kumanda devresi lazim
Başlatan upayi, 11 Ağustos 2007, 17:40:48
upayi
arakadaşlar bana kuamnda devresi lazim http://www.denizelektronik.com/akilli_kumanda.htm
gibi lazim en az 3 tusu olmali.IR uzerinden sinyal gondermeli
upayi developer free energy system (oler cell free energy motor design Guns design (magnetic guns=)
bs
upayi
st12codec ler turkiyede satiliyormu
Applications
Burglar alarm system
Smoke and fire alarm system
Garage door controllers
Car door controllers
Car alarm system
Security system
Cordless telephones
Other remote control systemsFeatures
Encode / Decode on single chip
Built in Oscillator
Minimum External Components
Wide operating voltage range. (2.0 - 5.5V)
Single chip Encoding Decoding Mode
40kHz carrier for infrared transmission medium
18 pin DIP packagePin Number
Description
1-4
A0-A3 - 4 bit Address Input
5
GND – Ground
6-13
D0-D7 – 8 bit Data input if configured as Encoder
D0-D7 – 8 bit Data output if configured as Decoder
14
VCC - +5V DC
15
ENC-DEC – Configure chip as Encoder or Decoder
 Encoder if pin is tied to VCC
 Decoder if pin is tied to GND
16
DATA RX-TX – Transmit data or Receive Data from this pin through IR/RF Interface
17
LATCH-MOM – Applicable in Decoder Mode
 Latching output (Toggle Output) if pin is tied to VCC
 Momentary output if pin is tied to GND
In encoder mode tie this pin to GND or VCC and do not leave it floating
18
Mode IR/RF – Selects Transmit / Receive by Infrared or Radio Frequency
 IR Mode if pin is tied to VCC
 RF Mode if pin is tied to GND
Encoder sends 40khz Modulation signal in IR Mode for driving IR LED
Decoder inverts received data in IR Mode
Hic fena değil ozellikler
