Yeni MPLAB X IDE v1.10 (NETBEANS Tabanlı)
Başlatan muuzoo, 06 Kasım 2010, 15:50:41
NaMcHo
Merhabalar,
MPLAB-X ile MPLAB8.56 da calısan bir kodumu derledim ve şu çıktıyı aldım
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory `/c/Users/NaMcHo/Documents/Projelerim/ADC SON/deneme.X/deneme'
make  -f nbproject/Makefile-default.mk dist/default/production/deneme.production.cof
make[2]: Entering directory `/c/Users/NaMcHo/Documents/Projelerim/ADC SON/deneme.X/deneme'
mkdir -p build/default/production/_ext/43898991
C:\\Program\ Files\ \(x86\)\\HI-TECH\ Software\\PICC\\9.71a\\bin\\picc.exe --pass1 ../../delay.c -q --chip=PIC16F877 -P  --outdir=build/default/production/_ext/43898991 -N31 -I"../.." --warn=0 --runtime=default,+clear,+init,-keep,+osccal,-resetbits,-download,+stackcall,+clib --opt=default,+asm,-speed,+space,-debug,-9 -D__DEBUG  --double=24 --float=24 --addrqual=ignore -mode=std -g --asmlist "--errformat=%f:%l: error: %s" "--msgformat=%f:%l: advisory: %s" "--warnformat=%f:%l warning: %s"
C:\\Program\ Files\ \(x86\)\\HI-TECH\ Software\\PICC\\9.71a\\bin\\picc.exe --scandep --pass1 ../../delay.c -q --chip=PIC16F877 -P  --outdir=build/default/production/_ext/43898991 -N31 -I"../.." --warn=0 --runtime=default,+clear,+init,-keep,+osccal,-resetbits,-download,+stackcall,+clib --opt=default,+asm,-speed,+space,-debug,-9 -D__DEBUG  --double=24 --float=24 --addrqual=ignore -mode=std -g --asmlist "--errformat=%f:%l: error: %s" "--msgformat=%f:%l: advisory: %s" "--warnformat=%f:%l warning: %s"
echo "build/default/production/_ext/43898991/delay.p1:\\" > build/default/production/_ext/43898991/delay.p1.d
cat build/default/production/_ext/43898991/delay.dep | sed -e 's/\\/\//g' -e 's/ /\\ /g' -e 's/^.*$/ &\\/g'  >> build/default/production/_ext/43898991/delay.p1.d
C:\\Program\ Files\ \(x86\)\\HI-TECH\ Software\\PICC\\9.71a\\bin\\picc.exe --pass1 ../../main.c -q --chip=PIC16F877 -P  --outdir=build/default/production/_ext/43898991 -N31 -I"../.." --warn=0 --runtime=default,+clear,+init,-keep,+osccal,-resetbits,-download,+stackcall,+clib --opt=default,+asm,-speed,+space,-debug,-9 -D__DEBUG  --double=24 --float=24 --addrqual=ignore -mode=std -g --asmlist "--errformat=%f:%l: error: %s" "--msgformat=%f:%l: advisory: %s" "--warnformat=%f:%l warning: %s"
../../main.c:10: error: undefined identifier "TRISA"
../../main.c:11: error: undefined identifier "TRISB"
../../main.c:11: error: undefined identifier "PORTB"
../../main.c:12: error: undefined identifier "TRISC"
../../main.c:12: error: undefined identifier "PORTC"
../../main.c:14: error: undefined identifier "CHS0"
../../main.c:14: error: undefined identifier "CHS1"
../../main.c:14: error: undefined identifier "CHS2"
../../main.c:15: error: undefined identifier "PCFG0"
../../main.c:15: error: undefined identifier "PCFG1"
../../main.c:15: error: undefined identifier "PCFG2"
../../main.c:15: error: undefined identifier "PCFG3"
../../main.c:16: error: undefined identifier "ADCS0"
../../main.c:16: error: undefined identifier "ADCS1"
../../main.c:18: error: undefined identifier "ADFM"
../../main.c:19: error: undefined identifier "ADON"
../../main.c:30: error: undefined identifier "ADGO"
../../main.c:32: error: undefined identifier "ADRESL"
../../main.c:32: error: undefined identifier "ADRESH"
../../main.c:34 warning: implicit conversion of float to integer
make[2]: *** [build/default/production/_ext/43898991/main.p1] Error 1
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
make[2]: Leaving directory `/c/Users/NaMcHo/Documents/Projelerim/ADC SON/deneme.X/deneme'
make[1]: Leaving directory `/c/Users/NaMcHo/Documents/Projelerim/ADC SON/deneme.X/deneme'
BUİLD FAILED (exit value 2, total time: 2s)
Biraz kurcalamama rağmen sorunu halledemedim.
justice_for_all
denetleyicinizi taniyamamis arkadasim o satiri yazabilirmisiniz...
teknikelektronikci
selam bende su an yeni proje oluistuirmak istedim select compiler bölümünde 3 tane hi-tech picc18 yesil yani aktif tabi 18 serisini sectgiim icin ama altlarinda none found yaziyor var olan compilerimi görmüyor bunu nasil göstrebilirim ?
justice_for_all
Tools ,Options, Embedded section
dan compiler lari gosteriyo...
