Ynt: CCS DE DS1307 nin Sout ucundan 1 sn aralıklarla çıkış bilgisi nasıl alınır.
Başlatan Murat Mert, 05 Eylül 2012, 10:03:08
Murat Mert
CCS de DS1307 den B4 portuna 1 sn aralıkla SOUT ucundan bilgi almak istiyorum nasıl yapabilirim?
mesaj birleştirme:: 05 Eylül 2012, 16:46:32
S.A.
i2c_write(0x08);     // Disable squarewave output pin  YERİNE
i2c_write(0x01);     // Disable squarewave output pin  YAPTIM
Simülasyonda bir çıkış alamadım
Şöyle basit bir progda yaptım.
#include <18F4580.h>
#device adc=10
#FUSES HS
#use delay(clock=20000000)
#include "wh1604.c"
#include "ds1307cc.c"
void main()
  BYTE sec;
  BYTE min;
  BYTE hrs;
  BYTE day;
  BYTE month;
  BYTE yr;
  BYTE dow;
  ds1307_init();
  lcd_init();
  // Set date for -> 15 June 2005 Tuesday
  // Set time for -> 15:20:55
  ds1307_set_date_time(05,9,12,2,21,10,00); //tarih ve saatin ilk ayarı ilk yükledikten sonra burayı de-aktif edip tekrar yükledim
  output_high(pin_d0);
  while(1)
    delay_ms(100);
    ds1307_get_date(day,month,yr,dow);
    ds1307_get_time(hrs,min,sec);
    lcd_gotoxy(1,1);
    printf(lcd_putc,"%02d/\%02d/\%02d",day,month,yr);
    lcd_gotoxy(1,2);
    printf(lcd_putc,"\%02d:\%02d:\%02d", hrs,min,sec);
mert07
necati
Murat Mert
S.A.
Yazılımın ds1307 driveri altta
///                               DS1307.C                                   ///
///                     Driver for Real Time Clock                           ///
/// ds1307_init() - Enable oscillator without clearing the seconds register -///
///                 used when PIC loses power and DS1307 run from 3V BAT     ///
///               - Disable squarewave output                                ///
/// ds1307_set_date_time(day,mth,year,dow,hour,min,sec)  Set the date/time   ///
/// ds1307_get_date(day,mth,year,dow)               Get the date             ///
/// ds1307_get_time(hr,min,sec)                     Get the time             ///
#define RTC_SDA  PIN_C4
#define RTC_SCL  PIN_C3
#use i2c(master, sda=RTC_SDA, scl=RTC_SCL)
BYTE bin2bcd(BYTE binary_value);
BYTE bcd2bin(BYTE bcd_value);
void ds1307_init(void)
   BYTE seconds = 0;
   i2c_start();
   i2c_write(0xD0);      // WR to RTC
   i2c_write(0x00);      // REG 0
   i2c_start();
   i2c_write(0xD1);      // RD from RTC
   seconds = bcd2bin(i2c_read(0)); // Read current "seconds" in DS1307
   i2c_stop();
   seconds &= 0x7F;
   delay_us(3);
   i2c_start();
   i2c_write(bin2bcd(seconds));     // Start oscillator with current "seconds value
   i2c_start();
   i2c_write(0x07);      // Control Register
   //i2c_write(0x08);     // Disable squarewave output pin
   //i2c_write(0x10);     // Disable squarewave output pin --bunu yaptım oda olmadı
    i2c_write(0x92);     // Disable squarewave output pin --burasını değiştirdim
   i2c_stop();
void ds1307_set_date_time(BYTE day, BYTE mth, BYTE year, BYTE dow, BYTE hr, BYTE min, BYTE sec)
  sec &= 0x7F;
  hr &= 0x3F;
  i2c_start();
  i2c_write(0xD0);            // I2C write address
  i2c_write(0x00);            // Start at REG 0 - Seconds
  i2c_write(bin2bcd(sec));      // REG 0
  i2c_write(bin2bcd(min));      // REG 1
  i2c_write(bin2bcd(hr));      // REG 2
  i2c_write(bin2bcd(dow));      // REG 3
  i2c_write(bin2bcd(day));      // REG 4
  i2c_write(bin2bcd(mth));      // REG 5
  i2c_write(bin2bcd(year));      // REG 6
  i2c_write(0x80);            // REG 7 - Disable squarewave output pin
  i2c_stop();
void ds1307_get_date(BYTE &day, BYTE &mth, BYTE &year, BYTE &dow)
  i2c_start();
  i2c_write(0xD0);
  i2c_write(0x03);            // Start at REG 3 - Day of week
  i2c_start();
  i2c_write(0xD1);
  dow  = bcd2bin(i2c_read() & 0x7f);   // REG 3
  day  = bcd2bin(i2c_read() & 0x3f);   // REG 4
  mth  = bcd2bin(i2c_read() & 0x1f);   // REG 5
  year = bcd2bin(i2c_read(0));            // REG 6
  i2c_stop();
void ds1307_get_time(BYTE &hr, BYTE &min, BYTE &sec)
  i2c_start();
  i2c_write(0xD0);
  i2c_start();
  i2c_write(0xD1);
  sec = bcd2bin(i2c_read() & 0x7f);
  min = bcd2bin(i2c_read() & 0x7f);
  hr  = bcd2bin(i2c_read(0) & 0x3f);
  i2c_stop();
  BYTE temp;
  BYTE retval;
  temp = binary_value;
  retval = 0;
  while(1)
    // Get the tens digit by doing multiple subtraction
    // of 10 from the binary value.
    if(temp >= 10)
      temp -= 10;
      retval += 0x10;
    else // Get the ones digit by adding the remainder.
      retval += temp;
      break;
  return(retval);
// Input range - 00 to 99.
  BYTE temp;
  temp = bcd_value;
  // Shifting upper digit right by 1 is same as multiplying by 8.
  temp >>= 1;
  // Isolate the bits for the upper digit.
  temp &= 0x78;
  // Now return: (Tens * 8) + (Tens * 2) + Ones
  return(temp + (temp >> 2) + (bcd_value & 0x0f));
yukarıdaki değişiklikleri yaptım ama olmadı.
mesaj birleştirme:: 06 Eylül 2012, 14:33:03
S.A.
Yeni bir dosya oluşturup yeni başka isimli proje oluşturdum yukarıdaki kodlar çalıştırdı.
Allah Allah ccs de bu bazen oluyor ilginç. Neyse kullanacaklara kolay gelsin.
mert07
