Picproje Facebook Sayfası:  https://bit.ly/2pUitll
TRANSLATOR 10.0 PLUS
Başlatan XNHCX, 19 Mayıs 2006, 22:45:31
XNHCX
Alıntı YapFinally, a true office translation solution. Foreign languages won t be a limitation at work or in private life. It allows you to write documents, surf the Net and chat via e-mail with people of other nationalities without problems. A software tool that will truly create a global village. This splendid suite contains three easy-to-use software applications, that will let you work in six different languages: English, French, German, Italian, Portuguese and Spanish.
The software is designed with a very simple, intuitive interface. In fact, it recreates a work environment similar to that of a word processor s. The program lets you import documents and simultaneously translate them in Word, RTF and HTML formats. Thanks to a sophisticated Landamp;HTM algorithm, it generates drafts of translations easily and quickly. It s an indispensable support in composing and translating letters, faxes, e-mail and documents in the most-spoken foreign languages. In the case of ambiguities, TRANSLATOR 10.0 PLUS interactive mode lets you select the most appropriate meaning phrase by phrase, improving the translation s quality. In automatic mode, the text will be translated immediately in its entirety or suggest the translation possibility of each word. You can easily update dictionaries, adding new words and idioms or modifying existent listings.
Features:
Wordprocessor-like approach.
Text translator for selected word and for full text in 6 languages.
Possibility to listen to the right pronunciation of a word or phrase.
Dictionaries update to personalize word translation.
Intuitional interface with a new online help.
Minimum system requirement:
586 Pentium or equivalent processor
Windows 98, Windows ME, Windows 2000 / XP
64 MB RAM
Download: 86 MB !!
Part1: http://www.megaupload.com/?d=I0GVE1L6
Part2: http://www.megaupload.com/?d=VH0UES6S
Part3: http://www.megaupload.com/?d=A88XSBS7
Part4: http://www.megaupload.com/?d=A9BPVRPA
tüh geç kaldım erşim engellenmiş
XNHCX
Türkiye serverları dışındaki proxy server kullanmanızı tavsiye ederim.Bu konunun çözümü için aşağıdaki başlıktaki mesaja bakınız...
SpeedyX 'in yazısına...
Merriam-Webster''''''''''''''''s 11th Collegiate Dictionary
https://www.picproje.org/index.php/topic,9973
