Bu LCD LM0xxxx serisinden hangisidir??
Başlatan Digimensch, 09 Ocak 2005, 17:34:25
Digimensch
Arkadaslar elimde bir LCD var arkasinda 3 tane HD44105H adinda Chip var.
Ekrani herhalde 4 Line'li bayagi genis.
Acaba bu LCD'nin Datasheetini nerde bulabilirim?
Nette aradim bulamadim.
ve bu LCD icin PicBasic Kod örnekleri veren bir Link varmi??
Veli B.
Alıntı Yap
Hitachi      HD44105H   Dot matrix liquid crystal graphic disp common driver
net böyle diyor
Hitachinini sitesine bir bak...[/code]
Digimensch
Bu Hitachi HD44105H icin Hitachinin sitesinde Datasheet bilgisi yok.
Nette aradim ama bulamadim.
neyse aramaya devam edeyim belki birseyler bulurum.
saygilar
teknisyen
Page 1
IC/Discrete 93-01: Number:
Mon Jan 10 15:39:56 2005
MFR Part Number: HD44105H
Device Information
INTERFACE
 DISPLAY DRIVERS
   Display Drivers, Dot Matrix, Multiple Character
               Manufacturer Source Code: Hitachi Ltd
                          Device Status: ACTIVE
                         Generic Number: 44105
                             Technology: CMOS
                          Package Style: FP
                         Number of Pins: 60
                        Surface Mounted: YES
              Display Type - Technology: LCD
                        V(IL) - Maximum: 1.5
                        V(IH) - Minimum: 3.5
           No. of Outp Lines to Display: 32
                   Output Configuration:
                        V(OL) - Maximum: 0.4
           @I(OL){Test Cond: V(OL)-Max}: 400u
                   V(OH), Rated Maximum:
            Supply Voltage, Nominal Neg: 5.5
            Supply Voltage, Nominal Pos: 5.0
                P(D) - Absolute Maximum: 4.4m
               Operating Temp - Minimum: -20
               Operating Temp - Maximum: 75
                            Reliability: Commercial
          M38535 Military Specification:
                               DESC/SMD:
                       M38510 (New PIN):
                           MIL-STD-1562:
            National Stock Number (NSN):
             NSN Codes: ISC, RNVC, RNCC:
                       Images Available: YES
                     Device Description:
                        Internal Number:
Page 1
Mon Jan 10 15:40:14 2005
Number of Pins: 60          Pinout Index: IF06000007
  1 Output 12
  2 Output 11
  3 Output 10
  4 Output 9
  5 Output 8
  6 Output 7
  7 Output 6
  8 Output 5
  9 Output 4
 10 Output 3
 11 Output 2
 12 Output 1
 13 DL
 14 Ground
 15 FS1
 16 FS2
 17 DS1
 18 DS2
 19 DS3
 20 C
 21 R
 22 CR
 23 STB
 24 SHL
 25 M/S
 26 Phase 2
 27 Phase 1
 28 FRM
 29 VCC
 30 NC
 31 M
 32 NC
 33 CL
 34 DR
 35 NC
 36 VEE
 37 V1
 38 V2
 39 V5
 40 V6
 41 Output 32
 42 Output 31
 43 Output 30
 44 Output 29
 45 Output 28
 46 Output 27
 47 Output 26
 48 Output 25
 49 Output 24
 50 Output 23
 51 Output 22
 52 Output 21
 53 Output 20
 54 Output 19
 55 Output 18
 56 Output 17
 57 Output 16
 58 Output 15
 59 Output 14
 60 Output 13
işine yararmı bilmem ama olan bu elimdeki
rast gele
Benzer Konular (2)
