Hi-tech c'de kesme lütfen!!!
Başlatan salih18200, 20 Temmuz 2007, 21:58:41
salih18200
Arkadaşlar hi-tech te kesme uygulaması yapmak istiyorum o kadar araştırmama rağmen hiç bir sonuca ulaşamadım lütfen yardım edin.
muuzoo
HI-TECH sample klasöründen alıntdır.
#include	<pic.h>
 *	Interrupt demo for PIC; wait for button press on RB0/INT,
 *	turn on a relay on another port bit for a period of time.
 *	For simplicity here, literal constants are used, usually these
 *	should be calculated with compile-time arithmetic.
#define RELAY RB4					// use this bit to drive relay
static unsigned int	relay_timer;	// timer value for relay driver
void
main(void)
	/* setup stuff */
	RELAY = 1;		// ensure relay is off before enabling output
	TRISB = 0x03;	// Port B bits 7 and 6 are output
	OPTION	= 0b00000111;
	TRISB	= 0b00000011;
	RBPU = 0;		// Use internal pullups
	T0IE = 1;		// Enable interrupt on TMR0 overflow
	INTEDG = 1;		// falling edge trigger the interrupt
	INTE = 1;		// enable the external interrupt
	GIE = 1;		// Global interrupt enable
	for(;;){
		CLRWDT();	// Idly kick the dog
static void interrupt
isr(void)			// Here be interrupt function - the name is unimportant.
	if(T0IF) {				// timer interrupt
		PORTB ^= 4;
		if(relay_timer){// is the relay timer running?
			relay_timer--;	// decrement it
			PORTB |= 8;
		}else{
			RELAY = 1;		// turn the relay off
			PORTB &= ~8;	// toggle a bit to say we're alive
		T0IF = 0;			// clear the interrupt flag
	if(INTF) {				// did we see a button press?
		RELAY = 0;			// turn the relay on
		relay_timer = 16;	// start the timer - 16 timeouts ~ 1 second
		INTF = 0;			// clear the interrupt