NaMcHo
#include <pic.h>
#include "delay.h"
#include "LCD216_benim.h"
unsigned int adc,x;
float voltaj;
void main(void)
TRISA=0x01;
TRISB=0; PORTB=0;
TRISC=0; PORTC=0;
CHS0=0; CHS1=0; CHS2=0//RA0 dan ADC i�lemi gerceklescek.
PCFG0=0; PCFG1=1; PCFG2=1; PCFG3=1; //RA0 Analog di�erleri dijital.
ADCS0=1; ADCS1=1; //RC osilat�r secildi ADC icin.
ADFM=1;                 //Sa�a dayal� olarak yaz�lcak yani 10bitlik.
ADON=1;
lcd_hazirla();
lcd_yaz("Voltaj Ust SINIR");
imlec(2,1);
lcd_yaz("30V'dur!");
for(x=0;x<10;x++)
DelayMs(100);
lcd_temizle();
for(;;)
ADGO=1;
while(ADGO); //ADC i�lemi bitene kadar bekle.
adc=ADRESL; adc+=(unsigned int)ADRESH*256;
voltaj=(30.0/1023)*adc;
x=voltaj*100;
imlec(1,1);
lcd_yaz("ADC:");
lcd_karakter_yolla(adc/1000 + 48);
lcd_karakter_yolla((adc%1000)/100 + 48);
lcd_karakter_yolla((adc%100)/10 + 48);
lcd_karakter_yolla(adc%10 +48);
imlec(2,1);
lcd_yaz("Voltaj:");
lcd_karakter_yolla(x/1000 + 48);
lcd_karakter_yolla((x%1000)/100 + 48);
lcd_yaz(".");
lcd_karakter_yolla((x%100)/10 + 48);
lcd_karakter_yolla(x%10 + 48);
lcd_yaz("V");
DelayMs(100);
Justice_for_all kod bu :)
birde 9.80 i gormuyor bu mplab x   sizdede aynı sorun varmı?
justice_for_all
Alıntı yapılan: NaMcHo - 07 Kasım 2010, 21:22:14 [Genişlet]
#include <pic.h>
#include "delay.h"
unsigned int adc,x;
float voltaj;
void main(void)
TRISA=0x01;
TRISB=0; PORTB=0;
TRISC=0; PORTC=0;
ADON=1;
lcd_hazirla();
imlec(2,1);
for(x=0;x<10;x++)
DelayMs(100);
lcd_temizle();
for(;;)
ADGO=1;
x=voltaj*100;
imlec(1,1);
lcd_yaz("ADC:");
imlec(2,1);
lcd_yaz("Voltaj:");
lcd_yaz(".");
lcd_yaz("V");
DelayMs(100);
eger compileri gormuyosa bi ustte verdim menulere tiklayarak compilerinizi tanitabilirsiniz...
ayrica compileri gormeyince de olur...
Deneyin bi..
teknikelektronikci
compileri görmeyince nasil olur derleyemezki sadece hatali olanlari kirmizi cizer yanlismiyim ? ayrica bende halen görmüyor
justice_for_all
Alıntı yapılan: teknikelektronikci - 07 Kasım 2010, 21:42:02
sizde kirmizi cizgi olayi meydana geldimi peki
mplap x i indirdigin sitede Getting_Started_with_MPLAB-X.pdf dosyasinda butun seyleri anlatiyor..
hi-tech kullanmadigin icin bilmiyorum ordada hi-techten bahsetmemis..
ama islemci adini yazarken buyuk kucuk harflere duyarli oldugu yaziyor...
justice_for_all
peki bahsettigim embedded penceresini bulabildiniz mi?
teknikelektronikci
ben buldum ordan bi klasörünü göstermeye calisorum bos ollarak görüyor
justice_for_all
isterseniz dedigim pdfi indirip bi goz atin cunku orda oyle yaziyo...
justice_for_all
dsPIC30F2020.gld dosyasinin adresini gosterip tekrar denermisiniz...
teknikelektronikci
fxdev gene yapacagini yapmisin :D eline saglik ama epey bi degisiklik yapmak gerekyior sanirsam bu kötü :)
justice_for_all
program files tan microchip C30 support die hatırlıyorum orda tine ayrılıyo sanırım 30f 33f 24f die bibalın isterseniz
justice_for_all
peki sorun neymiş ben telden baglandıgım için acamıyorum videoyu...
