsp include:
   * Small form factor DSP development tool for C5505 processor
   * TMS320C5505 fixed point low power DSP
   * Embedded XDS100 emulator
   * I2C EEPROM
   * TLV320AIC3204 32-bit programmable low power stereo codec
   * Line In, Headphone Out Connectors
   * Expansion connector
   * Removable USB stick enclosure
   * Includes Code Composer Studio 4.0
   * Full documentation on CD-ROM
   * Software
         o Designers can readily target the TMS320VC5504/5 DSP through TI's robust and comprehensive Code Composer Studio development platform, including:
         o A complete Integrated Development Environment (IDE), an efficient optimizing C/C++ compiler assembler, linker, debugger, integrated CodeWright editor with CodeSense technology for faster code creation, data visualization, a profiler and a flexible project manager
         o DSP/BIOS(TM) real-time kernel
FullMetal
benim için çok iyi bir haber. web adresini paylaşabilirmisiniz?
azimli
kart elinize gelince yukarıdaki uygulama projelerinin hepsi yapılabiliyor demekki ne kadar güzel sizin adınıza ben sizden fazla sevindim varsa öyle bir çıkar yol ben 10000TL vermeye hazırım.
picusta
Alıntı yapılan: "azimli"kart elinize gelince yukarıdaki uygulama projelerinin hepsi yapılabiliyor demekki ne kadar güzel sizin adınıza ben sizden fazla sevindim varsa öyle bir çıkar yol ben 10000TL vermeye hazırım.
Tam olarak ne demek istedigini anlamadim dogrusu.
Söylediklerimi daha açiklik getireyim :
"ögrenciyken geçseydi" demistim.
Burada anahtar kelime "ögrenciyken" altinda sunlar gizleniyor:
- Bu projelere ayiracak daha çok zaman
- Daha çok ögrenme istegi
- Deneyim kazanma istegi.
- Teknik bilgilerin tazeligi.
- Parasizlik (tasima su ile degirmen pek dönmüyor)
Bu projeleri okulda teorisini gördüm, Matlab'ta simüle ettim, makette denedim.
Su an hepsini yapacak zamanim yok.
Is geregi yakin bir gelecekte Active noise cancelling projesini gerçeklestirecegim.
Sesin geldigi yeri bulma projesi bu forumda daha önce konusuldu ve enteresan bir proje oldugundan bos zamanim olunca onun üzerine yogunlasmak istiyorum.
Bu kartin diger kartlara göre getirisi :dijital sinyal islemleri için gerekli olan muazzam gerçek zaman hesaplama islemleri.  Dediginiz gibi : "uygulama projelerinin hepsi yapılabiliyor demekki ".
DSP (processing anlaminda) yapilmaya kalkildiginda dsPic33 veya ARM7 bu kartin yaninda oyuncak kalir, çünkü bu "gerçek" bir DSP (processor anlaminda).
Fiyati ise ortalama bir PIC16 dev board'dan az.
Burada paylastim ki gençlerin vizyonu açilsin.
Board Texas Instrument sitesinden dogrudan siparis edilebilir.
Simdi biraz is konusalim :
O fiyata beni 2 hafta kiralayabilirsin.Hangi proje ile ilgileniyorsun?
gaktas
BU KART ELİMDE VAR BİTİRME İÇİN ALDIK AMA KAYNAK SIKINTISI ÇEKİYORUM ÖRNEK KOD DA YOK PEK KİMSE UĞRAŞMAMIŞ ANLAŞILAN.. EĞER DEDİĞİNİZ GİBİ UYGULAMA GELİŞTİRDİYSENİZ BU KARTLA YARDIMCI OLURSANIZ SEVİNİRİM.. EN AZINDAN KAYNAK SAĞLARSANIZ.. SON MESAJ KASIMDA OLDUĞUNA GÖRE DENEME ŞANSINIZ OLMUŞTUR DİYE UMUYORUM
hasangurlek
Alıntı yapılan: gaktas - 25 Mart 2010, 03:20:21
Küçük harflerle yazmaya, büyük harfleri ise yerlerinde kullanmaya dikkat ederiz.
Bu sayede 'Caps Lock' ledimizin yaşam süresinide uzatırız  :)
http://www.cyber-warrior.org, Although they like whiteness, sometimes twilight is required...  Hala evlilermi bilinmez ama kesinlikle artık uygun değiller !!!
mumco
Alıntı yapılan: picusta - 19 Kasım 2009, 00:53:52
    * I2C EEPROM
    * Software
netstal enjeksiyon makınalarının istetim sistemi ile bir alakası varmı bu konunun?
DSP (dijital signal processing)
Firzen
Aynı DSP den bende de var ama boş boş yatıyor yani. Bir türlü nasıl başlanır yapılır bulamadım. İşin garip tarafı yapanlarda matlabta yapıyor bu proje matlabta yapıalcaksa ki matlab fiyatı + eklenti fiyatları astarı yüzünü geçiyor. Siz nasıl programlama yapıyorsunuz (Yapan kişiler için söylüyorum). ? Bir kaç örnek gösterebilir misiniz?
Kararsız...
Matlabın ürettiği kodu DSP'ye atıp ardından da ben DSP de proje geliştirdim denemez.
Led yakıp söndürmeyle başla, ardından mesela 16 bit tam, 16 bit kesirli sayılarla çarpma, toplama, çıkartma, işlemi yap.
Bunlardan sonra da Z domenine dal, fark denklemlerinden çık sonra da klavyede kodlamasını yap.
Firzen
Alıntı yapılan: z - 16 Ocak 2014, 13:44:04
Z hocam sinyaller sistemler de bu işlemlerin matlab ile nasıl yapıldığını gördüm biliyorumda. Daha önce nasıl DSP ye matlabsız CCStudio kullanarak yapılıyor bilmiyorum. Nasıl yapıldığı konusunda Led yakıp söndürme de dahil hep hazır var sadece.
Kararsız...
IDE yi biliyorsan sorun yok.
DSP kullanmanın işlemci kullanmadan hiç bir farkı yokki.
Hele hele C kullanacaksan hiç sorun yok.
Kütüphane kullanacaksan kütüphanelerin kullanımını öğreneceksin. Yok Asm kullanacaksan asm dilini öğreneceksin.
Led yak söndür projesini ayrı bir klasöre kopyalayıp  üzerinde pratik yap.
Matlabsız nasıl yapılır?
Direk Z domeninde tasarımı bilmiyorum. Bir sistemin S domenindeki tasarımını yaptıktan sonra, Z domenine geç.
Z domeninden de fark denklemlerine geç.
Geriye kod yazma kalıyor.
DSP de sonuçta bir işlemci.
Hazır örneklerden bir kaçtanesini inceleyip anlamak zorundasın.
selimkoc
ARM M4 core içinde DSP de var.  STM32F4 Discovery fiyatı 15$.
Firzen
Alıntı yapılan: z - 16 Ocak 2014, 15:47:01
Elimde bununla ilgili bir kitap var "PANTECH EC2306 DIGITAL SIGNAL PROCESSING LAB MANUAL TMS320C5505 DSP" diye. İnceledim o da matlab kullanmış neyse hocam bir daha deneyip bakarım teşekkür ederim tekrardan olmazsa yine sizdeyim :D
Kararsız...
S domeninden Z domenine geçiş sonrasında frekans eğilmesi konusunu dikkate alman gereken durumlar olabilir.
http://www.cncdesigner.com/wordpress/?p=2799
ayrıca
http://www.cncdesigner.com/wordpress/?p=1671
