CCS C'de While döngüsü nasıl yapılıyor?
Başlatan veliusta, 18 Nisan 2013, 23:05:54
veliusta
#include <16f877a.h>
#device ADC=10
#fuses XT,NOLVP,NOBROWNOUT,NOWDT,NOPROTECT,NODEBUG,NOPUT,NOWRT,NOCPD
#use delay(clock=4000000)
#use fast_io(a)
#use fast_io(b)
#define use_portb_lcd TRUE
#include <lcd.c>
unsigned long int dijital;
float volt;
void main()
set_tris_a(0x01); //0000 0001
set_tris_b(0x00);
setup_adc(adc_clock_div_32);
setup_adc_ports(all_analog);
lcd_init();
printf(lcd_putc,"\f   Veli USTA   ");
delay_ms(500);
printf(lcd_putc,"\n ADC UYGULAMASI ");
delay_ms(500);
output_high(pin_b3);
delay_ms(250);
output_low(pin_b3);
delay_ms(250);
delay_ms(250);
output_low(pin_b3);
delay_ms(250);
delay_ms(250);
output_low(pin_b3);
delay_ms(250);
delay_ms(250);
output_low(pin_b3);
delay_ms(250);
while(1)
set_adc_channel(0);
delay_us(20); //Muhakkak verilmeli!
dijital=read_adc();
volt=0.0048828125*dijital;
printf(lcd_putc,"\fDijital=%lu",dijital);
printf(lcd_putc,"\nAnalog=%.2fV",volt);
delay_ms(1000);
printf(lcd_putc,"\f ADC UYGULAMASI ");
delay_ms(250);
printf(lcd_putc,"\nTEKRAR BASLIYOR!");
delay_ms(1000);
delay_ms(250);
output_low(pin_b3);
delay_ms(250);
Yukaridaki kodu 8 kerede yazmak istemiyorum ayrica :(
halilgalic
tekrar etmek için for döngüsü kullanman lazım
for(tekrar=0;tekrar<50;tekrar++){//50 tekrar sayısı
//tekrar ettireceğin komut
Eren Eraslan
Alıntı yapılan: veliusta - 18 Nisan 2013, 23:05:54
#device ADC=10
#use fast_io(a)
#use fast_io(b)
#include <lcd.c>
float volt;
void main()
set_tris_b(0x00);
lcd_init();
delay_ms(500);
delay_ms(500);
delay_ms(250);
output_low(pin_b3);
delay_ms(250);
delay_ms(250);
output_low(pin_b3);
delay_ms(250);
delay_ms(250);
output_low(pin_b3);
delay_ms(250);
delay_ms(250);
output_low(pin_b3);
delay_ms(250);
int i;
while(1)
dongu:
for(i=0;i<50;i++)
set_adc_channel(0);
delay_us(20);
dijital=read_adc();
i++;
delay_ms(1000);
delay_ms(250);
delay_ms(1000);
goto dongu;
delay_ms(250);
output_low(pin_b3);
delay_ms(250);
insanın içine işleyen şarkılar ;  https://soundcloud.com/reeraslan
Okan AKÇA
C tam olarak anlamak gerekiyor for dongüsü nerede kullanılması gerektigini  iyi bulmak gerekiyor.
veliusta
Bilgiler için herkese teşekkürlerimi sunarım.
Gökhan BEKEN
for ve while aynı değildir.
while daha kapsamlıdır. Derleyici ikisinde aynı işi yapıyor olarak görükebilir ama arkaplanda daha farklı asm kod üretebilir yani dosyanın boyutu artabilir. Hangisini kullandığınız çok önemli değil ama her derleyici her komutu düzgün veya tam verimli çalıştıramayabiliyor.
byte i=0;
do
i++;
//50 kere çalışmasını istediğiniz komutlar
while ( i<50 ); //i , 50 den küçük olduğu sürece do ile başlayan yere git
bu yöntemin dışında aşağıdaki yöntem var
byte i=0;
while ( i<50 ); //i , 50 den küçük olduğu sürece aşağıdaki döngüyü çalıştır
i++;
do-while ile while arasında bir fark var. while döngüsünde ilk iş şarta bakmak olur, şart sağlanırsa döngüye öyle girer değilse hiç girmez. Ancak do-whilede önce bir kez komutları çalıştırır sonra şarta bakar eğer şart sağlanıyorsa tekrar başa döner yoksa devam eder.
ayrıca goto komutu ve if kullanarak ta aynı işi yapabilirsiniz
byte i=0;
dongu:
if(i<50){
 i++;
 //50 kere çalışması gereken komutlar
 goto dongu;
ayrıca sonsuz döngü için şunlar yazılabilir
for(;;)
sonuz:
goto sonsuz;
while(1)
vs vs
speak48
while ile yapılan herşey for la
for la yapılan herşey while ile
while for ile yapılan herşey if le
yapılabilinir.
sonuçta asmbli aynı
cmp bra goto inc dec goto
ayrıca while kullanmayı tercih etmem
while hadi yap du bakalım nolucak gibi sonu kestirilemiyen  bir işi bilgisayara yaptırmak gibi gelir
ki sonunu kestirelemiyorsa kensin whilenın içinde hata verecektir onun yerine her zaman for u kullanırım.
Gökhan BEKEN
while()
şeklindedir, parantez içine her türlü şart yazabilirsiniz, ister 1 tane şart yazın ister 10 tane
for(;;)
3 parametre alır.
speak48
forun artısı vardır eksiği yoktur
a=50;
for(;a>40;)
           printf("%d\n",a);
           a--;
a=50;
while(a>40)
           printf("%d\n",a);
           a--;
printf("forlan bu boru mu\n");
elektronik
while(1)
//BURASI 50 DEFA DÖNECEK
i++;
if(i>50)
i=0;
//İ DEĞİŞKENİ 50 OLDUĞUNDA BURAYI 1 DEFA OKUYUP DÖNGÜDEN ÇIKACAK
break;// DÖNGÜDEN ÇIKIYOR
while(1)
set_adc_channel(0);
dijital=read_adc();
delay_ms(1000);
i++;
if(i>50)
i=0;
delay_ms(250);
delay_ms(1000);
Okan AKÇA
 ;D hepsinlede dongü işini yapabilirsiniz  for fonksiyanların toplanmış hali
elektronik
cevapları, sadece başlığı okuyarakmı veriyorsunuz ?   başlık : Ynt: CCS C'de While döngüsü nasıl yapılıyor?
arkadaş döngüyü zaten yapmış . soru başka.
o kadar hızlı yaşıyoruzki bir metnin yanlızca başlığını okuyup içeriğini anlamaya çalışıyoruz
bizler için zaman çok hızlı akıyor zaman bize yetmiyor. bazı insanlarda  kahvehanelerde zaman öldürmeye çalışıyorlar.
